| [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] | |
+18Destructive mr.modified TheCollector RichieRichOverdrive George Gooding Murraymountain biggasmowers prancstaman Dustin M. CraftsmanQuad19 diddie Double W Cross Ranch SebastianAlbrecht Crazy_Carl Offroad MudMowers AllisKidD21 Hillbilly Offroading MightyRaze 22 posters |
Age : 22 Join date : 2018-02-27 Points : 3630 Posts : 1299
Age : 49 Join date : 2016-09-06 Points : 15032 Posts : 10618 Location : Oklahoma
| Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] March 6th 2019, 1:03 pm | |
| It's pretty sturdy from the factory. I will be removing one brace, so I may have to after that. I don't know for certain at this time. I may just modify the brace.
I will be going back to a stock front axle but I will be removing the horrible GT steering for a Rack & Pinon steering. Parts are on order. | |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2637 Posts : 582 Location : Reeses Mill, WV
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5117 Posts : 2561 Location : Rochester, New York
diddie Member
Age : 56 Join date : 2016-10-02 Points : 3214 Posts : 411 Location : Indiana
| Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] March 7th 2019, 5:33 pm | |
| - MightyRaze wrote:
- It's pretty sturdy from the factory. I will be removing one brace, so I may have to after that. I don't know for certain at this time. I may just modify the brace.
I will be going back to a stock front axle but I will be removing the horrible GT steering for a Rack & Pinon steering. Parts are on order. Where are you getting your rack & pinion ? I've seen one on Go Power Sports that look like it would work real well on a mower. was planning on getting one for my trail mower. | |
| Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] March 8th 2019, 12:58 pm | |
| - SebastianAlbrecht wrote:
- What do U have planned for the Front End now??
See my post a few up. - MightyRaze wrote:
I will be going back to a stock front axle but I will be removing the horrible GT steering for a Rack & Pinon steering. Parts are on order. Notification, my parts should be in on Monday. I should have lots of wrenching time not this weekend, but next. The Wife is headed out of town with her Mom to visit some family out of state. I'll have LOTS of free time. If I can get some Warm temps, I could potentially have the base frame repainted, but that may be a stretch. | |
diddie Member
| Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] March 8th 2019, 5:44 pm | |
| - MightyRaze wrote:
- I got mine at BMIKarts. One for a yerf dog. I could find another but, I am familiar with it. I have the same one on my rig Kal.
just checked that out at BMIKarts looks about the same but cheaper and comes with the outer tie rods thanks for the info. looks like what im in the market for. | |
| Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] March 8th 2019, 11:55 pm | |
| - diddie wrote:
just checked that out at BMIKarts looks about the same but cheaper and comes with the outer tie rods thanks for the info. looks like what im in the market for. Keep in mind, it is pretty wide. I had to chop down and reweld my tie rods to make it work. | |
diddie Member
| Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] March 9th 2019, 12:39 am | |
| - MightyRaze wrote:
- diddie wrote:
just checked that out at BMIKarts looks about the same but cheaper and comes with the outer tie rods thanks for the info. looks like what im in the market for. Keep in mind, it is pretty wide. I had to chop down and reweld my tie rods to make it work. oh I know modifications are part of this ! that's what my life is all about [modifications] ! | |
Age : 20 Join date : 2017-06-09 Points : 5276 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] March 11th 2019, 3:34 pm | |
- MightyRaze wrote:
Hmmm...is that an 820 case I see sitting there?
Happy birthday to your wife! Yeah that is the top half of the 820 for Li'l Red. I was getting it out of the way while I was welding me a hub for the ring gear. | |
| Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] March 11th 2019, 3:38 pm | |
- Dangit!! That looks AWESOME!!!!!!!
I'm so damn Jealous to that Mower! I probably should have multi-quoted, but I'm just too darn lazy today. I was shocked how easily turning an opposed would be on the old craftsman. I don't even need a new belt. May need a little trim on the steering brace. I'm going back about an inch larger than the original stock pulley. I may step up one more inch. I am uncertain at this time. Only care about hitting 8-10 on this. | |
| Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] March 15th 2019, 9:13 pm | |
| All right... not much to account for on Patriot. I did install a new air cleaner. Good to have it there while I do some cleaning of the engine. I did get it sprayed down today and all the sand washed off. I also, moved the new starter and ignition coil to this engine. Business card is there to remind me to set the gap tomorrow. This however will be my big project tomorrow. I would like to get this done so I can install it on the tractor. | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 4880 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] March 16th 2019, 12:48 am | |
| Would be a good idea to move the rack a little closer to the axle so the arms are angled back while going straight. That way when at full turn you are pulling the spindle arm with a straight or angled back rod. If the rod is slightly forward while at full turn, the rod might lock up at full turn. Little sample of what I mean. | |
| Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] March 16th 2019, 2:23 am | |
| Thanks, I haven't really mocked it up yet as I need to fix the spindles first. The ones I have are too long for the axle. I will definitely keep those angles in mind for the build. I did exactly that with Kal's steering last year. It works smooth! | |
diddie Member
| Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] March 16th 2019, 11:01 pm | |
A little fun fact for those who don't know YERF DOG. is the creators last name spelled backwards Godfrey ! | |
