| George Gooding's Mini-Beast [Former 2019 Build-Off Entry] | |
+7mowerjunkie03 AllisKidD21 SebastianAlbrecht Offroad MudMowers Hillbilly Offroading MightyRaze George Gooding 11 posters |
George Gooding Member
Age : 50 Join date : 2018-06-15 Points : 2283 Posts : 133 Location : Joplin Missouri
| Subject: George Gooding's Mini-Beast [Former 2019 Build-Off Entry] February 17th 2019, 12:46 pm | |
| This will be my first true build so please bear with me. My plans for it will include but not limited to: Entirely new paint scheme Stretched frame Custom built bumper/brush guard Custom front axle using 1x2x11ga tubing Custom front spindles and hubs with bearings instead of bushings Winch LED lights Hopefully a pair of 25x10x12 or taller atv tires on the rear Tool and battery boxes mounted on the rear Custom receiver hitch Will be leaving the T-axle unlocked Cargo rack(s) Rewire to include a fuse box Approved: MightyRaze 2-18-19
Last edited by MightyRaze on November 10th 2019, 1:50 am; edited 12 times in total (Reason for editing : Build-off denial) | |
Age : 49 Join date : 2016-09-06 Points : 15032 Posts : 10618 Location : Oklahoma
| Subject: Re: George Gooding's Mini-Beast [Former 2019 Build-Off Entry] February 17th 2019, 3:36 pm | |
| Approved. Your sign is very hard to read. I did throw some filters at it and could read: ATLTF2019 Build OffPW: Goulash2-18-2019 or 2-17-2019George GoodingThis is good enough to get you started. Good Luck!
Last edited by MightyRaze on February 18th 2019, 8:33 pm; edited 1 time in total | |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2637 Posts : 582 Location : Reeses Mill, WV
Offroad MudMowers Member
Age : 20 Join date : 2018-01-09 Points : 2384 Posts : 81 Location : Washington
| Subject: Re: George Gooding's Mini-Beast [Former 2019 Build-Off Entry] February 21st 2019, 2:58 pm | |
| Originally it's a MTD 800 series, those front wheels are from a Honda atv, 18 hp oppey and a peerless 2300 T-axle. Can't seem to source any 3/4 x 1 3/8 non-flanged greasable bearings though, will not give up on them as bushings are hopefully not an option for me. | |
Age : 22 Join date : 2018-02-27 Points : 3630 Posts : 1299
| Subject: Re: George Gooding's Mini-Beast [Former 2019 Build-Off Entry] April 1st 2019, 2:00 pm | |
| Got a little more done this weekend, I like how it's turning out just not how long it's taking. Actually did a little more than what's pictured but I won't show it until I'm pleased with how it looks but I will post pictures of the frame crss brace for the front axle when I'm done welding, grinding and drill drilling it | |
Age : 25 Join date : 2016-07-10 Points : 8371 Posts : 5190 Location : Ontario Canada
| Subject: Re: George Gooding's Mini-Beast [Former 2019 Build-Off Entry] April 14th 2019, 9:12 pm | |
| Ooo, neat looking suspension setup! Looks like there are two pivot points, is it an independent setup? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: George Gooding's Mini-Beast [Former 2019 Build-Off Entry] April 17th 2019, 1:57 pm | |
| - George Gooding wrote:
- AllisKidD21 wrote:
- Ooo, neat looking suspension setup! Looks like there are two pivot points, is it an independent setup?
It's a semi-IFS, now I just need to figure out the steering set up Yeah, looks kinda like a trophy-truck style independent setup. Should be pretty cool! Are you planning on running radius arms or are the beams and pivots strong enough as is? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
mowerjunkie03 Member
Age : 20 Join date : 2018-10-29 Points : 2380 Posts : 342 Location : Burnt Ranch, California
| Subject: Re: George Gooding's Mini-Beast [Former 2019 Build-Off Entry] April 18th 2019, 8:00 pm | |
It's a semi-IFS, now I just need to figure out the steering set up Yeah, looks kinda like a trophy-truck style independent setup. Should be pretty cool! Are you planning on running radius arms or are the beams and pivots strong enough as is? I haven't decided yet, it's all made out of 1x2x11 ga tubing, 1/4" plate and 3/4" grade 8 bolts | |
| Subject: Re: George Gooding's Mini-Beast [Former 2019 Build-Off Entry] April 23rd 2019, 3:19 pm | |
| - mowerjunkie03 wrote:
- Is that a leaf spring function as the lower arm on the suspension? This reminds me of some golf karts I have seen.
No leaf springs, I thought about using one but decided that would be too easy, LoL | |
| Subject: Re: George Gooding's Mini-Beast [Former 2019 Build-Off Entry] April 23rd 2019, 10:55 pm | |
No leaf springs, I thought about using one but decided that would be too easy, LoL Woops my bad thought the arms were a single leafspring. Looks good man. The bigger tires will bring up the rear just enough. It will still have a pretty good squad but that should look good with the stretch ans suspension. | |
| Subject: Re: George Gooding's Mini-Beast [Former 2019 Build-Off Entry] April 24th 2019, 9:02 am | |
| Holy sky sniffing! I thought my tractor was nose up when I was building it. Looking good man!
Only 1 question.. you are building your own independant front. How strong do you think your axle is? With the bigger tires and "sending it" That axle will get stressed pretty good. What do you think the likelyhood of you bending or snapping the axle back would be?
