 George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]
George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Empty
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeWed Apr 24, 2019 9:02 am
Holy sky sniffing! I thought my tractor was nose up when I was building it. Looking good man!
Only 1 question.. you are building your own independant front. How strong do you think your axle is? With the bigger tires and "sending it" That axle will get stressed pretty good. What do you think the likelyhood of you bending or snapping the axle back would be?
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeThu Apr 25, 2019 12:02 am
really means a lot to me Mighty, it's a peerless 2300 5sp T-axle with 1 1/4" shafts, hopefully taking it out this weekend to test the front suspension then I'll start working on the rear and redoing the steering set up.
mowerjunkie03
mowerjunkie03
Forum Rep : 19
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeThu Apr 25, 2019 12:18 am
I didn't know there were 5spd 2300s. I think Mighty was regarding the strength of your front axle(s) just to clarify is it one axle with a single pivot point or two half axles and two pivot points like I-beam suspension?
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeThu Apr 25, 2019 4:27 am
The front axle has two separate arms and 2 pivot points using sintering oillight bearings and 3/4" grade 8 bolts. This is the only 5 speed I've ever seen, 2nd and 3rd gears are close together.
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeThu Apr 25, 2019 4:39 am
George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Img_2047
I'm pretty sure the steering will give out before one of the axles bend. Planning on making some radius arms to help prevent that. I will build those once I've figured out a better steering linkages set up and put some softer ATV shocks on it, just need to find some the exact same length as the Harley Davidson Sportster shocks that are currently on it.
Forum Rep : 213
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeThu Apr 25, 2019 9:51 am
Yeah definitely a good idea to add a couple radius arms, just 'cuz there's so much leverage out there and only one pivot point per beam. I really do like the setup so far though! Very clean work!
Also, when you say your 2300 is a 5-speed are you counting reverse as a speed?
       - Toro Rat Rod Tractor Build
       - Allis B-110, 710 & 716 - Wheel Horse 655 - Case 444 - Bolens Versamatic - Cub Cadet 106  - Jacobsen YT 14 -
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeThu Apr 25, 2019 1:24 pm
A quick video of the front suspension https://youtu.be/kpCXXO1t6n0
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeThu Apr 25, 2019 1:41 pm
Thanks, I appreciate it. It should be 4 fwd but when I ride it's like there's an extra half gear between 1st and 2nd, not quite as low as 1st but slower than 2nd. Don't know if one of the previous owners had some work done to it or what, I haven't split the case yet to see.
mowerjunkie03
mowerjunkie03
Forum Rep : 19
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeFri Apr 26, 2019 12:00 am
Very interesting. Don't know much bout these transaxles but a mysterious thing it is.
Forum Rep : 139
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeFri Apr 26, 2019 11:20 am
What I like about your front end is that it looks like something beefy to start with and I see room in there to put in ATV style steering with minimal bump steer.
Do you think you could pull the shock apart and find some lighter springs?
mowerjunkie03
mowerjunkie03
Forum Rep : 19
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeFri Apr 26, 2019 11:51 am
I don't know how much money your looking to spend but for about 80 bucks you can get a pair of 150cc go kart shocks on gopowersports.com. They are definitely less stiff and they are adjustable. They seem to be about the right length.
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeFri Apr 26, 2019 3:22 pm
I checked on that but it would cost more than just getting another used pair of shocks at the motorcycle salvage yard
diddie
diddie
Forum Rep : 17
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeSat Apr 27, 2019 9:00 pm
I would say the mini beast is a prime canidate for a rack and pinion steering.
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeSun May 19, 2019 2:23 pm
Finally got the rear tires mounted, still needs another 2" or so lift.George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Img_2051
George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Img_2050
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeSun May 19, 2019 2:26 pm
@SebastianAlbrecht hopefully, haven't really had time to test it though it seems a bit squirrelly just by pushing it
mowerjunkie03
mowerjunkie03
Forum Rep : 19
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeSun May 19, 2019 2:30 pm
Already sits alot better with the tires mounted. I think a 2in lift would look good but you could also make drop spindles for the front if you didn't want it to sit to high. Looks good man!
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeMon May 20, 2019 11:48 am
@mowerjunkie03 thanks, but I kinda like the height of it even though it does set a bit higher than I anticipated.
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeMon May 20, 2019 11:54 am
@SebastianAlbrecht took it out for a test drive and it really seems smooth, steers nicely going through the field and almost zero bump steer going over curbs
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeTue May 21, 2019 3:20 pm
@SebastianAlbrecht thanks, I don't think it's turning out to bad for my first true build. Hopefully will be doing a 2" lift on the back this weekend, depending on the weather.
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeMon May 27, 2019 8:04 pm
Got the front bumper mostly done, welder was acting up so I couldn't do the brush guard.George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Img_2053
George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Img_2054
George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Img_2052
Forum Rep : 413
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeMon May 27, 2019 9:16 pm
That Beast has a stance!
Bumper is looking good!
Patriot [2019 Build Off]
Kal-El [2018 3rd Place]
Sasquatch II [2017 Finalist]
Li'l Red 2.0
George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Admins10
George Gooding
PostSubject: Re: George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end]   George Gooding's Mini-Beast [2019 Build-Off Entry] [possible forfeit move to builds at end] - Page 2 Icon_minitimeMon May 27, 2019 9:21 pm
@MightyRaze thank you sir, means a lot coming from you
» Mickee's Huge Migraine [2017 Build-Off Entry]
» Anatomy of a Bonk - St. George 2011
» George Harvey’s 3rd Annual “Hawks Rising Star 2K9” Tourney!
» Price quote to build a racing mower
» which one to buy
