| [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] | |
+18Murraymountain prancstaman TheRainbowBoxer diddie mr.modified Stretch44875 redzz02 Double W Cross Ranch muddstir AllisKidD21 Hillbilly Offroading Crazy_Carl mowerjunkie03 MatthewD TheBeal SebastianAlbrecht MightyRaze CraftsmanQuad19 22 posters |
Age : 20 Join date : 2017-06-09 Points : 5276 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] August 5th 2019, 5:07 pm | |
| - CraftsmanQuad19 wrote:
- No it was super flexy (only 2 mounting bolt locations) and had a lot of play in it. Just wore out.
I wouldn't give up on it so soon. On my 110, the ross box is bolted to 1/8" steel plate, super dang beefy. Mine had a ton of play too before I rebuilt it. All you have to do to adjust the play is to put the steering wheel in the middle of the play, put a flat head screwdriver in that bolt head, loosen the nut, then tighten the bolt head until its tight, but not too tight. Then tighten the nut down. I had to lock tite mine in, it backed out after a bit. Now the box has no play in it and the tractor steers beautifully after I filled it with a ton of grease. It is just under power steering, I'd say. It feels great. The box has 2 bearings in it, a worm gear so it doesn't bump steer, and when you put the steering wheel somewhere it stays there. It doesn't turn when it hits a bump. I've been told these have been designed after old Jeep steering boxes, and they do look pretty similar. Of course, it's your tractor, and you do whatever you'd like, but I wouldn't give up on the box just like that. | |
Age : 25 Join date : 2016-07-10 Points : 8371 Posts : 5190 Location : Ontario Canada
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] August 5th 2019, 5:29 pm | |
| Some of them have different mounting holes though. I noticed the Ross box on my cousin's 1250 Cub flexes pretty bad when you turn the wheels with the tractor stopped. Too much for my liking. The setup on the early Deere's like that was much better.
Also sometimes those cam follower dowels get worn to where they won't ride in the worm gear properly, and they need to be re-turned to get the right edge or just simply replaced. I think sometimes if they're worn enough, adjusting them in tighter can damage the worm gear. Even though it reduces the steering play.
It's kind of a finicky thing adjusting steering boxes so that you don't damage anything long-term, even in automotive applications. It can be done with the right patience though. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 23 Join date : 2016-04-12 Points : 5740 Posts : 2617 Location : Indiana
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] August 5th 2019, 6:49 pm | |
| Ah, for the sector shaft? That's not so good. You could probably replace them but the shaft itself might even be worn a little bit.
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] August 5th 2019, 8:01 pm | |
| They’re pretty ovaled out. I’m sure they’re just brass or something but it’s probably gotten into the shaft itself. And mine doesn’t have the holes on the side, just the two next to the input. So there just isn’t a good way to go about it.
AK said something about the cub flexing real bad, this one is from a cub | |
diddie Member
Age : 56 Join date : 2016-10-02 Points : 3214 Posts : 411 Location : Indiana
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] August 6th 2019, 10:24 pm | |
Steering and power were the biggest things holding me back at haspin I think. Debating just buying a brand new predator 708, it mounts the oil filter up higher so I wouldn’t have to screw with a remote mount or anything like that, plus being brand new should mean less carb troubles and such. Finding parts may be harder though so I’m not sure. What do you guys think? Never assume Brand New means less troubles ! | |
Murraymountain Veteran Member
Join date : 2019-02-04 Points : 4205 Posts : 2167 Location : North Carolina
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] August 28th 2019, 8:18 pm | |
| No, looked around for engines, found a brand new vanguard 18 for 500 bucks. Little salty but it would be my first brand new engine and hopefully I wouldn’t have to worry about it for awhile.
I need to get it out of the trailer and take some measurements for the new steering setup. Also got some 1 into 2 cable splitter blocks so I’ll be able to rig up my front brakes finally. But the dumb thing isn’t even unloaded from haspin yet hahaha | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] August 31st 2019, 6:34 pm | |
| - Murraymountain wrote:
- It looks like the first one fits the best. And there is a couple build off entries using the second hood already, and also, since it's a '91, I think a 90s hood would fit the build better.
Just my two cents. Honestly I kinda like the newer style hood as well. And I won’t feel bad about trashing it when I roll it again hahaha | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] August 31st 2019, 6:35 pm | |
| - mr.modified wrote:
- I think they both look decent. I guess it just depends on what look you like. I think the one has that older more vintage look. The other has the somewhat sleeker, new look.
I agree 100%. I like the vintage look and presence but I’m kinda leaning towards the sleek newer lines. I think they compliment the rest of the build better | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] September 13th 2019, 10:36 am | |
| New rack and pinion setup has arrived. Doesn’t feel super beefy, but I’ll reserve judgment until I’ve installed it. Bought the full kit for about an extra 30 bucks just because it comes with the splined u joints and everything. Just the rack is 75 bucks I think. I will need to shorten the tie rods a lot, and I know I’ll need to lengthen the rotating shaft. Thinking of using some form of U bolt clamp like you would see on leaf springs or and exhaust to mount it. Think it will be strong enough? | |
Age : 49 Join date : 2016-09-06 Points : 15032 Posts : 10618 Location : Oklahoma
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] September 13th 2019, 11:01 am | |
| Nice. That the 17" wide one? Does that one have play like @redzz02's? I seen those, but wasn't entirely sure how to mount it or seemed involved to mount it with U-bolts? Also, the u-joint shaft is not floating extendable? You should still be OK with the independent front end as your rack should be in a fixed location. In my case for Kal, I needed one that was extendable. Here is the list of parts I used in Kal: | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] September 13th 2019, 11:12 am | |
| Gotcha. Yeah I was going to go with the one you used in kal, but I needed something to get it done by the buildoff. I guess if this one doesn’t work out I can always swap to the one you got. Hopefully they’re back in stock by then.
Also might be looking at an engine tonight. Listed for 650, but is a brand new never ran vanguard 18 horse. Hoping to talk him down to 500 even, but either way that’s an expensive engine in-box. He’s only asking about a third of the sticker price | |
diddie Member
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] September 13th 2019, 11:11 pm | |
| Yeah the crank journal is probably all scarred up. A brand new engine would be nice! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 29 Join date : 2010-05-12 Points : 6160 Posts : 899 Location : PA pittsburgh and pymatuning
