MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Lend10PortalHomeFAQSearchMemberlistRegisterLog inDiscordCountdown TimerMUD MURRAY Woods-Offroader [2019 Build-Off Entry] Rend10
Forum Rep : 45
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Empty
PostSubject: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeTue Jun 04, 2019 12:43 pm
There U go...
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats269
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats267
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats266
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats268
this is getting MUD MURRAY !!!
Here is its old Thread: Mud Murray
its life started as this :
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] 20180615
I heavily reinforced its frame 1 year ago:
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] 20180831
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] 20180815
Plans:
-14HP Vanguard
-Peerless 930 Oil Converted Open Diff
-Turfs for now, 22x12x8 Bearclaws & 16x6,5x8 for when I have Money
-3:2 Pulley Swap
-LED Lights
-Dynamark rear fenders
-front Fenders
-custom Exhaust
-trailer Hitch
-repaint
-custom Shifter
-Trying to reuse as much parts I already have instead to buy stuff
-front Bumper
-maybe throwing a snow plow on it
I want to go Budget Build on it since Im pretty low on cash currently & need a good Mower ASAP!
Approved mightyraze 6-4-2019
Forum Rep : 341
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeTue Jun 04, 2019 9:50 pm
Looks under 50%.
Good luck!
Patriot [2019 Build Off]
Kal-El [2018 3rd Place]
Sasquatch II [2017 Finalist]
ATLTF Facebook Page
How To Upload Pictures
ATLTF Staff:
Forum Rep : 45
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeWed Jun 05, 2019 2:16 am
@MightyRaze wrote:
Looks under 50%.
Good luck!
Thank U 4 approving it Mighty!
Forum Rep : 45
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeWed Jun 05, 2019 10:42 am
I kinda want big Tires, & the BearClaws R cheaper than Mud Lites, but i'm not sure if my 930 with open diff will be able to handle them well...
What's your Opinions & experiences?
Forum Rep : 72
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeThu Jun 06, 2019 1:44 am
Doc lock it and don't do too many clutch dumps and it'll handle mudlights.
Although I wouldn't hold off on clutch dumps myself as i can get msts and 900s $5 apiece
Forum Rep : 45
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeThu Jun 06, 2019 12:09 pm
hmm need to get a live axle first & couldnt find that stuff here
WTFH!!! SO DIRTCHEAP???
Forum Rep : 72
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeThu Jun 06, 2019 12:44 pm
Can you not find a piece of ¾" keyed crs? You have no metal suppliers up there?
Forum Rep : 45
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeThu Jun 06, 2019 12:58 pm
Ive only found metric sized round stock but thats no hardened axle & has no keyway....
I could turn it down but the keyway & hardening process would fail @ me
Forum Rep : 72
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeThu Jun 06, 2019 9:53 pm
They don't need to be hardened. No axle shaft i have is. Keyways can be cut with angle grinder and a steady hand and some layout
Forum Rep : 45
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeFri Jun 07, 2019 4:05 pm
good to know!
Gonna watch out 4 that stuff!
Forum Rep : 45
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeSat Jun 08, 2019 3:29 pm
FINALLY GOT PROGRESS ON IT!!
I took the angle grinder out & prepped the frame 4 paint
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats270
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats272
then I primed it
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats271
& threw underbody protection on the underside of that Frame
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats274
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats273
gonna let it dry & then paint the good side
I originally wanted to cut a big hole in the rear of the frame to get good access to the trans but realized that wont work when I want to use the stock clutch & decided to just drill few big access holes in the frame to be able to pull the clip that holds the pulley on & maintain the fill/drain hole
Forum Rep : 15
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeSat Jun 08, 2019 6:23 pm
Now you'll never notice those sickening welds!!! lol!
Forum Rep : 45
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeSat Jun 08, 2019 6:32 pm
Try to weld 8mm flat stock with 3mm frame together with a cheap ass welder & 2,5mm welding rods!
It were extremely hard to get the welds there cuz the welds wanted to only stick to 1 piece of metal & I had to weld the same spot 3-4 times smtms to get it a good hard weld!
IKR it doesnt change the fact that my welds & welding skills suck, but it holds & thats what matters LOL
Forum Rep : 15
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeSat Jun 08, 2019 8:08 pm
Right. I was restating what you've always said. Besides, as long as it holds. And I never thought those welds were bad, I was just going along with everyone else. (I don't even know how to weld MUD MURRAY Woods-Offroader [2019 Build-Off Entry] 1098998679)
Forum Rep : 45
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeSun Jun 09, 2019 4:18 am
yeah my welds suck, my skills as well, but as long as the final product (MUD MURRAY) is a reliable woods rig, nothing to complain LOL
Forum Rep : 45
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeFri Jun 14, 2019 2:49 pm
PAINTING TIME!!
I felt horrible today after i was home from work but since the Work @ home is piling up on me I decided to still do something to my stuff & that was PAINTING!
Threw the 1st coat on the Frame:
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats295
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats294
& on the other parts as well (prolly leave them with just 1 coat)
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats293
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats297
MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Whats296
I really like the black dashboard & guess when I have the stainless piece on it it will look badass!
Gonna buy the CAMO PAINT soon to make it SEXY!
Ran outta black paint as well cuz these were the leftovers from CrapTD (2018 Build Off) & have to buy new stuff to get it on the trails AFAP!
Forum Rep : 15
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeFri Jun 14, 2019 10:18 pm
I like that black. Did you ever think about painting the whole thing black?
Forum Rep : 45
PostSubject: Re: MUD MURRAY Woods-Offroader [2019 Build-Off Entry]   MUD MURRAY Woods-Offroader [2019 Build-Off Entry] Icon_minitimeYesterday at 2:14 pm
I Wont paint it black cuz every1 paints his stuff black & I'm just tired of seeing black mowers everywhere... & when I paint my main rig BLACK it will be bad!
» 2002 craftsman utility rig ''ol blue'' [2016 Build-Off Entry]
» Mickee's Huge Migraine [2017 Build-Off Entry]
» Murray Street Mower
» Lawn Flite Trail/mudder build
» Anyone ever go to lake murray ok
