 98 craftsman trail rig build
98 craftsman trail rig build - Page 3 Empty
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeFri Nov 29, 2019 11:28 am
No requirements to keep your thread going or delete. If so, 90% of the forum would be gone. Drunk
yeethaw
yeethaw
Forum Rep : 4
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeWed Dec 04, 2019 6:46 pm
All right so I found a MST205 pretty cheap That I’m gonna put in here And the guy also has A whole Murray steering set up for pretty cheap like $10 so do you think it’s worth it to go and swap over the Murray steering would it be any tighter than this that I have now
Rerun
Rerun
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeWed Dec 04, 2019 7:09 pm
Murray steering setup is probably not much better..or not worth the hassle of setting it up. Don’t get me wrong, Murray is a has a decent setup for low speeds but would need some beefing up for rough terrain use. And for speed the front axle should be locked so it don’t pivot. MST transaxle are good...I really like them. As long as you vent the case you can put a lot of rpm’s to them without hurting it.
Forum Rep : 42
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeWed Dec 04, 2019 8:10 pm
In my opinion, MST's are the best vertical shaft tranny next to a Peerless 820. You can never have enough MST's LOL. Peerless 930's and pretty much any Spicer is junk. But I love MST's. Get it if you can. Also, is anything wrong with the trans that's in your rig or do you just want an MST? I believe you said it has a Spicer...
Honestly, Murray steering is WAAAYYY better than the gearbox that's in yours. It would help a lot, but not to the point that there is no play at all. Murray steering is good for about 30MPH tops. That's when it starts to get hairy. But if you're only looking to take "most" of the play out of the steering I say do it.
yeethaw
yeethaw
Forum Rep : 4
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeWed Dec 04, 2019 8:22 pm
I’m prolly not going to be using this on much rough terrain and I’ll be raising the front axle up till its unable to move
Forum Rep : 232
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeWed Dec 04, 2019 8:51 pm
Or of course a 600 Series. 98 craftsman trail rig build - Page 3 2240318088
       - Toro Rat Rod Tractor Build
       - Allis B-110, 710 & 716 - Wheel Horse 655 - Case 444 - Bolens Versamatic - Cub Cadet 106  - Jacobsen YT 14 -
Forum Rep : 42
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeWed Dec 04, 2019 9:59 pm
So this is kind of a street build? I would just go ahead and get the Murray steering (that is, if it's out of a Widebody.) and throw it on. It'll help a lot.
Are 600 series vertical shafts? I thought those were horizontal...
yeethaw
yeethaw
Forum Rep : 4
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeWed Dec 04, 2019 10:03 pm
alright thanks then i guess ill get it
Forum Rep : 439
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeWed Dec 04, 2019 11:26 pm
Yes they are vertical.  Heaviest gear vertical I know of.
Here is @AllisKidD21's in MTD
@AllisKidD21 wrote:
98 craftsman trail rig build - Page 3 Trans011
Kal-El [Rally Trail Tractor]
Li'l Red 2.0 [Rally Trail Tractor]
SuperADMINS:
Admins:
Mods:
@Doug; @MightyRaze
@"Doc Sprocket", @Stretch44875
@AllisKidD21, @TheRainbowBoxer
ATLTF Facebook ~ How To Upload Pictures
Forum Rep : 42
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeThu Dec 05, 2019 9:31 am
Well, that may shine a different light on a future build...
Forum Rep : 439
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeThu Dec 05, 2019 1:00 pm
OK, lets get back on topic now.  :-)
SuperADMINS:
Admins:
Mods:
@Doug; @MightyRaze
yeethaw
yeethaw
Forum Rep : 4
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeFri Dec 06, 2019 11:57 am
so this weekend ill be cleaning part of our storage container up and ill be able to work in there and start lowering this thing, my plan is to raise the front axle into the frame all the way till it cant pivot and to flip the transaxle, is there going to be any problems running the oil filled mst 205 upside down?
also could one of the admins move this to the another more fitting section since this is going to end up being a drift mower
Rerun
Rerun
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeFri Dec 06, 2019 12:28 pm
Yeah you will need to get a seal for the input shaft.
Forum Rep : 439
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeFri Dec 06, 2019 3:22 pm
Moved to a "unique" build.
Another potential leaking area would be the shifter.
SuperADMINS:
Admins:
Mods:
@Doug; @MightyRaze
Forum Rep : 118
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeFri Dec 06, 2019 4:37 pm
On the mst there’s also a plug next to the shifter, should seal but there’s potential there for leakage
Forum Rep : 76
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeFri Dec 06, 2019 8:25 pm
If you flip the transaxle upside-down then you will have 5 reverse gears and 1 forward gear. By flipping the transaxle upside-down, the input shaft will be spinning in the opposite direction in relation to the case. Need to modify the transaxle gearing inside the case for it to work right.
Forum Rep : 118
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeFri Dec 06, 2019 9:20 pm
All that takes is reversing the order of the stack though right? None of them are cast as part of the shaft luckily
yeethaw
yeethaw
Forum Rep : 4
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeFri Dec 06, 2019 9:47 pm
Your gears will be right if you flip it upside down then flip it end to end which is what I’ll do
Forum Rep : 232
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeFri Dec 06, 2019 10:24 pm
I think it'll work fine if you just flip it, lots of racing mower guys flip transaxles for lowering and never have to modify the transaxle internally.
Rerun
Rerun
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeSat Dec 07, 2019 4:49 am
I flipped a MST 206 in a Murray wide body with no gearing mods. Just a input seal and some linkage mods for the shifter and brakes (if using). I had to run 20” tires to keep the frame off the ground.
Forum Rep : 118
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeSat Dec 07, 2019 9:42 am
If you get 5 reverse gears, you can turn it 180 degrees so the axles would be in front of the gear stacks in relation to the tractor...does that make sense?
yeethaw
yeethaw
Forum Rep : 4
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeSat Dec 07, 2019 10:51 am
idk but it doesn’t matter since I’m prolly not gonna flip it by any ways I got the parts and I’m ready to start98 craftsman trail rig build - Page 3 C5487810
98 craftsman trail rig build - Page 3 Cd939110
98 craftsman trail rig build - Page 3 9143e210
Forum Rep : 118
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeSat Dec 07, 2019 12:10 pm
Personally I’d run a jack shaft using a deck spindle
yeethaw
yeethaw
Forum Rep : 4
PostSubject: Re: 98 craftsman trail rig build   98 craftsman trail rig build - Page 3 Icon_minitimeSat Dec 07, 2019 7:09 pm
I’m thinking what I’m gonna do is mount the front axle so the top of it is up against the bottom of the frame and then for the back I ordered 18 inch tires so I’m gonna lower the fenders till there just above the top of tires and then I’ll still have enough ground clearance to go and ride in the woods
