| | LOCKED TRANSAXLE | |
+4Ford Boi blanket80 dangeroustoys56 craftsman30mph 8 posters | Author | Message |
craftsman30mph Member
Age : 31 Join date : 2011-08-23 Points : 4813 Posts : 127 Location : branch MI
| Subject: LOCKED TRANSAXLE September 30th 2011, 8:33 pm | |
| Quick question for you guys, I want to lock my transaxle and I want to know if it is worth it and if it breaks easier, because I am a pretty good welder even tho I haven't done it much But let me know if it is worth the work thanks guys | |
| Subject: Re: LOCKED TRANSAXLE September 30th 2011, 9:23 pm | |
| Depends- you might not like it - first itll be hard to steer with a locked axle, specially in trail/rock conditions.
To weld, the trans gears will need to be super clean to get a solid weld, and theres no guarantee that it wont break if run too hard.
Once i get my couple mod tractors going with the straight rear axles- ill probably be swearing up and down i shoulda used a diff axle. | |
| Subject: Re: LOCKED TRANSAXLE September 30th 2011, 11:35 pm | |
| - dangeroustoys56 wrote:
- Depends- you might not like it - first itll be hard to steer with a locked axle, specially in trail/rock conditions.
Once i get my couple mod tractors going with the straight rear axles- ill probably be swearing up and down i shoulda used a diff axle. I will really only be using mine for mudding I don't have a lot of rough territory around me so mostly just mud and I want as much traction as possible thats why I was considering it | |
| | | blanket80 Member
Age : 28 Join date : 2010-11-10 Points : 5077 Posts : 128 Location : Scottdale, PA
| Subject: Re: LOCKED TRANSAXLE October 1st 2011, 2:08 am | |
| If it is welded right, all the slag out of it, and you put back together right. it will be just as strong or stronger than before. I welded mine in my mudder over a year ago and its still going good. The only times I've had problems was if I messed up welding, or put it back together wrong. I would try to do it the way fearlessfront has in his video, but there are other techniques aswell. | |
| | | Ford Boi Member
Age : 39 Join date : 2010-08-22 Points : 5252 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: LOCKED TRANSAXLE October 1st 2011, 9:21 am | |
| I've welded many differentials, different ways and I've rarely had problems. Usually I will break teeth off the gears or shear the center pins, my welds never break:) This is a picture of my "fozzy" spider gears, an Idea I took from a friend's full-size Bronco. I was skeptical, but it's been run for over a year as a mudder, rock crawler, been rammed and slammed, I even broke an axle clean off, and my diff is still solid. Also this "fozzy" allows some rotation of the diff in tight situaions. When I took the transaxle apart to replace the broken axle I was amazed at the condition of the differential. | |
Age : 44 Join date : 2010-06-28 Points : 5590 Posts : 511 Location : Southern WV
| Subject: Re: LOCKED TRANSAXLE October 1st 2011, 9:46 am | |
| I wish I'd done the fozzy locker but forgot about it. I doubt mine will break but the fozzy would have been easier and less work/cleanup. | |
| | | redneckcarrow Member
Age : 54 Join date : 2010-12-22 Points : 4908 Posts : 30 Location : maine
| Subject: Re: LOCKED TRANSAXLE October 1st 2011, 10:05 pm | |
| like the fozzy locker never thought of that it would be a lot easyer becouse no slag in the transaxle but if i dont do it that way i would go with fearlessfronts way just my two sents | |
| Subject: Re: LOCKED TRANSAXLE October 1st 2011, 10:08 pm | |
| how do these so called "fozzy gears work??? does the welded teeth make it so they can't spin??
| Subject: Re: LOCKED TRANSAXLE October 1st 2011, 11:08 pm | |
| Throwing a wrench in the gears as the say. However one thing I've read about the fozzy locker in truck axles is that the will try to walk up over the welds and it can crack the carrier. Doubt mowers have to worry about it though. | |
| | | blanket80 Member
| Subject: Re: LOCKED TRANSAXLE October 2nd 2011, 1:23 am | |
| I've never heard of the "fozzy" before, but it might be worth a try. | |
| | | dirtybird Member
Age : 44 Join date : 2011-09-30 Points : 4629 Posts : 26 Location : Nova Scotia
| Subject: Re: LOCKED TRANSAXLE October 2nd 2011, 11:51 am | |
| - Ford Boi wrote:
- I've welded many differentials, different ways and I've rarely had problems. Usually I will break teeth off the gears or shear the center pins, my welds never break:) This is a picture of my "fozzy" spider gears, an Idea I took from a friend's full-size Bronco.
I was skeptical, but it's been run for over a year as a mudder, rock crawler, been rammed and slammed, I even broke an axle clean off, and my diff is still solid. Also this "fozzy" allows some rotation of the diff in tight situaions. When I took the transaxle apart to replace the broken axle I was amazed at the condition of the differential. Thats a nice set up!,, very interesting!,, I used to live in yarmouth NS, I'm there all the time. | |
| | | Ford Boi Member
| Subject: Re: LOCKED TRANSAXLE October 3rd 2011, 10:43 pm | |
| - craftsman30mph wrote:
- how do these so called "fozzy gears work??? does the welded teeth make it so they can't spin??
Exactly. It allowes it to turn so much either way, then locks. It's great it tight situations where you need to steer . I used alot of solid welded axles and had trouble. For my racers I weld the spider gears right to the center pin. Great for drifting. I suppose you could modify the amont of movement in the diff by filling more or fewer teeth. | |
| | | 1MurrayMayhem1 New Member
Age : 55 Join date : 2011-10-29 Points : 4563 Posts : 5 Location : Tuscaloosa,Alabama
| Subject: welded rear end October 29th 2011, 8:57 pm | |
| welded mine up about 2 months ago and have not had any problems. I am actually amazed at the diference in my ability to climb in the rough stuff. | |
| Who is online? | In total there are 18 users online :: 0 Registered, 0 Hidden and 18 Guests
