Welcome to the All-Terrain Lawn Tractor Forum! 2024 is the 10th and LAST ATLTF.COM BUILD-OFF . . . for now! |
| | How do I Prime my 4 stroke engine? | |
akcender Member
Age : 28 Join date : 2011-12-04 Points : 4604 Posts : 46 Location : Toronto, Ontario, Canada
| Subject: How do I Prime my 4 stroke engine? December 6th 2011, 7:52 am | |
| It has no primer bulb and im not 100% sure where i need to put the gas to prime it. Its a 12HP Tecumseh | |
| | | AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4720 Posts : 208 Location : Tennessee
| Subject: Re: How do I Prime my 4 stroke engine? December 6th 2011, 12:43 pm | |
| Tecumseh Snow King engines use a carb with a fitting for the vacuum line from the primer, however their engines used in tractors have no provisions for a primer. You could do what Briggs did with their older snowthrower engines.... use a pump primer that feeds fuel directly into the intake near the head.
Just curious...why do you need to prime it?
| | | akcender Member
| Subject: Re: How do I Prime my 4 stroke engine? December 6th 2011, 3:48 pm | |
| - AcreFarm wrote:
- Tecumseh Snow King engines use a carb with a fitting for the vacuum line from the primer, however their engines used in tractors have no provisions for a primer.
My battery is dying and i dont have a charger for it so i dont want to run it down by cranking it too much | |
| | | redneckcarrow Member
Age : 54 Join date : 2010-12-22 Points : 4908 Posts : 30 Location : maine
| Subject: Re: How do I Prime my 4 stroke engine? December 6th 2011, 7:32 pm | |
| take the plugs out squirt a little gas in cylender put plugs back in and try it or drizzle little gas in carb and try it just be careful about not spilling any gas on the engine | |
| Who is online? | In total there are 24 users online :: 1 Registered, 0 Hidden and 23 Guests AdnohMost users ever online was 412 on January 7th 2023, 7:59 am |
