| | Transaxle with Pressure Clutch | |
MatthewD Veteran Member
Age : 22 Join date : 2014-11-16 Points : 5537 Posts : 1993 Location : Northern Ireland
| Subject: Transaxle with Pressure Clutch December 10th 2016, 2:23 pm | |
| Evening, Surfing through ebay, found this - Transaxle with pressure clutch fittedIt appears to be a Peerless 900/MST series trans fitted with a 'Pressure Clutch' on top of the pulley. Never seen one of these before. Anyone know how these work, what's the advantage of them over a belt clutch?Ride-On-Mower-Gearbox-With-Pressure-Clutch-Fitted
Last edited by MatthewD on December 10th 2016, 4:17 pm; edited 1 time in total | |
| Subject: Re: Transaxle with Pressure Clutch December 10th 2016, 3:26 pm | |
| I imagine it would work the same as a car type clutch. Your v belt wouldn't need a clutch, just would need to be tight all the time. "Real" style clutch like this would be much less hassle than a v-belt clutch setup. Honda liquid cooled lawn tractors have a setup sort of like this from the factory and of course cub cadets are a more popular example. | |
| | | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8371 Posts : 5190 Location : Ontario Canada
| Subject: Re: Transaxle with Pressure Clutch December 11th 2016, 12:56 pm | |
| The trans in my Rat Rod had one of these setups on it. The friction disk was too wore out though, so I had to do away with it. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Transaxle with Pressure Clutch December 11th 2016, 1:33 pm | |
| Interesting. Was that the 600 in your Rat rod or the previous trans?
From the research I've done, it's two friction plates that ride together when the cable is pulled. | |
| | | Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7553 Posts : 3035 Location : Lebanon County, PA
| Subject: Re: Transaxle with Pressure Clutch December 11th 2016, 1:48 pm | |
| Interesting, never seen a setup like that.
I wonder if it would be prone to slipping when submerged. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Transaxle with Pressure Clutch December 11th 2016, 1:55 pm | |
| - MatthewD wrote:
- Interesting. Was that the 600 in your Rat rod or the previous trans?
From the research I've done, it's two friction plates that ride together when the cable is pulled. Yeah it was on the 600. Kinda wish I'd kept that old clutch haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Transaxle with Pressure Clutch December 11th 2016, 4:31 pm | |
| - Doug Fackler wrote:
- Interesting, never seen a setup like that.
I wonder if it would be prone to slipping when submerged. It probably would slip, unless you could stop water/mud getting into the disks somehow. - AllisKidD21 wrote:
- Yeah it was on the 600. Kinda wish I'd kept that old clutch haha.
Cool, I'm sure it is very hard to find parts for it though. Probably cost the earth to get a new disk or whatever it needed. | |
| Subject: Re: Transaxle with Pressure Clutch December 11th 2016, 4:41 pm | |
| Yeah that's pretty much what I thought at the time. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
