| 72 cub cadet | |
+4willis923 camomanusa Moose Craftsman1998 8 posters |
Craftsman1998 Veteran Member
| Subject: Re: 72 cub cadet March 3rd 2014, 8:55 am | |
| - willis923 wrote:
- you do know you could have extracted the bolts, right? at this point, extract the bolts, have the threads re-tapped, get a head, and rebuild it. it really IS a good vintage engine. as long as its not blown up, there really is no such thing as a BAD engine
I have tried to extract them but they are rust welded. And i dont have the money for a machine shop so i will probably Sell it and buy a better engine. | |
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5577 Posts : 1408 Location : Galway NY
| Subject: Re: 72 cub cadet March 3rd 2014, 8:58 am | |
| - Craftsman1998 wrote:
I have tried to extract them but they are rust welded. i presume that RedneckComputerGeek's candle wax trick would work. if not, is there any way to weld a nut to the broken stud? the heat of the weld should be enough to break it free, then back it out | |
Age : 26 Join date : 2013-10-30 Points : 4968 Posts : 1068 Location : New jersey
| Subject: Re: 72 cub cadet March 3rd 2014, 9:07 am | |
| I tried it multiple times and the nut just twists off so just ground them off and just put a ton of gasket sealer on it so there isnt any head gasket leaks. | |
Age : 57 Join date : 2013-12-21 Points : 4621 Posts : 744 Location : Salem Illinois
| Subject: Re: 72 cub cadet March 3rd 2014, 12:37 pm | |
| welding on a spark plug wouldn't have told you if it would fire.... it absolutely wont after welding. The current induced in the coil from welding could have killed the coil (like lightening bolt inducing current in your phone line and burning your house phone up) The heat from welding the plug on likely melted the conductor inside of the plug as well.
It's good that you knew enough not to weld the head to the block, but this "Test" was never gonna tell ya anything. keep in mind that some of these older engines are worth money... working or not. 805Roadking makes a good bit of money restoring these types of old engines. Broken studs are aggravating, but not the end for an engine.
Keep in mind, I'm not bustin yer chops.... I've been a mechanic for over 30 years.... you are relatively new to it... nuthin wrong with that. I'm trying to give you the reasons why this wouldn't work not just for YOUR benefit, but for others that wish to do this. | |
| Subject: Re: 72 cub cadet March 3rd 2014, 1:27 pm | |
| - Lawren Wimberly wrote:
- welding on a spark plug wouldn't have told you if it would fire.... it absolutely wont after welding. The current induced in the coil from welding could have killed the coil (like lightening bolt inducing current in your phone line and burning your house phone up) The heat from welding the plug on likely melted the conductor inside of the plug as well.
Keep in mind, I'm not bustin yer chops.... I've been a mechanic for over 30 years.... you are relatively new to it... nuthin wrong with that. I'm trying to give you the reasons why this wouldn't work not just for YOUR benefit, but for others that wish to do this. The coil wasnt connected when i was welding. i took it off | |
Join date : 2013-06-01 Points : 4626 Posts : 578 Location : West Virginia
| Subject: Re: 72 cub cadet March 3rd 2014, 1:40 pm | |
| THE PLUG IS TOASTED NOW.... There is your point you needed to learn. 9 times outta ten, you melted the insides of the plug. if you didnt, im impressed. Welding anything to a motor is usually a nono.. | |
| Subject: Re: 72 cub cadet March 3rd 2014, 1:41 pm | |
I have tried to extract them but they are rust welded. i presume that RedneckComputerGeek's candle wax trick would work. if not, is there any way to weld a nut to the broken stud? the heat of the weld should be enough to break it free, then back it out That's not redneck computer geeks idea, that method has been around longer than he has.. | |
| Subject: Re: 72 cub cadet March 3rd 2014, 1:54 pm | |
| Um... the spark plug could be bad. but i put the coil back on when i was done welding. I tried to get it to fire up it didn't so i pulled the cord off the spark plug put a electric meter on it and it read nothing. so i cleaned the connections on the coil Still nothing. I changed the spark plug wire with a spare one i had. still nothing so then i put the one from me 10 hp kohler that runs still nothing I checked the points they were fine but cleaned them anyway still nothing so its obvious the coil or the condenser is bad. And if i get a new coil and condenser and it has spark but the plug has none then ill get a new head but untill then im not putting money out. Im still in the middle of a project when thats done ill think about putting money into the motor to restore it. And repair it. | |
| Subject: Re: 72 cub cadet March 3rd 2014, 3:04 pm | |
| - TroyBilt Pony wrote:
I have tried to extract them but they are rust welded. i presume that RedneckComputerGeek's candle wax trick would work. if not, is there any way to weld a nut to the broken stud? the heat of the weld should be enough to break it free, then back it out That's not redneck computer geeks idea, that method has been around longer than he has.. well thats where i heard it from... | |
| Subject: Re: 72 cub cadet March 3rd 2014, 3:36 pm | |
| as Solomon said, "there's nuthin new under the sun"
a lot of folks refer to redneckcomputergeak's vid, it is a good demo of an old technique. Giving him credit is no slam on whoever first came up with the idea | |
| Subject: Re: 72 cub cadet March 15th 2014, 10:03 am | |
| When i bought my 72 cub the wiring was chewed threw so yesterday i pulled all the wiring out. Cut 2 of my knuckles while doing it. And started scraping of dirt. So i can start measuring the frame to see what engines will fit in it. | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4395 Posts : 467 Location : Greensburg, PA
| Subject: Re: 72 cub cadet March 15th 2014, 3:43 pm | |
| unless i missed it, what are your plans for this cub? | |
| Subject: Re: 72 cub cadet March 18th 2014, 10:05 am | |
| - camomanusa wrote:
- unless i missed it, what are your plans for this cub?
My plan is to get a running motor put it in the tractor and make it a plowing/work tractor. And maybe restore it if i decide to keep it. | |
| Subject: Re: 72 cub cadet March 25th 2014, 2:30 pm | |
| Got the carb soaking in kerosene | |
| Subject: Re: 72 cub cadet July 16th 2014, 10:36 pm | |
| ok so tonight i tore apart the cub i worked on it for 3 hour until it got too dark to see had a lot of rusted bolts so it was a pain. got it down to the frame trannys still in it because i'm going to tear it open tomorrow to look inside. tractor needs A LOT of work. and i was debating just using it for parts but what do you guys think should i restore it or part it out. i would like to start working on a racing mower and a mudding mower. let me know what you guys think i should do. Ill post pictures tomorrow. | |
Age : 27 Join date : 2013-03-18 Points : 7299 Posts : 3131 Location : raleigh nc
| Subject: Re: 72 cub cadet July 16th 2014, 11:11 pm | |
- ok so tonight i tore apart the cub i worked on it for 3 hour until it got too dark to see had a lot of rusted bolts so it was a pain. got it down to the frame trannys still in it because i'm going to tear it open tomorrow to look inside. tractor needs A LOT of work. and i was debating just using it for parts but what do you guys think should i restore it or part it out. i would like to start working on a racing mower and a mudding mower. let me know what you guys think i should do. Ill post pictures tomorrow.
Id hate seeing this going to pieces, but this doesnt HAVE to be done now. what id do, is take it apart, label everything you're gunna keep, and bag it up and store it, push it to the side if you're thinking about a racing or mudding tractor. | |
| Subject: Re: 72 cub cadet July 17th 2014, 7:00 am | |
| ok yeah thats probably what i'm going to do for now | |
| 72 cub cadet | |
