| Toro Racing/Wheelie machine | |
+3LAWN MOWER MUDDER redlinemotorsportts Craftsman1998 7 posters |
Craftsman1998 Core Member
Age : 25 Join date : 2013-10-30 Points : 4796 Posts : 1068 Location : New jersey
Age : 26 Join date : 2013-03-18 Points : 7125 Posts : 3129 Location : raleigh nc
 | Subject: Re: Toro Racing/Wheelie machine June 19th 2014, 9:33 pm | |
| You copyed my mind, if i ever got my grimy hands on a rer, then id do exatly this. put a seat on that thing and try not to kill yourself. | |
 | Subject: Re: Toro Racing/Wheelie machine June 19th 2014, 9:42 pm | |
| Im going to start coming up with ideas tomorrow for a seat while i wait for cub parts to show up. And i was driving it standing up lol im impatient and if i dont post ever again theres a good chance i killed myself on it lol | |
Age : 22 Join date : 2013-04-08 Points : 4853 Posts : 913 Location : Central Pa
 | Subject: Re: Toro Racing/Wheelie machine June 19th 2014, 9:54 pm | |
| - LAWN MOWER MUDDER wrote:
- Redneck-Lawnchair. *poke*
Legitimate reason, seat doesn't fit back on! I should do what 1puglife does and use a lawn chair as a seat lol | |
 | Subject: Re: Toro Racing/Wheelie machine June 19th 2014, 10:05 pm | |
That is what I meant.... Thanks for the idea i think i might do that i just need to buy a lawn chair | |
Age : 22 Join date : 2014-01-22 Points : 4215 Posts : 546 Location : north carolina
 | Subject: Re: Toro Racing/Wheelie machine June 20th 2014, 9:12 am | |
| - kawasaki220 wrote:
- how many gears dose the 700 have
- Over head view The engine runs to a tranny then the tranny runs to the axle. Its a 4 speed with reverse
1997 Murray Core Member
Age : 25 Join date : 2013-11-13 Points : 5090 Posts : 1311 Location : NW USA
 | Subject: Re: Toro Racing/Wheelie machine June 20th 2014, 1:11 pm | |
| Should extend the steering wheel, for better comfort. I was LOLing big times at the first sight of that. Do you also plan on locking the diff? If you do then you should add a wheelie bar! | |
 | Subject: Re: Toro Racing/Wheelie machine June 20th 2014, 5:49 pm | |
- i didnt know that, that had a live axle
Yep it has a live axle ill make a video of the setup soon | |
Mitch'sgarage Casual Member
Age : 24 Join date : 2014-03-24 Points : 3586 Posts : 46 Location : Omaha, Nebraska
 | Subject: Re: Toro Racing/Wheelie machine June 23rd 2014, 9:38 am | |
| sweet, that is going to need a wheelie bar so you can ride wheelies for blocks! Is it pulley swapped? | |
 | Subject: Re: Toro Racing/Wheelie machine June 23rd 2014, 9:44 am | |
| - Mitch'sgarage wrote:
- sweet, that is going to need a wheelie bar so you can ride wheelies for blocks! Is it pulley swapped?
i am going to pulley swap it. it isn't pulley swapped yet it needs a chain first before i pulley swap it. i want to make sure everything works right. And i'm going to make a wheelie bar i just haven't done it yet. i want to make sure it can do wheelies before i make one. | |
 | Subject: Re: Toro Racing/Wheelie machine June 23rd 2014, 9:45 am | |
| i need to measure the pulleys to see what the ratio is so i know what size pulleys to get. what sizes would be good for wheelies? | |
Moose Established Member
Age : 34 Join date : 2014-01-12 Points : 4595 Posts : 919 Location : Defiance, Ohio
 | Subject: Re: Toro Racing/Wheelie machine June 23rd 2014, 10:16 am | |
| 1:1 will give you wheelies all depends what gear you wanna do wheelies in :p but I suggest a large diameter pulley so you get really good belt grip | |
 | Subject: Re: Toro Racing/Wheelie machine June 23rd 2014, 10:32 am | |
| - Moose wrote:
- 1:1 will give you wheelies all depends what gear you wanna do wheelies in :p but I suggest a large diameter pulley so you get really good belt grip
ok thanks. if i had to guess it has a 4 on the engine and a 5 on the tranny but i'm not sure need to measure them | |
 | Subject: Re: Toro Racing/Wheelie machine June 23rd 2014, 10:53 am | |
ok thanks. if i had to guess it has a 4 on the engine and a 5 on the tranny but i'm not sure need to measure them 4" on the motor and 5" on the back would be good. I wouldn't go any bigger than that for a stock peerless 700. I would change the sprockets on the axle. What size sprocket is on the axle?? | |
 | Subject: Re: Toro Racing/Wheelie machine June 23rd 2014, 10:58 am | |
ok thanks. if i had to guess it has a 4 on the engine and a 5 on the tranny but i'm not sure need to measure them 4" on the motor and 5" on the back would be good. I wouldn't go any bigger than that for a stock peerless 700. I would change the sprockets on the axle. What size sprocket is on the axle?? I dont know what size sprocket it has how do i check do i measure it or what? | |
