| MTD off-road build (Mobile Terrain Dominator) "1" | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Mon Nov 21, 2016 7:59 pm | |
CraftsmanQuad19 DimeWeld
Age : 20 Join date : 2016-04-12 Posts : 2545 Forum Rep : 151 Location : Indiana
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Mon Nov 21, 2016 8:11 pm | |
| - @AllisKidD21 wrote:
- @TheGreenHornet wrote:
- i never thought to slightly move the magneto. thats a pretty good idea. i might try that on my oppy in the king, whenever i get it back together
Thanks! Without points there's not really any other way to mess with timing, haha. Well thats not entirely true. they make flywheel keys with timing advance built in. I'm gonna try to make the shape in letters Normal flywheel key: IIII IIII Timing advance key: _IIII IIII These are if you're looking at the small side and looking down the key like you were aiming a gun...if that makes any sense | |
Age : 22 Join date : 2016-07-10 Posts : 5103 Forum Rep : 272 Location : Ontario Canada
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Mon Nov 21, 2016 8:52 pm | |
| Oh yeah! I forgot about the key way! So instead of getting the flywheel magnet to the coil sooner, what I've done gets the coil to the magnet sooner. Sorta, haha. _______________________________________________ "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* - Allis B-110 x2, 710 & 716 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic & 1668 - Cub 106 & 124 - Ford LGT 125 & 145 - White 1650 Yard Boss | |
TheGreenHornet Screwdriver
Age : 20 Join date : 2016-04-16 Posts : 227 Forum Rep : 3 Location : Indiana
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Tue Nov 22, 2016 10:22 am | |
| Your way is the cheap and easy way to slightly advance it without getting a special flywheel key and going through all the process to get the rusty flywheel off, replace the key, and get it back on. Its a good method for me, because not only do i not have a flywheel puller, i do not have an impact or a socket that big. At home at least. I can drive about 20 minutes and have access to all the tools i want, but it takes gas, my grandpa has to be home, and i cant stay too late. besides, i dont actually have my license yet. | |
MatthewD Prybar
Age : 19 Join date : 2014-11-16 Posts : 1993 Forum Rep : 42 Location : Northern Ireland
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Tue Nov 22, 2016 1:35 pm | |
| Back in my go karting days, we used to file a little bit off the flywheel key to increase the timing. It does work but weakens the key a tad. | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Tue Nov 22, 2016 3:42 pm | |
| Yeah plus I'd think that would leave a bit of flywheel play,but it probably would work. And yeah GreenHornet, this way is free, and I'm all for that! Hahaha, all you need is a vise, a file, and some patience! _______________________________________________ "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* - Allis B-110 x2, 710 & 716 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic & 1668 - Cub 106 & 124 - Ford LGT 125 & 145 - White 1650 Yard Boss | |
MatthewD Prybar
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Wed Nov 23, 2016 2:20 pm | |
| If that works, I'll probably do it to some of my engines. | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Wed Nov 23, 2016 6:46 pm | |
| The sides of the coil should be strong enough to take off that little amount in both directions, shouldnt it? i wouldnt think that it'd affect anything. | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Wed Nov 23, 2016 8:15 pm | |
| Oh yeah it should be fine. I didn't take too much off, just enough to let it move a couple thou'
Anyway I've cured my oil leak, so I should be good to put the 'ol girl back on the tractor pretty soon and take 'er for a spin to test out the strength of the new frame!
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Wed Nov 23, 2016 8:22 pm | |
| Did you do any porting while it was out? | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Wed Nov 23, 2016 8:28 pm | |
| I was gonna, but maybe not. I can't really port the exhaust port because my current exhaust threads in to the block and I don't want to wreck the threads. But I have a cool idea for an exhaust and I'll use a flange instead. _______________________________________________ "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* - Allis B-110 x2, 710 & 716 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic & 1668 - Cub 106 & 124 - Ford LGT 125 & 145 - White 1650 Yard Boss | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Wed Nov 23, 2016 11:07 pm | |
| you dont have to take out the threads. I usually leave the threads, just as a backup for when and if a bolt breaks off in the block and i have to resort to using the threads. i just take out the rough casting. those flatheads are casted really rough. CQ did my hh11. it was bad. he could tell you more of what he did than i could lol. but it really gives a nice boost. eyebrows too, since the valves would already be out to do porting
MatthewD Prybar
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Thu Nov 24, 2016 5:30 pm | |
| My 1000th post! Yay! Anyway, yeah, most alluminum blocks are roughly casted, especially if they are for industrial small engines built for 3600rpm and powering mowers, generators etc. | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Fri Nov 25, 2016 3:56 pm | |
| Congrats Matt, hahaha. Yeah I agree with both you guys, I've seen engines with pretty bad casting seams in the ports. But luckily both ports are perfectly smooth in this engine and the intake port is even shiny! It kinda looks like someone already polished 'er up. _______________________________________________ "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* - Allis B-110 x2, 710 & 716 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic & 1668 - Cub 106 & 124 - Ford LGT 125 & 145 - White 1650 Yard Boss | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Fri Nov 25, 2016 4:26 pm | |
Doug Administrator
Age : 25 Join date : 2012-12-24 Posts : 2951 Forum Rep : 71 Location : Lebanon County, PA
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Fri Nov 25, 2016 4:29 pm | |
- you dont have to take out the threads. I usually leave the threads, just as a backup for when and if a bolt breaks off in the block and i have to resort to using the threads.
Get super creative and do both. Weld like a ring on the pipe and a loose flange. Thread the pipe in, and tighten the flange down. Sooper secure. _______________________________________________ | |
MatthewD Prybar
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Fri Nov 25, 2016 4:57 pm | |
| Cheers man! You're pretty lucky that someone has been in that engine already, that's a good sign of a well cared engine. | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Fri Nov 25, 2016 6:53 pm | |
| Yeah it looks like it anyway. All I know is, she's already got lots of torque! I don't think I've ever heard that thing bog down, hahaha! _______________________________________________ "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* - Allis B-110 x2, 710 & 716 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic & 1668 - Cub 106 & 124 - Ford LGT 125 & 145 - White 1650 Yard Boss | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Sat Nov 26, 2016 7:10 pm | |
Last edited by AllisKidD21 on Fri Nov 10, 2017 11:43 pm; edited 1 time in total | |
MatthewD Prybar
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Sat Nov 26, 2016 7:38 pm | |
| Nice! Are you redoing your front leafs or keeping them? | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Sat Nov 26, 2016 10:41 pm | |
| - @MatthewD wrote:
- Nice! Are you redoing your front leafs or keeping them?
Thanks! Naw the leaf and seat springs are staying, this is just an improvement haha. _______________________________________________ "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* - Allis B-110 x2, 710 & 716 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic & 1668 - Cub 106 & 124 - Ford LGT 125 & 145 - White 1650 Yard Boss | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Sat Nov 26, 2016 11:17 pm | |
MatthewD Prybar
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Sun Nov 27, 2016 5:29 am | |
| Nice! That's quite a bit of flex | |
Doug Administrator
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Sun Nov 27, 2016 10:14 am | |
| Looks like it should work well enough. Do you still have the sway bar links on too or...? _______________________________________________ | |
MatthewD Prybar
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Sun Nov 27, 2016 6:40 pm | |
| I think the purpose of that ball joint rod is to allow the sway bars to be removed so you can get separate up and down wheel flex, but I could be wrong | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" Sun Nov 27, 2016 7:31 pm | |
| - Doug Fackler wrote:
- Looks like it should work well enough. Do you still have the sway bar links on too or...?
Yeah I still have the sway bar links on 'er, but the more support the better haha. That's pretty much why I added the big ball joint rod. _______________________________________________ "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* - Allis B-110 x2, 710 & 716 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic & 1668 - Cub 106 & 124 - Ford LGT 125 & 145 - White 1650 Yard Boss | |
 | Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1"  | |
