Subject: Re: Craftsman GT3000 "MUTT" May 10th 2023, 12:36 am
Pulled the old oppy out of her tonight. Hell of a step in the bore. Seeing almost .005” of wear in the bore of the cylinders at the worst points. When you spin the engine over you can hear a bunch of air sucking past the rings.
It’s a wonder I never fouled a plug
Steering looks nice in there! I can still identify some flex in the setup and I may address it in the future if the current mods don’t stop it from skipping.
I also lowballed the hell out of a fella on eBay selling a new one of these sector gears and somehow he accepted my offer, so now I’ll have a nice brand new gear as a spare
Rustbucket Garage Core Member
Join date : 2021-01-15 Points : 2144 Posts : 1150 Location : Upstate New York
Subject: Re: Craftsman GT3000 "MUTT" May 10th 2023, 8:18 am
“Tree fiddy for that!”
Age : 20 Join date : 2016-10-29 Points : 5813 Posts : 3220 Location : Lewisburg, KY
Subject: Re: Craftsman GT3000 "MUTT" May 11th 2023, 9:41 am
Maybe one day…
I borrowed a valve spring compressor and picked up some copper gasket spray yesterday. Looks like I’ll be doing some fun stuff to the ports, heads, and valves on the new oppy
Subject: Re: Craftsman GT3000 "MUTT" May 13th 2023, 2:56 am
-Back cut the valves -Used exhaust valve springs and keepers all the way around -Ported it -Lapped valves -Shaved eyebrows -Used the flywheel teeth and sharpie marks to index a roughly 6* ignition advance -Reset valve clearances -Transferred basically everything external of the block from the old engine to the new one. I didn’t actually get tins with the engine. The new engine also got the old flywheel and stator -Fixed my carb mount so the carb won’t come loose
Looks like an engine!
Found something fun in the old engine! It’s a wonder she even ran!
Subject: Re: Craftsman GT3000 "MUTT" May 13th 2023, 10:04 pm
Man those oppys always remind of vws. Boxer engine I suppose.
Age : 48 Join date : 2016-09-06 Points : 13403 Posts : 9481 Location : Oklahoma
Subject: Re: Craftsman GT3000 "MUTT" May 13th 2023, 11:57 pm
The new oppy is HOT! A mild clutch dump stands her up on end. The bighorns also grab pretty good.
Very nice, the ol' Snapper nose Craftsman is sounding sweet! I'm guessing that 1 tooth advancement was a win? Not to mention pistons that don't wobble.
Subject: Re: Craftsman GT3000 "MUTT" May 14th 2023, 2:20 am
I actually realized I could put my drag link even further to the left. It’s now on the opposite side of the steering arm than I had intended it to be on. The red arm on the far right is where I had originally mounted the drag link before these steering mods. I could have cut that part off but didn’t really see a need to
You can see how both ends of the drag link are much closer to being in line. This solves some of my problem of not being able to turn as far right as I can left, due to the leverage issues I had before from the drag link pulling from almost the center of the tractor.
Subject: Re: Craftsman GT3000 "MUTT" May 14th 2023, 11:58 pm
Bighorns really are meaty looking
Hit a new top speed today. 34mph, compared to the old 27mph.
Since I don’t have my tach mounted yet I did a little math. Assuming the tires are actually 26” like they say, I’m turning around 5500rpm. With the old top speed(old oppy) I was turning more like 4300rpm. Now, if you actually measure the rear tires, they’re more like 25”, which puts the rpm up to 5700
Subject: Re: Craftsman GT3000 "MUTT" May 16th 2023, 11:27 pm
I think I remember the part you’re talking about but if it’s that then it was thrown out either when I put in the snapper steering or when I went to the flat dash. It’s the support bushing that’s under the dash lol
Took hood off so I could paint the nose cone. For future reference, majic tractor paint SUCKS But hey, the rest of the hood doesn’t look much better
I also got new idler pulleys in the mail for both the clutch and winch clutch, and I think my oil filter relocate kit should be here tomorrow. Oh yeah, and one little belt keeper solved my clutch issue.
Subject: Re: Craftsman GT3000 "MUTT" May 16th 2023, 11:42 pm
Different part. Mine doesn't have that. Isn't majic oil based? If I remember it takes a "couple days" to dry and nearly a week to dry fully. When it does, it's pretty tough!
Subject: Re: Craftsman GT3000 "MUTT" May 17th 2023, 10:37 am
I sprayed majic with hardener on my horizontal milling machine. It sprayed like crap but boy is it some tough paint. I dunno what kind of paint it is. Was the only can of MF red I could find, the other red I used on the steering was a bit too bright but good enough considering it wasn’t close to the other red of the hood.
