 Craftsman GT3000 "MUTT"
Adventurewagen
Rustbucket Garage
Budget_gokart
Dr Bob
mh434
BlakeGroce
Hillbilly Offroading
mowerjunkie03
26 posters
Go to page : Previous  1 ... 11 ... 18, 19, 20  Next
Craftsman GT3000 "MUTT" - Page 19 Empty
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeMon Oct 23, 2023 9:53 am
Nice carnage. Just shows you were riding hard and having fun. Rack and Pinion will be nice. I don't think I can turn as sharp with mine. I have my geometry as close to the spindle as I can too. You going to use it as a push pull to the bell crank or across the axle?
BairleaFarm
BairleaFarm
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeMon Oct 23, 2023 10:26 am
Watched it last night.   You guys are closeish so I follow giverthebeans but some of it is too hardcore for me with some physical limitations i have.   Still enjoy it.
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeMon Oct 23, 2023 10:30 am
Don't worry, I'm sure there are bypasses on some stuff, they like to video the more hardcore stuff cuz it's cool to watch!
Craftsman GT3000 "MUTT" - Page 19 Sig112PROJECTS:
Craftsman GT3000 "MUTT" - Page 19 Sig212Craftsman GT3000 "MUTT" - Page 19 Sig312
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeMon Oct 23, 2023 11:50 am
A lot of the stuff is just trails and creek bed riding. All the super crazy stuff we do is optional. If you don’t feel good about something we’ll even spot you, we’ll line a whole hill with spotters. If you have a pulley swap and a reliable rig that doesn’t drop belts you’ll keep up no problem at all. We’ve had stock speed guys come out too, we don’t mind them so long as they tell us ahead of time.
BairleaFarm
BairleaFarm
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeMon Oct 23, 2023 12:30 pm
BYOTR for the stock guys? Bring your own tow rope? cheers
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeWed Oct 25, 2023 3:29 pm
Didn't see this message before. The rack and pinion will be as close to the left side of the frame as possible, just pushing a plain old drag link. I have universals to route the (new) steering shaft to it. From what I can see with my tape measuring, the rack should have enough travel
Tow rope and a good front and rear tow point is much appreciated! Remember, you might be fishing around in mud and water to hook your rope, so it's wise to make it easy to find lol!
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeThu Oct 26, 2023 11:51 pm
Fun fact, these club car racks seem to be designed for 7/16 or 12mm bolts. Or at least this one was, haha.
Craftsman GT3000 "MUTT" - Page 19 09596c10
Here is the rear mount. Pretty simple, one bolt through the frame and one through the rack.
Craftsman GT3000 "MUTT" - Page 19 0d5fc010
The forward mounting of the rack has two holes and one of them doesn’t land on the frame. The little bolted on plate will work for both front mount holes as it extends below the frame a bit. The rear mount was enough to position and hold the rack so I could transfer hole locations from the rack to the little plate.
Craftsman GT3000 "MUTT" - Page 19 8a6f2310
Picked up the transferred holes and tapped them 8mm (not a metric guy but it’s just hardware on hand). Two more little standoffs, tapped 1/2-13 on one end and and 8mm on the other. They are joined to the plate for now by an 8mm set screw-the set screw positions the little standoffs for welding and will hopefully prevent them from pulling out of line when I weld them.
Craftsman GT3000 "MUTT" - Page 19 E23de710
This is pretty much the final position of the rack.
Craftsman GT3000 "MUTT" - Page 19 16dd1c10
I cut up and tapped the end of the old drag link just to get an idea of how things are going to work. I definitely need some more aggressive bends to clear the tie rod.
Craftsman GT3000 "MUTT" - Page 19 8d52e310
Bonus pic showing my wacky setup to drill and tap the end of the old drag link. Too tall for the mill and too bent for the lathe spindle. I stuck it in a boring bar holder and just put a drill in the lathe chuck. Worked great.
Craftsman GT3000 "MUTT" - Page 19 B30b2210
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeFri Oct 27, 2023 10:28 pm
Not much done today. I had to enlarge the hole in the dash to fit a flange bearing, so I used a holesaw the size of the first hole as a pilot for the larger holesaw. This arbor has room to screw two saws on, some don’t though unfortunately.
Craftsman GT3000 "MUTT" - Page 19 63de9b10
From here I just had to drill the bolt holes for the bearing. This all wound up being pretty easy, I was worried I’d have to pull the dash off to cut it.
Craftsman GT3000 "MUTT" - Page 19 03f80b10
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeFri Oct 27, 2023 11:53 pm
Very nice again.  MUTT is going to become a beefier tank once you are done!
PizzaKitty26
PizzaKitty26
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeSat Oct 28, 2023 6:14 am
Wow! That is a strong steering bushing, got to tell you! That'll out last the tractor.
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeSat Oct 28, 2023 7:53 am
If you ever get a chance to weigh this beast I'm really curious where it's at! With all the upgrades and reinforcements it's got to be around 700lbs I'd think
My All Terrain Tractors:
- The "Silver Bullet" ~ 1984 Sears Craftsman LT(V)11 (MTD Built) (*Lanquishing*)
- 1973 Massey Ferguson MF12 ~ (Work in Progress)
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeSat Oct 28, 2023 6:06 pm
She’s definitely not 700, I’ve seen some 700lb wheel horses and Sears and mutt is definitely not that. She’s definitely below 650.
And that’s only the upper steering bearing, there will be another one bellow it.
MightyRaze and PizzaKitty26 like this post
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeWed Nov 01, 2023 8:47 am
Splined the end of the steering shaft at work. Could have done it at home but I didn’t have the indexer plate for it.
Craftsman GT3000 "MUTT" - Page 19 1a3f1310
Intermediate shaft made up
Craftsman GT3000 "MUTT" - Page 19 27bd2410
Here you can see the lower bearing and everything all together.
Craftsman GT3000 "MUTT" - Page 19 Cf3b2310
Drag link.
Craftsman GT3000 "MUTT" - Page 19 759c0a10
I got her running last night, think the float was stuck up was why she wouldn’t run. Working on an engine cage now.
Craftsman GT3000 "MUTT" - Page 19 430ee610
Brianator and PizzaKitty26 like this post
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeWed Nov 01, 2023 10:35 am
You have another snapper hood lying around for that Craftsman?  Nice.  Interested in your engine cage.
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeWed Nov 01, 2023 11:13 am
I have two spares, this one with glass headlights and one with (missing) plastic headlights. I’m gonna use this glass headlight grille with the old hood, I just needed something straight to build the cage to.
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeThu Nov 02, 2023 12:17 am
I hate warped weldements so much that I set up my material on a mill table and clamp it down lol.
Craftsman GT3000 "MUTT" - Page 19 4087d510
About how it sits in the hood.
Craftsman GT3000 "MUTT" - Page 19 B4620a10
Here’s what it looks like sans hood and grille.
Craftsman GT3000 "MUTT" - Page 19 752f9210
Hood and grille mounted. You can actually go without either the grille or hood, everything kind of mounts independently to the cage now.
Craftsman GT3000 "MUTT" - Page 19 A3ecd410
So now to be ready for GER I guess I just have to stick the headlights in and get my belt system working right.
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeMon Nov 06, 2023 8:04 pm
Aye! Love to see what happened in that doc locker! GER FB footage.
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeTue Nov 07, 2023 9:34 am
Well sadly (or not lol) I didn’t get to try the engine cage out at GER…she stayed pretty horizontal besides one time where she got sleepy and layed over Craftsman GT3000 "MUTT" - Page 19 2664539216
She was performing flawlessly until I was trying to pop the front wheels over a rock in cripple creek…one minute the left rear was spinning, then a little pop, and then I was one wheel peel. Oops! I guess I twisted off the left side of the straight axle. I wasn’t really doing anything crazy at the moment, but definitely had been hopping the front end all weekend with some serious clutch work lol!
Rode the GT6k the rest of the weekend, but here’s some shots from when mutt was still in action.
Craftsman GT3000 "MUTT" - Page 19 8417e010
Craftsman GT3000 "MUTT" - Page 19 2eace910
Craftsman GT3000 "MUTT" - Page 19 E21e8310
This was right where I twisted off the axle, had to winch up out of the creek.
Craftsman GT3000 "MUTT" - Page 19 490e1710
Craftsman GT3000 "MUTT" - Page 19 C6996d10
Craftsman GT3000 "MUTT" - Page 19 1a17a810
Bighorns love rocks! Even big flat ones with nothing to grip on!
Craftsman GT3000 "MUTT" - Page 19 0f5d9c10
She’s hiding in the back there
Craftsman GT3000 "MUTT" - Page 19 F0d2a110
So, turns out that piece of stainless keyed shaft just wasn’t up to snuff for an axle. Think I’ll get a piece of 4140 pre hardened stock to cut keyways in and make a new axle. Lots of engineering coming up!
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeFri Nov 10, 2023 2:31 pm
Dang that's some hard riding! The thought to try and go over some of the stuff you all do wouldn't even cross my mind if I came across that kind of stuff when I'm riding lol. Of course, I don't have anything quite capable enough for that yet.
I'll be waiting to see that transaxle carnage too! I just dealt with a similar issue with Alfredo.
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeThu Nov 30, 2023 9:50 am
So here’s the diff assembly that came out of the 820 in mutt. It already had chopped axles so I chopped them some more for free material lol. I think the diff carrier currently in mutt is from the original 820? Eh, oh well lol.
Craftsman GT3000 "MUTT" - Page 19 21934210
Whole assembly is 4” overall length…this means my locker hub needs to be 4” long
Craftsman GT3000 "MUTT" - Page 19 7b349110
Little bit of measuring later…
Craftsman GT3000 "MUTT" - Page 19 79822210
MightyRaze, Brianator and Hammernco like this post
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeThu Nov 30, 2023 9:54 am
Oh.... nice!
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeThu Nov 30, 2023 10:57 am
Meant to put this with the last post but ran out of time. Here’s the locker hub itself.
Craftsman GT3000 "MUTT" - Page 19 9a2a1910
I will have to start a thread on the subject with all the technical details.
Craftsman GT3000 "MUTT" - Page 19 21032910
Hammernco likes this post
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeThu Nov 30, 2023 11:27 am
That's a sweet design man, get er done and it could be added to the list of different ways to lock diffs thread too!
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeThu Nov 30, 2023 1:48 pm
I didn’t even know there was a thread for that, haha. Someone would need a pretty good machine shop to lock a diff like this. I can make them to sell as well, but I’m kind of the only market for something like that, almost nobody putting an 820 through this much abuse. I’m making the big keys and side plates from scratch as well as the center hubs. Well, I may reuse the side plates but bore them up, I’ll have to look them over.
I picked up material for an axle, 1” 4140 prehard TGP (turned, ground, and polished). Im not sure if it will hold up, may be a bit too hard. We shall see. The locker should at least be pretty bulletproof. Will be using some kind of tougher steel for the hub key too.
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeYesterday at 1:38 am
First side done on the hub
Craftsman GT3000 "MUTT" - Page 19 263ecf10
Second side just before finish turning
Craftsman GT3000 "MUTT" - Page 19 1edef010
Shiny. The bore is still .003” under, I bored it half from either side so I didn’t have to fight with chatter on a long bore(like I did on the hubs), I will take it to work and hone it up to size before I cut the 1/4” keyway in it.
Craftsman GT3000 "MUTT" - Page 19 63a54210
Had to true up this boss on the side plates before I could chuck on the boss to indicate the step in the side plates true so I can true up the OD of the plates so I can chuck on the OD to cut the bore of the plate *gasps for air*
Craftsman GT3000 "MUTT" - Page 19 B56aed10
One side plate done. It’s bedtime for now, I’m not quite the young whippersnapper I was in 2017 posting the nights work at 4am lol!
Craftsman GT3000 "MUTT" - Page 19 B37ea110
Hammernco
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 19 Icon_minitimeToday at 2:38 am
Shiny. The bore is still .003” under, I bored it half from either side so I didn’t have to fight with chatter on a long bore(like I did on the hubs), I will take it to wor and hone it up to size before I cut the 1/4” keyway in it.
One side plate done. It’s bedtime for now, I’m not quite the young whippersnapper I was in 2017 posting the nights work atCraftsman GT3000 "MUTT" - Page 19 B37ea110
Boy! excellent machine work and Idea, should be stout enough for sum good romping!!!
Wonder what will break next?
Gears? Guess will discover soon enough ! LOL
Page 19 of 20Go to page : Previous  1 ... 11 ... 18, 19, 20  Next
» Craftsman GT3000 "MUTT"
» mtd craftsman mutt
» Craftsman GT6K
» 1990's Craftsman GT3000 utility mower.
» My first build 2003 craftsman gt3000 23hp v-twin
