Welcome to the All Terrain Lawn Tractor Forum! . . .
2020 Build-off Started, Look for entry instructions HERE! . . .
New Top Tractor Challenge and Build-Off Profile Buttons on the menu bar! . . .
2019 Build-Off Winners . . . 1-AllisKidD21 . . . 2-Offroad Mudmowers . . . 3-MightyRaze . . . Close vote, all were winners!
 98 craftsman lt1000 rally mower/speed build
Go to page : 1, 2, 3, 4, 5, 6  Next
yeethaw
yeethaw
Forum Rep : 8
98 craftsman lt1000 rally mower/speed build Empty
PostSubject: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeTue Aug 13, 2019 10:38 pm
well after lurking for a year or so i finally decided to get a tractor and start a build thread so this is my 98 craftsman that is practically rust free it has a 19.5 hp briggs oppy on it. i got the tractor for $100 after searching for months and missing multiple opportunities for tractors. i plan to make this an all around trail rig that can still handle some mud so my plans for this tractor are as follows
things that need to be fixed
loose steering
gash in the front tire
planned modifications
smaller pulley on the back for a 1:1 ratio
cut the turfs to use till i can afford atv tires
https://www.amazon.com/20x10-8-20x10x8-Replacement-Tubeless-A003/dp/B06XCHLRVM?th=1 these tires on the back
paint rims black
front snowblower tires
brake lever foot throttle
remove extra deck bits
better headlights
improve the braking somehow
https://images-na.ssl-images-amazon.com/images/I/91SSiq3PmiS._SX355_.jpg and then ive got one of these id like to put on the back of it
front bumper
upgrade transaxle to an oil filled and doc locked peerless 930
so those are my plans feel free to give advice and criticism on my build plans
98 craftsman lt1000 rally mower/speed build 20190810
98 craftsman lt1000 rally mower/speed build 20190811
98 craftsman lt1000 rally mower/speed build 20190812
Last edited by yeethaw on Mon Dec 16, 2019 6:20 pm; edited 4 times in total (Reason for editing : clearing it up and adding some stuff i forgot)
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeTue Aug 13, 2019 10:47 pm
98 craftsman lt1000 rally mower/speed build 20190814
98 craftsman lt1000 rally mower/speed build 20190816
98 craftsman lt1000 rally mower/speed build 20190815
^it next to the mtd which has all sorts of issues
Master
Master
Forum Rep : 54
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeWed Aug 14, 2019 11:43 am
Haha, I see someone really wanted a Ford eh, lol!
Sounds like a fairly simple build. You'll definitely need a brush guard with that plastic hood even though it's already broken. Can't wait to see where you go with it!
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeWed Aug 14, 2019 12:56 pm
yep i plan on making one but ill need to make it so the hood and grill can still pivot forward
Forum Rep : 98
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeWed Aug 14, 2019 1:06 pm
sounds like a good plan, I would swap a cast iron front axle from another craftsman, those stamped axles fail constantly....
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeWed Aug 14, 2019 1:12 pm
which tractors can i find those in?
mowerjunkie03
mowerjunkie03
Forum Rep : 19
PostSubject: Re: 98 craftsman trail rig build   98 craftsman lt1000 rally mower/speed build Icon_minitimeWed Aug 14, 2019 1:47 pm
Any newer Craftsman or Husky LT and Craftsman GT are pretty common and those will swap right in. In my experience the stamped axles will serve you well as long as you don't plan on running overly large tires. Not all ofthem but the AYP ones are good.
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeWed Aug 14, 2019 2:30 pm
would the front axle from that mtd be any better i have that for parts
Master
Master
Forum Rep : 54
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeWed Aug 14, 2019 3:35 pm
Nope. MTD axles are worse. They'll all tell you Murray axles are the worst of all but they're really not. But I wouldn't put another brand axle in it. You could find a cast iron one in a GT6000. I actually have a spare one that I haven't found a use for yet.
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeWed Aug 14, 2019 4:23 pm
alright thank you im thinking of picking up a gt6000 to use for parts
Forum Rep : 98
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeThu Aug 15, 2019 11:25 am
Its the tack welds where you grease the spindle bushings are not fully welded. I have got a few of them where people complained the tire would turn and hit the body because the spindle wallows out the hole & this is just from regular mowing.  They are the Dana 35 of tractors if anyone gets the reference.
I beat on mine regularly & was replacing the axle 1 time a year so I just got the cast iron one from a DYT(red craftsman model).  The green GTs have them or you can get them online for 50-60 bucks.
Forum Rep : 76
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeFri Aug 16, 2019 12:25 am
I mean, I'd keep the steel axle, I've got steel axles in 2 craftsman style tractors I own, and they're really not bad. They aren't be best, but they aren't bad. Cast iron axles, I've just seen several break and then you're screwed. I'd stick with steel.
Master
Master
Forum Rep : 54
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeFri Aug 16, 2019 9:52 am
Yes, I've seen several break too, but let me say this, I'd have cast iron over that piece of junk any day of the week. Not that they're weak, but the amount back and forth play is ridiculous, not to mention dangerous and hard on the machine. Even when just mowing, it's super annoying... It adds play in your steering, and like mrshaft said, they wear out and the tire starts grabbing the hood. That why if I had an AYP mud mower, it'd have a cast iron axle for sure. Takes the play out of every thing. The Craps-man has 90 degree play in it's steering, the Husqvarna has none, and the JD wouldn't if it had wheel bearings. Out of those 3 the Husky and JD have cast iron axle and the Craps-man the steel one.
Not that I'm against other people using steel, but the cast iron ones are really just better all the way around.
Just my two cents...
Forum Rep : 76
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeFri Aug 16, 2019 10:11 am
Well, I mean, I've got cast axles in both my 990 and my 110, to be honest, I'd like to swap my 110s axle out for steel, because I don't trust it that much. My 990 I'm fine with because it doesn't do a lot of bashing, and I want the front end of it to weigh as much as possible (lol).
Master
Master
Forum Rep : 54
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeFri Aug 16, 2019 10:20 am
I have no problem with steel. I just don't AYP's steel axle. AYP steel axles are trash in my opinion. I don't deal much with tractors from your JD's time era so I'm no help in which is better there. Everyone has their opinion, I like my Murray's stamped axle to be honest. I think they're great. Everyone else doesn't seem to think so but in my opinion they are.
Anyway, if we're specifically talking about his 98 LT1000 and nothing else, I'd definitely swap cast iron axle in it.
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeFri Aug 16, 2019 11:48 am
hm is there anything else i could do to get rid of the slack in the steering it seems like its in the gears
Master
Master
Forum Rep : 54
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeFri Aug 16, 2019 12:38 pm
Well yes, the gears are probably the main cause, but the axle just adds to it. The main reason for replacing the axle is not the play, it's because they're really just junk.
Now if your gears are set up the way I think they are, than you may want to replace the entire steering setup. Can you get a picture of your steering setup?
Forum Rep : 76
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeFri Aug 16, 2019 2:02 pm
Yeah, so he's got a flathead, and it's a 98, so it's before they redid the LT1000s, so it should have gen 1 steering. I can confirm it sucks. LOL. But I'm pretty sure you can change bushings and tighten it up a hair.
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeFri Aug 16, 2019 2:19 pm
ill just roll with my current steering and do what i can to tighten it up
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeFri Aug 16, 2019 4:27 pm
took the it down the road last night about a half a mile to ride in some shallow mud only got stuck once surprisingly but after the drive there i realize how much i need a pulley swap on this thing anyways heres a slightly muddy pic of it98 craftsman lt1000 rally mower/speed build 20190817
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeFri Aug 16, 2019 4:40 pm
also got a video of it running excuse the crappy mic
https://youtu.be/eMhVb9_6zxU
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeMon Sep 16, 2019 9:02 pm
98 craftsman lt1000 rally mower/speed build 20190912
finally got a rack built up for the back of this thing used stuff laying around and some bolts still need to make braces running down to the frame but for now its not that big of a deal as the most itll carry is 50lbs
98 craftsman lt1000 rally mower/speed build 20190910
another picture from the front
98 craftsman lt1000 rally mower/speed build 20190911
then this happened to me in the middle of a field and it was on my main drive side so i had to push it home98 craftsman lt1000 rally mower/speed build 20190913
also decided to make a hood hold down since it was bouncing around like crazy
[url=https://servimg.com/view/20075183/13]98 craftsman lt1000 rally mower/speed build 20190914[/uraa
a few days ago i discovered that this thing was leaking oil around the dipstick tube any ideas of where it could be coming from and how i can fix it for the most part it seems like its on the side of the engine not the ground at all
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeMon Sep 16, 2019 9:11 pm
98 craftsman lt1000 rally mower/speed build 20190915[/url]
also dont think im gonna do the atv box as it just looks bulky as can be on this little tractor
Forum Rep : 134
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeMon Sep 16, 2019 9:15 pm
Oil leak is probably the seal around the dipstick tube. Pretty easy fix. That atv box is pretty neat too, but i agree it’s a bit big for the tractor. Maybe on a craftsman GT or something
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build Icon_minitimeMon Sep 16, 2019 9:36 pm
any clue on how i could fix the dipstick seal?
Page 1 of 6Go to page : 1, 2, 3, 4, 5, 6  Next
