Welcome to the All Terrain Lawn Tractor Forum! . . .
2020 Build-off Started, Look for entry instructions HERE! . . .
New Top Tractor Challenge and Build-Off Profile Buttons on the menu bar! . . .
2019 Build-Off Winners . . . 1-AllisKidD21 . . . 2-Offroad Mudmowers . . . 3-MightyRaze . . . Close vote, all were winners!
 98 craftsman lt1000 rally mower/speed build
Go to page : Previous  1, 2, 3, 4, 5
loggers gogert
98 craftsman lt1000 rally mower/speed build - Page 5 Empty
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeSat Mar 07, 2020 4:00 pm
nooooooooooooooooooooooooooooo...............
i ACTUALLY feel bad for you.......
hopefully you figure out what happened
Master
Master
Forum Rep : 47
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeSat Mar 07, 2020 4:09 pm
Don't worry bud... You ain't the only one with a failing MST. Sucks.
yeethaw
yeethaw
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeSat Mar 07, 2020 4:10 pm
I’m guessing something got in there and got stuck between the bull gear and the case then made its way to freedom by breaking through it
yeethaw
yeethaw
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeSun Mar 15, 2020 9:23 pm
98 craftsman lt1000 rally mower/speed build - Page 5 79196010
98 craftsman lt1000 rally mower/speed build - Page 5 841f7d10
Well I tore it apart today and found out that the bolt head that held my extra spider gears in place came loose and jammed up between the case and the bull gear. I didn’t look very much yet to find where the metal shavings came from but I’m wondering if I should retry this method or if I should attempt a limited slip differential using this big spring I have laying around that just so happens to fit perfectly. Can anyone gimme advice on wether or not to do the limited slip
loggers gogert
loggers gogert
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeSun Mar 15, 2020 9:41 pm
you said this will be a drift mower right?
yeethaw
yeethaw
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeSun Mar 15, 2020 9:55 pm
Eh prolly not now I’m guessing it’s just gonna be a trail machine
loggers gogert
loggers gogert
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeSun Mar 15, 2020 10:10 pm
alrigh.............wich one?
but besides that, if its a trail machine, some of the people on here run limited slip, but the people who run limited slip usually have STUPID good tires, but for YOU,
id recomend a locked diff, un less you can find some really aggresive tires
Forum Rep : 254
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeSun Mar 15, 2020 10:35 pm
I don't think any of us run a limited slip differential because the transaxles we run don't have that feature.
I like your idea with the spring though! Maybe add a washer on each end too? I think I would give it a try and see how it performs, not like it'll really hurt anything.
       - Toro Rat Rod Tractor Build
       - Allis B-110, 710 & 716 - Wheel Horse 655 & 953 - Case 444 - Bolens Versamatic - Cub Cadet 106 - Ford LGT 125 -
yeethaw
yeethaw
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeSun Mar 15, 2020 10:37 pm
i don’t think I’m able to run a washer since it would hang over the edge of the bull gear and catch on the case so it’ll just be pushing directly on the gears
Forum Rep : 254
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeSun Mar 15, 2020 10:42 pm
If you found one with the same O.D. as the spring it would probably work, but I imagine running without washers would still be fine.
loggers gogert
loggers gogert
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeSun Mar 15, 2020 11:15 pm
@AllisKidD21, i meant to say one person runs limited, wich is craftsmanquead i believe, i remeber him telling me he did....
yeethaw
yeethaw
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeMon Mar 16, 2020 6:16 pm
Ahh okay I’ll look into that
Forum Rep : 100
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeMon Mar 16, 2020 6:24 pm
If i were you I'd take a welder and turn all of those spider gears into one solid block. That's just me though.
yeethaw
yeethaw
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeTue Mar 17, 2020 6:57 pm
I don’t have a welder in easy access but I was thinking if I could do that and also weld the original two to the shaft so it’d be locked in multiple ways and hopefully unbreakable but I’m still thinking imma try the limited slip first
yeethaw
yeethaw
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeWed Mar 18, 2020 8:17 pm
So I got the posi setup then found out it wasn’t gonna work since the end of the halfshafts hit on the spring. Since this won’t work I’m gonna end up having my dad weld the 4 spider gears together and also weld the original spiders to the pin so hopefully it’ll be indestructible. Also there’s a gouge in the side of the case from when it blew, will this present a problem even though nothing is against it? Or will I be good just jb welding the hole
Forum Rep : 100
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeWed Mar 18, 2020 8:51 pm
Grind out any sharp corners of the hole to prevent cracks from forming and clean it really well before you jb weld it. It will probably be ok for a while.
Make sure he tacks it all around before turning the thing really solid. Tack it, spin it to make sure it's true, tack it, spin it, tack it, etc. Do that until you feel it won't warp when you weld it fully. If the axle shafts are out of alignment they will blow the case up.
yeethaw
yeethaw
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeFri Mar 20, 2020 6:10 pm
98 craftsman lt1000 rally mower/speed build - Page 5 07346e10
Is it possible to shorten this shaft or to replace it with a shorter one so that it won’t be in the way of the belt
Master
Master
Forum Rep : 47
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeFri Mar 20, 2020 6:17 pm
Yes. If it was flush with the case, would that work?
yeethaw
yeethaw
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeFri Mar 20, 2020 6:50 pm
Yes thats how the spicer was
Master
Master
Forum Rep : 47
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeFri Mar 20, 2020 8:13 pm
Well, I did have one, but I just used it on my BO project. You might be able to find a short MST shifter on Ebay.
Forum Rep : 100
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeFri Mar 20, 2020 8:42 pm
I cut the one on my 820 down. Just cut it, grind the square profile on the end with an angle grinder, then drill and tap a ¼-28 hole on the end for the original bolt. Only problem i had with it is because i ground the square a bit too small and had to weld it back up and grind it again to get the slop out.
yeethaw
yeethaw
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeWed Mar 25, 2020 2:00 pm
So I jb welded the case up and got smoother out surprisingly well, I left the extra jb on the outside of the case so that hopefully it will provide some support so this won’t happen for a while98 craftsman lt1000 rally mower/speed build - Page 5 F7316610
98 craftsman lt1000 rally mower/speed build - Page 5 48661810
Forum Rep : 100
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeThu Mar 26, 2020 10:38 am
Looks good. We'll see how it lasts i guess.
loggers gogert
loggers gogert
Forum Rep : 6
PostSubject: Re: 98 craftsman lt1000 rally mower/speed build   98 craftsman lt1000 rally mower/speed build - Page 5 Icon_minitimeThu Mar 26, 2020 10:49 am
jb weld.......grade A engineering..........
Page 5 of 5Go to page : Previous  1, 2, 3, 4, 5
