Welcome to the All Terrain Lawn Tractor Forum! . . .
2020 Build-off Started, Look for entry instructions HERE! . . .
New Top Tractor Challenge and Build-Off Profile Buttons on the menu bar! . . .
2019 Build-Off Winners . . . 1-AllisKidD21 . . . 2-Offroad Mudmowers . . . 3-MightyRaze . . . Close vote, all were winners!
 [2020 Build-Off Entry] AK's Jacobsen Crawler Build!
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Empty
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeSat Apr 04, 2020 10:28 am
Yeah I don't wanna risk bringing anything out to the grandparents by hanging out there, so I've just been at home. Just taking extra precautions, haha.
Forum Rep : 496
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeSat Apr 04, 2020 1:51 pm
I don't blame ya.
Li'l RED my original modified tractor!
Forum Admin -- Chat Admin-- Facebook Page Admin
ATLTF Facebook Page --How To Upload Pictures
Forum Rep : 496
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeTue Apr 07, 2020 8:33 am
[adm]
I have put the new [-19] on your build until you are able to work on the entry again.  The [-19] gives you a pass for monthly updates until this blows over.
[/adm]
Forum Rep : 496
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeThu Jun 04, 2020 8:49 am
Any luck with the social distancing up there AK?
Forum Rep : 261
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeSun Jun 14, 2020 10:33 pm
Well I'm officially back in the competition now folks. Decided to bring my build and the neccessary supplies home and work on it as much as I can.
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200610
When I went to pick it up the left rear tire was flat, which I found was due to a leak from the bead and valve stem:
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200611
So I'll have to cure that at some point, should be an easy fix though.
The other thing I did tonight was pop the carb bowl off quick because when I had this engine running it was obvious that it has some junk in the carb:
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200612
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200613
Pretty good, haha. But I got it all cleaned up nice and put back together, so I'll see how she runs tomorrow.
Glad to be back building again!!
       - Toro Rat Rod Tractor Build
       - Allis B-110, 710 & 716 - Wheel Horse 655 & 953 - Case 444 - Bolens Versamatic & 1668 - Cub 106 - Ford LGT 125 -
Forum Rep : 496
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeSun Jun 14, 2020 11:17 pm
Welcome back to the build-off!
Forum Rep : 261
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeMon Jun 15, 2020 6:26 am
Thanks Mighty!
Forum Rep : 261
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeWed Jun 17, 2020 6:38 am
Well I tried the ol' Magnum out last night and she runs pretty good now!
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200614
Pretty loud with the exhaust coming straight out of the block as you can imagine. lol!
Also I plan on making a new dash out of steel, so I removed the busted up plastic panel:
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200615
There's a lot to work with there, so it shouldn't be too hard to make something up.
Forum Rep : 261
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeSat Jun 20, 2020 8:49 am
I did a little more tinkering the other day and got the leaking tire fixed up:
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200616
Good to go! Just had to clean up the beads and the rim, and put a new valve in.
Next thing I did was tackle the throttle pedal, which actually went pretty well. Didn't take any pictures along the way but here's what I came up with:
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200617
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200618
It's the PTO engagement lever from a little Ford LT-75 that I bent up and welded a bushing on to the opposite end. Pivots on a 3/8" bolt which should be strong enough, but I'd like to do a little bracing in a couple spots at some point.
Works good though! I just jooked the cable right to the factort governor likage:
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200619
Glad to have that done!
Forum Rep : 117
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeMon Jun 22, 2020 3:54 pm
Looking good. Pretty cool throttle setup.
Forum Rep : 261
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeWed Jul 01, 2020 4:14 pm
Thanks mr.mod!
Well I originally planned to use a gear box of some sort for the steering on this build, but unfortunately I haven't been able to find anything to use. So for the sake of getting it moving, I decided to utilize the stock steering gears with the setup I had planned.
So here's what I started with;
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200620
A 7/8" bore pulley with two bushings pressed in, and a little bell crank I made. The idea was to use the pulley as a pivot point mounted to the wishbone, so I cut it close to the middle so it could be welded on:
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200710
I used the original drag link, but had to make some cuts and bends to get it down lower to where the bellcrank was:
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200711
Pretty close, but it clears everything. Here's the bell crank mount tacked to the axle:
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200712
Still needs to be welded fully and braced up, but it's in place.
The last thing I had to do was add a little extension to the left steering arm, and that's where the link coming from the bellcrank attaches to.
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200621
And now, we have steering!
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200713
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200714
It's not super sharp turning, but it still looks to be enough so I think it should be fine. It's not low ratio like I wanted, but if I ever find a nice steering box to use I should be able to swap it in place of the stock setup and retain everything else. Either way I'm glad to have some steering!
Last thing I did today was weld up a transaxle pulley, used a deck drive pulley and a hub with a keyed 5/8" bore.
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200715
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200716
Worked good! Let me know what ya think!
Forum Rep : 496
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeWed Jul 01, 2020 5:22 pm
Looks like it turns plenty sharp!  Coming along great AK.  How much pulley reduction did you have on the trans?
Forum Rep : 496
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeWed Jul 01, 2020 6:09 pm
OH, happy Canada Day!
Forum Rep : 116
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeWed Jul 01, 2020 8:07 pm
Definitely turns sharp enough for a crawler. Gonna build a crawling course to test this thing out on? Wink
Forum Rep : 261
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeWed Jul 01, 2020 10:01 pm
Thanks fellas! I can't remember what size pulley this trans originally had, this one is smaller but not sure how much.
Haha, a nice crawling trail course would be a cool idea, be good for the final video!
BlakeGroce
BlakeGroce
Forum Rep : 21
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeThu Jul 02, 2020 12:39 am
Yes definitely need some sort of rock crawling video......on a side note am I the only one who kinda wants to see someone take a rock crawler/bouncer up Mt. Rushmore?
Alright! If Allis can get 100,000 likes on this video he will take it up Mt. Rushmore
Forum Rep : 261
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeThu Jul 02, 2020 6:28 am
Hahaha, now there's an idea.
Forum Rep : 261
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeTue Jul 28, 2020 9:26 am
Quick update here, I got the engine pulley I wanted to use mounted up, along with the factory belt guides.
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200732
The belt setup should be pretty straight forward, except for the belt wanting to rub on the shifter due to the smaller transaxle pulley. I figured all I needed was a small V-idler to pull it the one way a bit. It should bolt to this original crossmember:
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200731
Once I find one small enough it should bolt in that hole and work fine.
The other thing I did was finally make mounts for the fuel tank and battery. Pretty simple, just an adjustable bracket up top for the tank to lean against, and an old tarp strap with a couple spots to hook it welded on. For the battery I just used an actual lawn tractor hold down and made it work:
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200733
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 20200734
Pretty lame update I know, haha, but I figured it was better than nothing. Smile
Forum Rep : 496
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Crawler Build!   [2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 Icon_minitimeTue Jul 28, 2020 2:03 pm
[adm]
No update is lame.
[2020 Build-Off Entry] AK's Jacobsen Crawler Build! - Page 3 110
[/adm]
