| [Withdrawn][2020 Build-Off Entry] Bear's beast | |
Bearsgarage Member
| Subject: [Withdrawn][2020 Build-Off Entry] Bear's beast February 10th 2020, 8:50 pm | |
| This is a 67 ford 100 made by Jacobsen. It is going to be a trail rig on 27 or 28 inch rear tires with a locked transaxle. It will have a mild built 6.5 predator hopefully will make about 10 hp. Approved MightyRaze Feb 10, 2020 | |
Age : 48 Join date : 2016-09-06 Points : 14921 Posts : 10540 Location : Oklahoma
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2606 Posts : 582 Location : Reeses Mill, WV
Bearsgarage Member
Age : 25 Join date : 2016-07-10 Points : 8340 Posts : 5190 Location : Ontario Canada
| Subject: Re: [Withdrawn][2020 Build-Off Entry] Bear's beast February 11th 2020, 9:44 am | |
| Yeah should be a Peerless 2300 with left hand input.
Nice entry, those old Ford's are cool tractors. Looking forward to seeing this one! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Bearsgarage Member
| Subject: Re: [Withdrawn][2020 Build-Off Entry] Bear's beast February 11th 2020, 6:22 pm | |
| That's the reverser gearbox to get the shaft turning the correct direction, there's a small chance the inner shaft in seized in place if it won't budge with the bolts removed. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Bearsgarage Member
| Subject: Re: [Withdrawn][2020 Build-Off Entry] Bear's beast February 11th 2020, 6:35 pm | |
| That's what i thought it was but wasn't sure. For what i want to do i need it removed. Could i spray brake clean in then fill it with blaster or coke or something? | |
| Subject: Re: [Withdrawn][2020 Build-Off Entry] Bear's beast February 11th 2020, 7:02 pm | |
| Yeah some penetrating oil might help, also maybe see if that Welch plug in the end will come out. Just be real careful with that thing, they are really hard to come by if you accidentally break it. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Bearsgarage Member
| Subject: Re: [Withdrawn][2020 Build-Off Entry] Bear's beast February 22nd 2020, 1:13 pm | |
| So i got the reverse drive off. Whoever decided to do the stupid external clip but make it impossible to reach i hope everything they work on has them on everything. Progress is going to be slow right now trying to buy a house and dont want to move 1000s of parts. | |
Bearsgarage Member
| Subject: Re: [Withdrawn][2020 Build-Off Entry] Bear's beast April 6th 2020, 10:48 am | |
| [adm]Per Rules and guidelines: Entrants MUST update their thread at least monthly detailing progress, with either write-ups, videos and/or photos.
If you cannot work on the project right now, please let us know. [/adm] | |
Bearsgarage Member
| Subject: Re: [Withdrawn][2020 Build-Off Entry] Bear's beast April 7th 2020, 12:19 am | |
| I forgot I was even in the competition with all the chaos going on it escaped me. However I have been working during this time off I stripped the mower down to prep for paint while I'm waiting for the parts I need to come back into stock. | |
Bearsgarage Member
Bearsgarage Member
Bearsgarage Member
| Subject: Re: [Withdrawn][2020 Build-Off Entry] Bear's beast June 4th 2020, 1:08 pm | |
| As of the last month I've been trying to flip a tractor to fund a new engine for the beast. I have decided not to use the predator because I need a charging system to run the accessories i want and don't want to put one one the predator and still have it be pull start. | |
Bearsgarage Member
| Subject: Re: [Withdrawn][2020 Build-Off Entry] Bear's beast August 29th 2020, 7:48 pm | |
Bearsgarage Member
