| [DNF][2020 Build-Off Entry] Bearsgarage's Thrown Rod | |
Bearsgarage Member
| Subject: [DNF][2020 Build-Off Entry] Bearsgarage's Thrown Rod February 11th 2020, 3:48 am | |
| This is my craftsman that I will be turning into a rat rod its motor is locked up it has no wiring harness and needs body work i pulled it out of the weeds after a few years so its rough but should be fun when im finished. Approved MightyRaze Feb 11, 2020 | |
Age : 48 Join date : 2016-09-06 Points : 14921 Posts : 10540 Location : Oklahoma
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2606 Posts : 582 Location : Reeses Mill, WV
Bearsgarage Member
Bearsgarage Member
| Subject: Re: [DNF][2020 Build-Off Entry] Bearsgarage's Thrown Rod April 6th 2020, 10:49 am | |
| [adm]Per Rules and guidelines: Entrants MUST update their thread at least monthly detailing progress, with either write-ups, videos and/or photos.
If you cannot work on the project right now, please let us know. [/adm] | |
Bearsgarage Member
Bearsgarage Member
Age : 21 Join date : 2016-10-29 Points : 6476 Posts : 3549 Location : Lewisburg, KY
| Subject: Re: [DNF][2020 Build-Off Entry] Bearsgarage's Thrown Rod April 14th 2020, 12:37 am | |
| What are those hubs? Looking good, progress is progress. Also, I'm assuming you're just using that axle for mockup, and know that a flipped axle doesn't play well with c clips or steering geometry? lol | |
Bearsgarage Member
Bearsgarage Member
Age : 25 Join date : 2016-07-10 Points : 8340 Posts : 5190 Location : Ontario Canada
| Subject: Re: [DNF][2020 Build-Off Entry] Bearsgarage's Thrown Rod May 5th 2020, 6:15 am | |
| Wow, that cylinder head picture belongs in the Fail Thread for sure! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Bearsgarage Member
Bearsgarage Member
Age : 34 Join date : 2013-11-02 Points : 6916 Posts : 2906 Location : New Jersey USA
| Subject: Re: [DNF][2020 Build-Off Entry] Bearsgarage's Thrown Rod June 4th 2020, 2:14 pm | |
| I have generally used older flat head engines on my equipment, somewhat because I worry about the rocker arms and valve gear holding up on OHV engines, but also because I usually just use what I can get for nothing. On the other hand, some people run the heck out of the newer OHV stuff with no problems too. Seems to be just a little more likely to have problems that the flat heads. I guess at this point the really old stuff is getting a little bit less common, but so many lawn mowers sit around un-used for years in garages and outside that it'll be quite awhile still before we run out of parts to play with.
Oh well, part of the fun is breaking stuff and then trying to fix it or make it better. Wonder if the keepers just jumped out at high rpm or what? | |
Bearsgarage Member
Bearsgarage Member
Bearsgarage Member
Bearsgarage Member
| Subject: Re: [DNF][2020 Build-Off Entry] Bearsgarage's Thrown Rod September 17th 2020, 11:00 pm | |
| This month I've made no progress, getting things made for my wedding has taken over my garage. However it has been on my mind that the way I'm trying to cut up and sit the body it might be hard to bail. That has me thinking i should set up a seat belt and roll bars
Bearsgarage Member
| Subject: Re: [DNF][2020 Build-Off Entry] Bearsgarage's Thrown Rod November 3rd 2020, 1:18 pm | |
| It has been an interesting last few months i got married, my best friend got married and between the two i didn't get time in the garage. However i did manage some time to cut the body a little more to sit on the frame. | |
