Welcome to the All Terrain Lawn Tractor Forum! . . .
2020 Build-off Started, Look for entry instructions HERE! . . .
New Top Tractor Challenge and Build-Off Profile Buttons on the menu bar! . . .
2019 Build-Off Winners . . . 1-AllisKidD21 . . . 2-Offroad Mudmowers . . . 3-MightyRaze . . . Close vote, all were winners!
 - [2020 Build-Off Entry] Justin’s Jammin Deere
jeliff0205
- [2020 Build-Off Entry] Justin’s Jammin Deere Empty
PostSubject: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeFri Mar 06, 2020 4:52 pm
This is my John Deere 130 that is stock other than a pulley swap and governor removal. It has a Kawasaki single and a peerless 800. I would like to lower it with a custom built front end, with live axle and hopefully slicks all around. The power source will be a Briggs horizontal with a torque converter. My goal is to reach a minimum of 50 mph.
- [2020 Build-Off Entry] Justin’s Jammin Deere Fd679f10
Approved MightyRaze Mar 6, 2020
Forum Rep : 498
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeSat Mar 07, 2020 12:08 am
Welcome to the Build-Off 2020!
Li'l RED my original modified tractor!
Forum Admin -- Chat Admin-- Facebook Page Admin
ATLTF Facebook Page --How To Upload Pictures
jeliff0205
PostSubject: Build off progress for Justin’s Jamin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeFri Mar 20, 2020 3:52 pm
Many things are happening, whole drive system is removed, custom built front spindles, and front axle is in! Also, painted the floor pan with bed liner, really digging the look and texture.
- [2020 Build-Off Entry] Justin’s Jammin Deere A498f210
- [2020 Build-Off Entry] Justin’s Jammin Deere 31dd4c10
- [2020 Build-Off Entry] Justin’s Jammin Deere Df190b10
Hammer
Hammer
Forum Rep : 83
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeFri Mar 20, 2020 7:00 pm
Like the spindles. Very easy and simple suspension. Should work great at the high speeds you are shooting for.
jeliff0205
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeFri Apr 17, 2020 3:52 pm
Haven't done an update in a few weeks, frame has been stripped completely and has been painted in a gloss black, mounted pillow bearings and got axle parts in(brakes, sprocket, axle).  Steering is put together with aluminum tie rods from a polaris indy sled. Bought a hydraulic brake kit and made a bracket to be hooked up to the stock brake pedal.  The build is coming along EXTREMELY well. - [2020 Build-Off Entry] Justin’s Jammin Deere Img_2212
- [2020 Build-Off Entry] Justin’s Jammin Deere Img_2210
- [2020 Build-Off Entry] Justin’s Jammin Deere Img_2211
jeliff0205
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeFri Apr 17, 2020 3:57 pm
More pics for above post
- [2020 Build-Off Entry] Justin’s Jammin Deere Img_2214
- [2020 Build-Off Entry] Justin’s Jammin Deere Img_2213
yeethaw
Screwdriver
Screwdriver
yeethaw
Forum Rep : 8
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeFri Apr 17, 2020 11:41 pm
Looking clean! Can’t wait to see this finished
diddie
Screwdriver
Screwdriver
diddie
Forum Rep : 21
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeSat Apr 18, 2020 8:18 pm
nice build looks like it should handle 50 plus ! but be smart and wear protection affraid
jeliff0205
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeTue Apr 21, 2020 12:23 am
@diddie oh yea definitely will, thanks!
Forum Rep : 498
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeTue May 26, 2020 9:21 am
Don't forget to update!  Very Happy
jeliff0205
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeTue May 26, 2020 1:30 pm
Little update, rims are on order and engine mockup begins! I purchased rear hubs and tires and all 4 rims. I’m using an intek Briggs that I’m slowly building into an animal. I had to buy proper springs for the springer spindles because the ones I originally had were too weak. - [2020 Build-Off Entry] Justin’s Jammin Deere Image10
- [2020 Build-Off Entry] Justin’s Jammin Deere 25e27d10
a- [2020 Build-Off Entry] Justin’s Jammin Deere 0ea29e10
Forum Rep : 498
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeMon Jul 06, 2020 4:40 pm
jeliff0205
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeSat Jul 18, 2020 11:52 pm
Many changes have been made to the Deere, I swapped the Briggs out for a 212 because it had a rod knock and was smoking and fouling plugs, I also mounted the hood, and put a hater pipe out the side of the hood, I took the torque converter off and put on a clutch with a slightly bigger rear sprocket, the engine is going to get built later, as of now with the clutch I hit 50!- [2020 Build-Off Entry] Justin’s Jammin Deere B8e41c10
- [2020 Build-Off Entry] Justin’s Jammin Deere 8aaab710
- [2020 Build-Off Entry] Justin’s Jammin Deere Eb4e3810
Forum Rep : 498
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeSat Aug 29, 2020 7:49 pm
[adm]Per Rules and guidelines:
Entrants MUST update their thread at least monthly detailing progress, with either write-ups, videos and/or photos.
If you cannot work on the project right now, please let us know.
[/adm]
Forum Rep : 498
PostSubject: Re: - [2020 Build-Off Entry] Justin’s Jammin Deere   - [2020 Build-Off Entry] Justin’s Jammin Deere Icon_minitimeFri Sep 25, 2020 2:17 pm
Topic Deficient
[/adm]
Please make any kind of update in the next month to avoid probation!
