Welcome to the All Terrain Lawn Tractor Forum! . . .
2020 Build-off Started, Look for entry instructions HERE! . . .
New Top Tractor Challenge and Build-Off Profile Buttons on the menu bar! . . .
2019 Build-Off Winners . . . 1-AllisKidD21 . . . 2-Offroad Mudmowers . . . 3-MightyRaze . . . Close vote, all were winners!
 [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller
Vice Grip
Vice Grip
Forum Rep : 99
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Empty
PostSubject: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeMon Mar 30, 2020 8:42 pm
Well I am gonna do my best here... this is a late 70's sears suburban, 6speed hi low trans, 16hp briggs opposed twin.  I bought it from a family that the old man died, it was pretty well taken care of... I have allot of old records and manuals for it, the family called it the grey boy, I also bought two other suburbans that were the blue boy and yellow boy...
Goals are to build it to pull in the stock tractor class this summer hopefully, I have to abide by the rules of the place I intend to pull so certain modifications are allowed and others are not...
In the short term it has had a nasty backfire thru the exhaust while running, I got the heads off it tonight, and the most important thing I think I noticed is that the intake manifold gasket was loose and missing on the passenger side, and that is the side the backfire was happening so I think I have it figured out... Either way I have both heads pulled to clean the carbon off the pistons and valves....
Gonna paint it up, get some Ag tires on the back, get a pulling hitch and some weight..
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5011
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_4717
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5010
Approved MightyRaze Mar 30, 2020
Forum Rep : 498
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeMon Mar 30, 2020 9:40 pm
Welcome to the 2020 Build-Off. Sorry, you came in right when I was processing the sticker giveaway. An hr earlier and I would have added you to the pot. Sad Eyes
Li'l RED my original modified tractor!
Forum Admin -- Chat Admin-- Facebook Page Admin
ATLTF Facebook Page --How To Upload Pictures
Hillbilly Offroading
Screwdriver
Screwdriver
Forum Rep : 21
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeMon Mar 30, 2020 9:49 pm
The patina is perfect.
Vice Grip
Vice Grip
Forum Rep : 99
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeWed Apr 01, 2020 8:39 pm
got both heads off and the intake manifold off.... cleaned off the carbon and checked the valve clearances... everything looks good except the passenger side intake manifold was totally missing and the screws were loose so, I am waiting for those parts to come in and i can put the motor back in... I had to unbolt the motor and turn it 90 deg so i could work on it....
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5012
Vice Grip
Vice Grip
Forum Rep : 99
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeMon Apr 13, 2020 9:33 am
so I finally got the motor cleaned up new gaskets, retuned the carb & I finally drove it without something crazy going on.... This thing is awesome, it does a big wheelie and pulls hard in 3rd gear....
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5110
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5111
Vice Grip
Vice Grip
Forum Rep : 99
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeFri May 08, 2020 8:05 pm
not much progress but got the gas tank out and the seat off, want to get a smaller pan type seat to use for pulling.... plans are to make a front weight bracket, front weights, and go ag tires in the rear. Started wet sanding the hood, gotta get some paint soon....
The backfire problem was due to a bad intake gasket, now it runs great and strong... will do a big wheelie in 3rd gear....
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5211
BoogerWeld
BoogerWeld
Forum Rep : 145
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeSat May 09, 2020 6:36 am
Glad to hear it's running right. Keep up the good work.
Vice Grip
Vice Grip
Forum Rep : 99
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeSat May 23, 2020 10:19 am
So weights are expensive etc, I found a deal on some sets of these ones for riding mower rear wheels, I cut a chunk off of them with the sawzall and mounted them up to my front rims & it worked out great. Luckily my valve stem is on the inside....
I am working on a bracket for weights way out front & getting ready to do some paint...
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5312
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5310
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5311
Forum Rep : 498
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeMon Jul 06, 2020 4:41 pm
Don't forget to update!  Very Happy
Vice Grip
Vice Grip
Forum Rep : 99
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeTue Jul 07, 2020 7:55 am
been a tough few months with the virus nonsense, all the local pulls got cancelled, & we are a month away from a new baby! Anyway got some work done... got my fenders painted and scored some 23x10.5 tires....
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5510
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5610
Vice Grip
Vice Grip
Forum Rep : 99
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeTue Jul 21, 2020 9:07 pm
tractor is moving on its own... got the tires mounted.. i got some rear wheel weights over the weekend... still have to paint my hood... not sure how much further i will get with the baby coming at the end of august but im working on it...
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5710
Forum Rep : 264
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeWed Jul 22, 2020 7:11 am
She's looking good. Congrats on the baby news by the way! Very Happy
       - Toro Rat Rod Tractor Build
       - Allis B-110, 710 & 716 - Wheel Horse 655 & 953 - Case 444 - Bolens Versamatic & 1668 - Cub 106 - Ford LGT 125 -
Forum Rep : 498
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeSat Aug 29, 2020 7:50 pm
Spoiler:
Vice Grip
Vice Grip
Forum Rep : 99
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeFri Sep 18, 2020 10:00 pm
Sorry for my absence, I dont really need the big highlighted reminder, but anyway my son was born on the 25th, and things have been crazy obviously....we are back home and I did end up buying and selling allot of tractors between march and now even with the stupid virus problems...
I just starter work back on this tractor but I probably wont have it ready for competition till next season, but I will have it looking good soon...
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5911
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_5910
[2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Img_6110
Forum Rep : 498
PostSubject: Re: [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller   [2020 Build-Off Entry] mrshaft696's The Grey Boy Sears puller Icon_minitimeSat Sep 19, 2020 1:39 am
Super congrats man! Awesome update!
