Welcome to the All Terrain Lawn Tractor Forum! . . .
2020 Build-off Started, Look for entry instructions HERE! . . .
New Top Tractor Challenge and Build-Off Profile Buttons on the menu bar! . . .
2019 Build-Off Winners . . . 1-AllisKidD21 . . . 2-Offroad Mudmowers . . . 3-MightyRaze . . . Close vote, all were winners!
 [2020 Build-Off Entry] Rally Deere Build
yeethaw
yeethaw
Forum Rep : 8
[2020 Build-Off Entry] Rally Deere Build Empty
PostSubject: [2020 Build-Off Entry] Rally Deere Build   [2020 Build-Off Entry] Rally Deere Build Icon_minitimeWed May 06, 2020 6:06 pm
Well I’m finally back with my new 2020 build off entry. It’s a John Deere 165 hydro that Im gonna be making into a rally mower for off-roading and also for driving on the streets. My main goal with it is to be able to hit 50mph on it. So far I’m planning on lowering it with a live axle and putting a Race prepped peerless 700 In so I can still have low end torque for trail riding. I’m gonna put either 16 or 18 inch ag tires on the rear and knobby tires on the front. For my front end I’m going to make lower spindles that will mount onto the original axle. I’m hoping to use the stock steering since there’s barely any slop in it and it’s also fully adjustable. For the engine I plan on using the 20hp intek v twin on the black tractor. For engine mods I’m just gonna do a bigger exhaust and an open air intake [2020 Build-Off Entry] Rally Deere Build Ff1a8c10
[2020 Build-Off Entry] Rally Deere Build Ac47ae10
[2020 Build-Off Entry] Rally Deere Build 59a01d10
Approved MightyRaze - May 7, 2020
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: [2020 Build-Off Entry] Rally Deere Build   [2020 Build-Off Entry] Rally Deere Build Icon_minitimeWed May 27, 2020 9:12 pm
[2020 Build-Off Entry] Rally Deere Build B137a510
[2020 Build-Off Entry] Rally Deere Build 98954010
[2020 Build-Off Entry] Rally Deere Build 1eb7cd10
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: [2020 Build-Off Entry] Rally Deere Build   [2020 Build-Off Entry] Rally Deere Build Icon_minitimeWed May 27, 2020 9:16 pm
well im starting the build, ive got it stripped down in my basement and im starting to work on making the clutch and mounting the engine. i have an engine that im gonna sell soon and once that is gone im gonna go and buy the live axle and the rest of the rear end. im hoping tonight to be able to get the dash mounts notched to fit the exhaust
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: [2020 Build-Off Entry] Rally Deere Build   [2020 Build-Off Entry] Rally Deere Build Icon_minitimeTue Jun 16, 2020 11:23 pm
Got the throttle set up on the v twin, also started to do a direct steering setup for it but I was having problems with roll over on steering shaft arm, how can I fix this? Also ordered my whole rear end setup so I hope to have that put in soon. Anybody have any opinions or input on this build?[2020 Build-Off Entry] Rally Deere Build Fab3c910
Forum Rep : 116
PostSubject: Re: [2020 Build-Off Entry] Rally Deere Build   [2020 Build-Off Entry] Rally Deere Build Icon_minitimeWed Jun 17, 2020 1:31 am
What do you mean rollover? Is an arm camming over and locking up?
Forum Rep : 134
PostSubject: Re: [2020 Build-Off Entry] Rally Deere Build   [2020 Build-Off Entry] Rally Deere Build Icon_minitimeWed Jun 17, 2020 6:29 am
If this is the case, just weld in some steering stops to limit travel so it doesn’t “roll over”
Forum Rep : 115
PostSubject: Re: [2020 Build-Off Entry] Rally Deere Build   [2020 Build-Off Entry] Rally Deere Build Icon_minitimeWed Jun 17, 2020 10:17 am
You can either add steering stops on the axle or on the steering arm itself so it comes over and hits the axle. Just as long as it's heavy duty enough to not bend too bad or break off. I've used bolts before.
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: [2020 Build-Off Entry] Rally Deere Build   [2020 Build-Off Entry] Rally Deere Build Icon_minitimeTue Jun 23, 2020 9:57 pm
Well I got the rear axle In and finally got the chance to do a mock-up on it. I’ve gotta send the tires back since the beads are messed up
All I have left to do is
•center rear axle
•mount engine
•mount trans
•get new tires put on
•repaint rims
•mount clutch
•front tires
•repaint body
And a few other things but this thing is looking closer to completion
yeethaw
yeethaw
Forum Rep : 8
PostSubject: Re: [2020 Build-Off Entry] Rally Deere Build   [2020 Build-Off Entry] Rally Deere Build Icon_minitimeTue Jun 23, 2020 9:58 pm
[2020 Build-Off Entry] Rally Deere Build 98eb5310
[2020 Build-Off Entry] Rally Deere Build B25aca10
