❆ ❅ ❄ Happy New Year ❄ ❅
Minor forum update to allow for easier to read forums.
New Awards system! Look for your award at 500, 1000, 2500, 5000, 7500, and 10000 Posts!!!
 Li'l Red 3.0? Growing up to be Red.
Budget_gokart
Nevadablue
darkside0914
Rustbucket Garage
redzz02
Hillbilly Offroading
BlakeGroce
17 posters
Li'l Red 3.0? Growing up to be Red. - Page 5 Empty
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeMon Feb 22, 2021 6:44 am
A bore guage will let you check the cylinder for out of round and taper, or take a top ring to and use it to check the ring end gap in the top and bottom of ring travel in the cylinder. You should be fine giving it a honing too, the oppys have cast iron cylinder sleeves.
What did you set your valve clearances to?
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeMon Feb 22, 2021 9:49 am
Good Idea on using an old ring to check too.  I may try that later.
I set the intake to .004.  One was already there, the other had no gap.  I got it up to .004.  The exhausts were sitting around.005, I bumped them to .008.
Seats an valve mating surfaces looked great!  Didn't feel I needed to lap them.
Tractors:
Li'l Red 89 Murray Widebody
TheGreenMachine 89 Craftsman GT18
Bowser 01 Murray Widebody LT
Grandpa 75 Sears ST/16
Dirty Rat 77 Sears Suburban
 > > > ATLTF Staff < < <
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeMon Feb 22, 2021 10:04 am
Oh okay, your clearances should be alright. A good way to check if a valve is seating is put it in the block, apply good pressure to it with your thumb and try to turn it back and forth. If it turns real easy it's not seating right.
  - Allis B-110 x2, 710 & 716 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic & 1668 - Cub 106 & 124 - Ford LGT 125 & 145 - White 1650 Yard Boss
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeMon Feb 22, 2021 10:25 pm
They are seating really well.  No wiggles.
Drilled out those pockets so oil doesn't sit in there to coagulate. Now the block needs a good cleaning to be sure not to get any shavings in there.
Li'l Red 3.0? Growing up to be Red. - Page 5 Img_1114
Anyone know what this nifty tool is for?  Very Happy
Li'l Red 3.0? Growing up to be Red. - Page 5 Img_1115
I'll post the answer tomorrow if no one gets it!
Waiting for some parts to come in at this point.
Tractors:
darkside0914
darkside0914
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeTue Feb 23, 2021 12:12 am
i don't remember what it was for but i do remember my grandpa had one like it in his tool box when i was a teen
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeTue Feb 23, 2021 7:54 pm
Since no takers...
It's a piston groove cleaner/cutter.   Li'l Red 3.0? Growing up to be Red. - Page 5 102878487
Li'l Red 3.0? Growing up to be Red. - Page 5 Img_1116
Tractors:
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeThu Feb 25, 2021 9:05 am
Well I guess I learned something today! Never knew they had those. Cool!
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeFri Feb 26, 2021 9:16 pm
Boy that's pretty neat, I don't think I've seen one of those before either. Another good way to do it is snap one of the old rings in half and use the sharp broken edge to clean the grooves out.
'Course that only works if you're replacing the rings. lol!
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeFri Feb 26, 2021 11:33 pm
@AllisKidD21, that was my plan to use an old ring since I got new ones.  My dad whipped that out and said, here you go.  You can keep it.  Worked like a charm and was super easy.
Tractors:
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeSat Feb 27, 2021 12:25 am
Hopefully the next update is ripping some dirt.
Tractors:
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeSat Feb 27, 2021 1:39 am
@MightyRaze wrote:
I worked over the engine this afternoon.  I found my compression and leak test kits.  I hate to go on, but left side engine I was getting 45psi with leaks.  Right side I got 32psi with major leak.
I knew I should have did a valve job.  I hate pulling valve springs.  I have a briggs tool now, so this should be easier.  I guess I have a new project.  Should I screw up, I do have a couple engines to pull new valves.
Dizzy
Well, compression is 53 both cylinders. Not as much as I hoped, but that could be the compression release. Leak down appeared fine. Too impatient to wait too long.
Tractors:
BlakeGroce
BlakeGroce
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeMon Mar 01, 2021 11:08 pm
Sounds good! Cant beat the sound of an opposed twin! Makes me want to get out the old onan and fire it up.
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeTue Mar 02, 2021 11:51 am
Here it is idling. Not a special video, just one to hear it purr.
Tractors:
BlakeGroce and Rustbucket Garage like this post
BlakeGroce
BlakeGroce
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeThu Mar 04, 2021 12:15 am
Li'l Red sounds great! But that was the best "Alright!" I've ever heard! I swear that was better than Mathew MaConaughey. Like you need to take that sound clip and make a button so that anytime your feeling cool just go over press the "Alright! Cool" button.
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeThu Mar 04, 2021 12:38 am
LOL, I go around doing the alright alright alright all the time.  Makes my wife laugh...  BigGrin
Tractors:
BlakeGroce likes this post
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeSun Mar 07, 2021 9:37 pm
Hmm... not that big an issue, but we will see how things go. Changed the oil after running it about an hour straight.  Oil looked good, no metal in it.  Yesterday I noticed an oil drip under Red.  Appears to be some oil weeping out the bolt holes in the front of the sump.  Not happy about that.  Tomorrow, I may see about dropping the engine pulley to be sure the oil seal isn't part of the issue.  I have about 2-3 of those on hand if needed.  If all of it is coming from the sump bolts, ugh...  I'll just run with it and send it at Haspin.
Tractors:
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeSun Mar 07, 2021 9:47 pm
I forgot, I did upgrade my seat spring and added more foam to my seat on RED for haspin later this year.
Li'l Red 3.0? Growing up to be Red. - Page 5 Img_1123
Tractors:
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeThu Mar 11, 2021 9:41 pm
Li'l Red 3.0? Growing up to be Red. - Page 5 1f624 I see forumotion snuck in a new emoji button.  Anyways...
I dropped the pulley and the oil seal is dry, no oil from there.  I cleaned it up and placed a paper towel around the sum.  Found that the oil is coming from the front 2 bolts in the front of the sump.  Also noticed the gasket was squeezed out around the front.  Guess I need to pull it back out and replace the sump gasket again.  Dang cheapo chinagasket....
Tractors:
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeThu Mar 11, 2021 9:56 pm
You can get gasket material online relatively cheap too. I tried some and it can be kind of a pain if you don’t have a really sharp pair of snips but it holds up ok. Used some as a carb gasket and it tore 3 months later when I took it off again but hey pretty sure the factory would have done the same too. Anyway, thought it might work better for what you’re doing because you can get a higher grade compound than factory and it’s cheaper. Hope that helps ya. Li'l Red 3.0? Growing up to be Red. - Page 5 1f44d
darkside0914
darkside0914
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeFri Mar 12, 2021 2:24 am
or just use a non-corrugated box, like a cereal box, i've used them for everything from carbs to automotive water pumps and never had one fail yet
BlakeGroce
BlakeGroce
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeFri Mar 12, 2021 4:26 pm
I make alot of gaskets this way, but I'm not sure I'd make a sump gasket just because normally they are a specific thickness to get the right crankshaft end play. But I have used a paper plate as a gasket before and that also worked but not sure I'd do it again.
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeWed Mar 17, 2021 10:58 pm
Tiny update!
Tractors:
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeSat Mar 20, 2021 11:46 pm
Got my "BRIGGS" gasket today for the sump.
This is how a flat gasket should be shipped.  No bends to be had here!
Li'l Red 3.0? Growing up to be Red. - Page 5 Img_1210
Check the difference in the "Briggs" gasket and the china gasket.
Li'l Red 3.0? Growing up to be Red. - Page 5 Img_1211
Briggs gasket fitment!
Li'l Red 3.0? Growing up to be Red. - Page 5 Img_1212
China gasket fitment.
Li'l Red 3.0? Growing up to be Red. - Page 5 Img_1213
None of the holes quite fit right.  Probably why it leaked.  Briggs one fits well.  I got the sump back on and stripped out 2 of the bolts.  I think I can use a metric bolt in those holes to catch threads and be ok.
I hope to have it back together tomorrow or this week.
Tractors:
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeSun Mar 21, 2021 6:26 pm
Back together.  Metric M8-1.25 bolt did the trick! Ran it around the block to warm it up and see if it leaks.
Tractors:
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeTue Jun 08, 2021 11:32 pm
SO in the process of getting Red Haspin ready, I realized.  Red is pissin oil out again.  So post Haspin I will look into engine options.  Try to fix this one a 3rd time or move on to the V-Twin.
Tractors:
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 5 Icon_minitimeThu Jun 10, 2021 7:20 pm
where is the oil leak coming from?
Page 5 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
