PortalHomeSearchRegisterLog inTop Tractor Challenge
Welcome to the All Terrain Lawn Tractor Forum! . . .
. . . . . . . . . . . . . . Happy Holidays!
 Li'l Red 3.0? Growing up to be Red.
Budget_gokart
Nevadablue
darkside0914
Rustbucket Garage
redzz02
Hillbilly Offroading
BlakeGroce
17 posters
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8
Li'l Red 3.0? Growing up to be Red. - Page 8 Empty
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeSun Nov 07, 2021 1:51 am
@Dr Bob  A very PIC intensive post.
I busted out the MST206 I had and aligned it up on Red with the 820 for more "accurate" measurements.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2618
The shift rod is in the exact same location on both...
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2619
As I mentioned earlier, the 820 had a much longer input shaft.
The 206 had a height around 3 5/8 inches.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2620
The 820 I have came in at about 5 7/8 inches.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2621
I also did a pulley height.  Also, as I had expected.  From the frame mount to the top of the input pulley on my 820 is taller than the MST.
MST frame mount to top of pulley came in just over 4.5 inches.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2622
You can't see the pulley, but... 820 frame mount top of pulley came in about 5 1/16 inches.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2623
This was good for me, now I know I need about a half inch lift in the rear.  Time to take the time and get things right.
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeMon Nov 08, 2021 3:34 pm
Video version of my updates thus far.
Tractors:
Li'l Red 89 Murray Widebody
Kal-El 82 Murray GT -Retired-
TheGreenMachine 89 Craftsman GT18
Bowser 01 Murray Widebody LT
Thor 77 Hydro Sears Suburban
Grandpa 75 Sears ST/16
Nevadablue likes this post
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeMon Nov 08, 2021 9:49 pm
Frame raised on the transaxle a hair over 1/2 inch higher than it was.  820 input pulley appears to be in much better alignment now for the belt.  Also, a bonus to the 7 inch larger engine pulley, the belt now easily clears the steering bolts.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2625
Still need to remove the rear tires and drill out the new front mount bolts.
Tractors:
Nevadablue
Screwdriver
Screwdriver
Nevadablue
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeMon Nov 08, 2021 10:01 pm
Looking good!
Dr Bob
Dr Bob
Forum Rep : 2
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeTue Nov 09, 2021 12:45 am
Aha! Caught and fixed an allignment issue while going above and beyond to answer a question, cool. Thanx so much for the side-by-side (over-under) comparison. I acquired an 820 and already have the widebody but have yet to compare transaxles side-by-side. This confirmed my suspicions about input pulley height. Now I just have to tackle the shift shaft. Mine is from a Craftsman GT and has a short shift shaft that's a nub that sticks out just outside the case.
Looks like that 7" front pulley gives you plenty of clearance from the steering bolts. While exploring a 5" option, I strongly considered filing the mounting holes square in that bottom steering bearing and replacing the bolts with carriage bolts for their smooth head.
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeWed Nov 10, 2021 12:04 am
Few little things today.  My metal replacement pulley was the right size at the lip of the pulley, but the belt surface was the wrong diameter so it would not work in the clutch arm.  I did have another, which I have on the clutch arm, but the seal is busted.  I have a replacement on order.  Should be here Thursday.  Once that is on, I should be able to but the rear fenders back on.
Wiring for the rear lights, battery cable and my new vent line is installed.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2627
One of my older exhaust pipes with the muffler is installed.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2628
Transaxle is now realigned and bolted up.  You can see my 1/2 inch worth of shims in the rear mount.  I could have done nuts or something, but I wanted something a little more structural.  Don't want any undue stresses.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2626
Couple more shots of the exhaust.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2631
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2630
My plugs for my rear lights, yellow plug is ground, blue is brakes, and the red is my normal tail lights.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2629
I'm probably going to sit on it a day until my pulley comes in for the clutch arm.  I will likely reuse 75% or more of the existing wiring.  I actually did a decent job last time running it.
Tractors:
Nevadablue
Screwdriver
Screwdriver
Nevadablue
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeWed Nov 10, 2021 12:39 am
I think you should enlarge that ‘lift plate’ to include the outer set of holes in the axle housing and add a gusset between the bolts.
Li'l Red 3.0? Growing up to be Red. - Page 8 F0ba4c10
MightyRaze, Murraymountain, Brianator and Dr Bob like this post
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeWed Nov 10, 2021 9:45 am
I've thought about that several times.  I'll continue to think about it.  Li'l Red 3.0? Growing up to be Red. - Page 8 1f604
Got board waiting for my pulley and did a little engine dressing.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2710
Tractors:
Dr Bob and Nevadablue like this post
Budget_gokart
Screwdriver
Screwdriver
Budget_gokart
Forum Rep : 5
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeWed Nov 10, 2021 9:52 am
im painting my oppy red white and blue
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeFri Nov 12, 2021 12:34 am
Progress is being made!  Got my pulley today so the rear fenders and reconnecting the wiring has begun!  I got a few things under the dash left to do, so my switches are just dangling at the moment.
Tail lights...
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2711
Brake lights
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2712
Tail lights with brake lights.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2713
Tractors:
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeSun Nov 14, 2021 1:09 am
Got 'er fired up today to check if the belt would work.  I'm going to need a slightly bigger belt in length.  the 96 is a bit too short. I'm thinking a 97 is in order.  Even with the clutch in, the belt is still turning.  I kind of figured as the clutch pedal was not coming all the way back.
Tractors:
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeSun Nov 14, 2021 1:40 am
2 options... put the 6 inch pulley back on or buy a new belt...
I'm thinking put the 6 inch back on. (31mph is fast enough)  It's at least $20 (plus tax) cheaper.  HAHA...
I'm working on cleaning out another part of the building.  When I am done, I may put the other pulley back on and reconnect the steering.
Tractors:
Nevadablue
Screwdriver
Screwdriver
Nevadablue
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeSun Nov 14, 2021 5:05 pm
At 31 MPH, connected steering is good!  Li'l Red 3.0? Growing up to be Red. - Page 8 1f601
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeSun Nov 14, 2021 6:33 pm
Works well with rack and pinion and ball bearing hubs.  No death wobble for me.
Dash is reinstalled.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2718
Installed the USB charger from Kal onto Red.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2716
I have the winch kill installed next to my manual winch override.  I have labels made for these, just not installed yet.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2717
I have not reinstalled, the 6 inch pulley yet.  After cleaning the 2nd 3rd of the building, I was pretty sore and tired.  Did get a little done with Grandpa.  More on that in his thread.
The right 3rd is cleaned up.  All that is missing is my daily mower and grandpa.  They will go on the right wall.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2719
Tractors:
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeMon Nov 15, 2021 12:02 am
Got the foot throttle installed and the hood is reinstalled.  Now I just need to reinstall the old pulley, relocate some guides and  reconnect the steering.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2723
Tractors:
MN mudder
Screwdriver
Screwdriver
MN mudder
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeMon Nov 15, 2021 11:14 am
lookin good mighty!
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeMon Nov 15, 2021 11:46 am
So, this tractor's battery is about toast an it is only 5 months old.  Still going dead while sitting a couple days even with the winch disconnected.  I got it from TSC.  Last battery I got from TSC did the same thing.  Lasted about 6 month and kaput.  I have Walmart batteries that are 5-6 YEARS old that still work.  Ugh....
Tractors:
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeTue Nov 16, 2021 12:10 am
All right!  I think I got it done for now!  Red is back together and in one piece again!  I'll see if I can get it out tomorrow for a test run!
When you can't get on the ground and work on the underneath, you get creative!  New belt installed, ended up with a .5x94".  The 5/8x96 was too short and actually didn't fit the pulleys well after all.  I may have to redo one guide, but that's no big deal.  I did find the oil leak.  It's the typical valve cover leak on an oppy.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2726
Trans vent terminated up near the gas tank.
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2725
All back together!
Li'l Red 3.0? Growing up to be Red. - Page 8 Img_2724
Tractors:
Screwdriver
Screwdriver
Forum Rep : 7
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeTue Nov 16, 2021 12:15 am
That's one clean machine man and I'm not talking about just the lack of dirt! Lol
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeTue Nov 16, 2021 9:42 am
LOL, thanks.. Looks pretty good from the 10 foot range!  It is starting to get a lot of scrapes, dents......er Character marks.  LOL
Tractors:
Forum Rep : 554
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeTue Nov 16, 2021 1:39 pm
Well, it seems I have toasted another HF 2500 winch controller.  Don't make these things try to pull too hard, those controllers will just burn up.  Not sure why I have such bad luck with these things.  Now that they are $85.  I just don't see myself getting another.  Should have seen it coming when it started to drain my battery over time.  Winch itself seems fine.  I'll look into just a manual switch.
Tractors:
Screwdriver
Screwdriver
Forum Rep : 7
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeTue Nov 16, 2021 9:49 pm
Ahh nobody is going to notice at 18.746mph anyhow!
Budget_gokart
Screwdriver
Screwdriver
Budget_gokart
Forum Rep : 5
PostSubject: Re: Li'l Red 3.0? Growing up to be Red.   Li'l Red 3.0? Growing up to be Red. - Page 8 Icon_minitimeWed Nov 17, 2021 9:31 am
LOL how fast can a murray go Razz
Page 8 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8
