Subject: Re: Li'l Red 3.0? Growing up to be Red. Wed Jan 20, 2021 7:22 pm
It’s your call, but I would keep the oppy just because they sound cool
Age : 45 Join date : 2016-09-06 Posts : 7068 Forum Rep : 531 Location : Central Oklahoma
Subject: Re: Li'l Red 3.0? Growing up to be Red. Thu Jan 21, 2021 7:51 am
Yeah, I think I'll keep the oppy for now, or at least till it croaks. LOL.
While thinking this morning about the project. A "duh" type moment hit me like a ton of bricks. I'm a smart guy, not sure why I didn't think of this in the first place. The arrangement of my shocks are severely limiting articulation. I have them literally going straight up and down.
I should have them slanted and drawn in a little further. / \
That would probably make them flex more and ride even smoother.
_______________________________________________ Li'l RED my original modified tractor!
Subject: Re: Li'l Red 3.0? Growing up to be Red. Thu Jan 21, 2021 8:05 am
I just realized only things I have done to the oppy in this tractor is change the sump gasket and pto side oil seal. I bet this thing would benefit with some new head gaskets.
Age : 44 Join date : 2018-05-05 Posts : 511 Forum Rep : 25 Location : S. Illinois
Subject: Re: Li'l Red 3.0? Growing up to be Red. Fri Jan 22, 2021 9:51 am
@MightyRaze i'm about to do the same basic thing on a 14hp oppy and put it in my build off tractor, but google is stupid, or i am, and i can't find the part numbers for the gaskets and seal, i have no experience with these engines, so if you can give me a little help with the seals and pan gasket part numbers i'd appreciate it, it's my understanding that the seal and pan gaskets are the same for all 14 to 20hp briggs opposed twins
Subject: Re: Li'l Red 3.0? Growing up to be Red. Fri Jan 22, 2021 11:18 am
Shoot me your model-type and I can get you the exact part #'s. Mine was a 495868 for the engine gasket set.
Subject: Re: Li'l Red 3.0? Growing up to be Red. Fri Jan 22, 2021 9:53 pm
Time to re-evaluate my path as it has somewhat changed.
Plans are open, but I think I may take a stab at a custom frame. if it does not cost too much. Scrapped, cost too much for right now.
Put in the 21HP Vtwin Scrapped, engine needs some repair. Will hold for another day.
Better front suspension and front frame. Do the shocks need angled? Still need to plan out.
While the tires are good, maybe upgrade them. Put these on other tractors. Rear tires swapped over to garden tractor wheels. Hubs installed on rear axle. Waiting now for rear axle nuts. Front tires purchased, waiting on tubes.
New Exhaust planned
Backup drum brake adjusted. Not needed. Left alone.
Subject: Re: Li'l Red 3.0? Growing up to be Red. Sat Jan 23, 2021 3:46 am
angling the shocks will soften the ride, i'm not sure how to put it exactly, but with them at an angle they will feel softer, and will give more articulation as well, one of the strange facts i've learned building rc rock crawlers which have coil over oil filled shocks similar to what you have on red, and where do i find the model number, is it on the flywheel cover like the singles?
Murraymountain Prybar
Join date : 2019-02-04 Posts : 1698 Forum Rep : 64 Location : North Carolina
Subject: Re: Li'l Red 3.0? Growing up to be Red. Sat Jan 23, 2021 6:47 am
Yes either the cover like a single or on the side tins.
Subject: Re: Li'l Red 3.0? Growing up to be Red. Sat Jan 23, 2021 7:10 am
Subject: Re: Li'l Red 3.0? Growing up to be Red. Sat Jan 23, 2021 11:40 pm
@MightyRaze thanks for the help, i've only had 1 of the opposed twins and then got rid of it, we thought this one was junk until i decided to take a closer look inside, it had some loose head bolts that i think was what made it smoke and it looks like it was only firing on one cylinder, the valves open and close normally and the pistons have no slop at all, the cylinders look good, no scratches and a very tiny ring ridge at the very top, so i think replacing the coil, plugs, seals, and either rebuilding or replacing the carb should get it running nicely
Subject: Re: Li'l Red 3.0? Growing up to be Red. Mon Jan 25, 2021 8:13 am
Front end is missing.
Subject: Re: Li'l Red 3.0? Growing up to be Red. Mon Jan 25, 2021 2:06 pm
if you lived closer i'd offer you some of this rectangular steel i have, it's 1x3 i think and looks to be 1/8in thick, it was the main support legs from some large shelves being thrown out at our local dollar store
Rustbucket Garage Screwdriver
Join date : 2021-01-15 Posts : 221 Forum Rep : 20 Location : Upstate New York
Subject: Re: Li'l Red 3.0? Growing up to be Red. Mon Jan 25, 2021 5:26 pm
Just my 2c but if you have the front axle out would it be a good time to upgrade it? It looks like you have already braced your spindles judging by the picture but I think @Murraymountain had his bend at one point. I won’t tell you what to do though and I am certain you will have a very capable machine either way!
Subject: Re: Li'l Red 3.0? Growing up to be Red. Mon Jan 25, 2021 6:03 pm
Actually the Widebody axles are about as good as it gets without going cast iron. It's everything surrounding it that's the problem. Mighty deleted all that and with the suspension, it would be very unlikely to bend anything.
The main reason mine died (the axle was fine though) is because I cut off a lip (on the motor mount plate) that I didn't think was necessary. That was a big mistake since I have no suspension. Matter of fact, the new one is hurting a little. Of course, I definitely don't jump mine and run it through ruts and rocks at high speed on a weekly basis so I don't know why it's breaking .
Anyway, Mighty will be fine with his axle. I kinda wanna see how it holds to some hardcore abuse because there's several people who love to hate on the Widebody (not the regular Murray axle) stamped steel axle and praise they're stamped craftsman axles that snap in half on grass cutters.
Subject: Re: Li'l Red 3.0? Growing up to be Red. Mon Jan 25, 2021 6:14 pm
Good to know, thank you! I forgot all about his suspension work (which is fantastic). Sorry for the bad advice, I guess I went blank there.
Subject: Re: Li'l Red 3.0? Growing up to be Red. Mon Jan 25, 2021 8:04 pm
Before I start... I hate Forumotion added the "Current Time" button to the reply toolbar. Hate that it makes the bar wrap to a second line...
Man, that sounds perfect. I was thinking about 1x3 by 8'.
Axle isn't too bad. I did upgrade the nylon bushings to brass. I also added a few more welds to the seam. If I upgraded again, I would either go with a craftsman axle like Kal, or build my own.
Yep! Although, I would almost think a cast iron would be a downgrade possibly. They tend to snap when you get them too bound up. I would rather go for the bend. To me, the best actual upgrade that wasn't homebuilt would be to go to a Sears Suburban front axle. Talk about heft!
Yeah that's why I love my Widebody axles. You can't beat the strength to weight ratio.
I definitely wouldn't do cast iron on a build with suspension. I don't even know if that's possible. Seems like if you drilled a hole or did any welding it would create a weak/stressed spot.
And if jumping/rocky trails are in the future... Well, cast iron would definitely not be good.
Subject: Re: Li'l Red 3.0? Growing up to be Red. Mon Jan 25, 2021 9:51 pm
Latest video update.
Age : 18 Join date : 2019-06-01 Posts : 323 Forum Rep : 34 Location : Richmond Ky
Subject: Re: Li'l Red 3.0? Growing up to be Red. Tue Jan 26, 2021 6:58 pm
Nice job on the wheel studs! I did the same thing to Brutus and I ran into the same problem with finding bolts that didnt have a shank on them. I just ended up buying some grade 8 bolts the right length and then I used a 7/16 20 die and threaded them the rest of the way down......took forever, and it was pretty tight since the shank is a little bit bigger in diameter than the threads but ended up having to do 2 sets cause I guessed wrong on the length, cause I didnt have my wheel spacers yet. (Story of my life. lol) But the second ones I did worked perfectly!
Heres the first ones I made. Figured I'd use them on something else one day.
Subject: Re: Li'l Red 3.0? Growing up to be Red. Tue Jan 26, 2021 8:23 pm
Thanks! What I had worked out really well!
So this happened today.
