Welcome to the All Terrain Lawn Tractor Forum! . . .
New Top Tractor Challenge and Build-Off Profile Buttons on the menu bar! . . .
2020 Build-Off Winners . . . 1-Hillbilly Offroading . . . 2-darkside0914
HASPIN 2021 . . . Wednesday June 23rd through Sunday June 27th.
2021 Top Tractor Challenge August 14 competition –August 15 competitors ride, Pymatuning Pennsylvania **INFO HERE**
No 2021 Build-Off. Will return in 2022. Stay tuned later this year for rule changes!
 Two stroke sand mower/desert terrain mower (thinking about this build)
Clapped Out Ben
Clapped Out Ben
Two stroke sand mower/desert terrain mower (thinking about this build) Empty
PostSubject: Two stroke sand mower/desert terrain mower (thinking about this build)   Two stroke sand mower/desert terrain mower (thinking about this build) Icon_minitimeMon May 03, 2021 5:17 pm
Hi everyone I was thinking of making a two stroke pulley swapped mower out of a small lawn chief that had a 12.5 hp Briggs. The engine I am planning on putting in it is from a mantis rotor tiller. So it is a vertical shaft. I was planning on doing a 4 or 5 inch pulley on the front and a 2.5 or 3 inch pulley on the back as this is way this on my mudding/trail mower and does now have any belt slip. I was planning on taking this engine apart and porting it and polishing it and putting an expansion chamber on it. Do you think if I took my time on the shifting this motor would be able to handle it? I would also be taking the centrifugal clutch out and just welding a pulley to the crank shaft. Thanks!
