Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 5th 2022, 3:39 pm
Let me introduce foot throttle 2.0, it is not flimsy!
Nevadablue Established Member
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 5th 2022, 5:37 pm
Nice! More details required.
Age : 47 Join date : 2016-09-06 Posts : 8611 Location : Oklahoma
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 5th 2022, 7:21 pm
Base is 1.5x1.5 1/8th angle. 2 1/4 bolts though footboard holes. 3/4o.d. x 3/8 I.d x1 inch bushing welded to angle. 3/8 rod cut and welded into a z like pattern. Nuts welded to angle and z pedal to pull the cable. Pedal cover that use to be on red placed on pedal. Spring I found in a bucket for return.
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 5th 2022, 7:54 pm
Looks like a nice pedal, is it controlable? I had a throttle that would just shove your foot back from acceleration resulting in a surging driving pattern, yours looks like it wouldn't have that problem...
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 6th 2022, 12:10 pm
"MTD: Made To Die, Many Troubles Daily..." - Taryl
Brianator Veteran Member
Age : 43 Join date : 2019-07-02 Posts : 1140 Location : Ontario, Canada
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 6th 2022, 5:45 pm
It looks and sounds great Mighty, nice work!
Guess no Super Clean for me eh?! Lol. That's okay I prefer Spray Nine anyhow. What's interesting is they could mail a voucher anywhere for basically free....
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 6th 2022, 6:03 pm
Nice, the dark shots at the start of the video were pretty cool, I was feeling like the opening shots were a wee bit long, that or there needed to be a more substantial music track... Anyhow, great job on the tractor and the video, when are you starting your second BO project?
diddie Frequent Poster
Age : 55 Join date : 2016-10-02 Posts : 364 Location : Indiana
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 9th 2022, 5:09 pm
Great job on the video and the Dirty Rat ! I loved your opening bit.
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 9th 2022, 11:42 pm
I'm going to make another later an actual closeout of the B/O entry. Not the end of the tractor. I'm pretty pleased with it. The 2300 in this shifts a bit different than the other one I have. Little harder to shift on the fly, if at all. LOL It also wines a bit.
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 10th 2022, 12:08 pm
By shifting on the fly do you mean bump shifting? Like shifting with out the clutch or with the clutch?
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 10th 2022, 12:38 pm
Shfting with the clutch, but still rolling. Like you can do with a geared transaxle where your shift pattern is inline R-N-1-2-3-4-5(-6). Non "H" pattern trans like a older wheel horse, peerless 2300, 600, roper 633a, etc.
My other one I can shift most of the time without a gear grind. This one not so much. I still have to feel it out for the sweet spot.
I'm pretty sure it has to do with running the 7" engine and 4" trans pulleys. Takes a second for it to wind down.
Rustbucket Garage Established Member
Join date : 2021-01-15 Posts : 900 Location : Upstate New York
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 11th 2022, 8:59 pm
Maybe try double clutching? (Ie clutch, shift to neutral, clutch, shift to gear)
Might help to cut down on the grinding some.
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 11th 2022, 9:04 pm
That is kind of what I am doing now. I have a couple ideas, then again maybe just need some belt break-in time.
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 12th 2022, 6:48 am
That's what I was about to say, double clutching, but also I hear guys talk about "matching" where you match the RPM's from gear to gear, you can probably look up a video on how to drive a unsychronised trans
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 17th 2022, 11:48 pm
I decided to go ahead with changing the rear wheels to lugs. I bought some old 2300 hubs the other day on evilbay. We'll see how they work out!
diddie and Nevadablue like this post
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 24th 2022, 1:54 am
Installed the hubs and swapped the tires over to the 5 lug rims. I also brough in the tires about 1/2 inch.
Little struggle getting the tire off the old rim on the first one, but the second was pretty easy. I have 7psi in the tires, but I think I need to bring that down to 5psi. They are a little round right now. Wheel size is the same as the others.
I had about a 4 hour delay to do the second tire as we were tornado warned 2 times with another that didn't go warn until after it passed us.
This one just passed to the north of us. It was close to my wife's parents. Another was close to my parents as well. About 10 minutes later I could see power flashes that way due to it being much darker. If you look close enough just over the building in the distance, you can see a tiny finger hanging down.
Here is the second one that came right over the house. A third came even closer but was too weak.
Luckily none touched down near the house. The closest damage was about 10 miles away.
Brianator, Nevadablue and MN mudder like this post
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 24th 2022, 6:15 am
Glad y’all are ok. I’d certainly be biting my nails if I saw one of those twisters!
New rims look great!
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 24th 2022, 11:28 am
I grew up in tornado alley and am glad I am not there now. Glad you are all safe.
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 25th 2022, 10:34 pm
Had a few close encounters myself. can get a bit scary !
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 25th 2022, 11:50 pm
Took a little stroll today and I think either the clutch or idler pulley may need replaced. There is a pulley not happy somewhere. Will need to take care of that soon. I was thinking of putting the 4 on 4 hubs on the front but decided not to do that. I have the original wheels pretty dialed. That and they are actually easier to remove than the 4 lugs if needed.
Did some measuring.
Front axle 36" wide. Rear axle 41"wide. Length 76" long.
Subject: Re: [C] [22 BO] MightyRaze's - Dirty Rat April 26th 2022, 6:47 am
Uhhh, I think here you kinda are indoctrinated with the metric system, I always have to convert MPH to KPH But, yeah, I have the same "screaming pulley" problem, thought it was the trans before, it's quieter with the new one, but still screams, are you sure your input bearings are OK?
