PortalHomeSearchRegisterLog inDiscordBuild-Off
New Awards system! Look for your award at 500, 1000, 2500, 5000, 7500, and 10000 Posts!!!
 * [22 BO] diddie's Salvage
BigPip
TechnoChicken
Budget_gokart
Nevadablue
diddie
12 posters
diddie
* [22 BO] diddie's Salvage - Page 2 Empty
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 1st 2022, 10:42 pm
So i'm wondering if anyone has ran a chain to a counter shaft which will have a pulley to run to the rear end. which will let me use a shorter belt and should help prevent belt slippage. and make changing the belt easier ? i'm already in the process of doing it, just thought i'd see who else has done this. pics to come soon of what i've built, having issues loading pics right now.
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 6th 2022, 9:42 pm
solved my gas tank problem (which was i didn't have the original one ) but with a little ingenuity i was able to make the tank out of the john deere work under the seat as shown in these pics. and opened the opportunity to build me a dual battery tray that also is the skeleton to brace up my steering support/dash whatever you want to call it. and iv'e also been working on my chain to belt jack shaft and got that all sorted out.* [22 BO] diddie's Salvage - Page 2 Bo3710
* [22 BO] diddie's Salvage - Page 2 Bo3810
* [22 BO] diddie's Salvage - Page 2 Bo3910* [22 BO] diddie's Salvage - Page 2 Bo4010
* [22 BO] diddie's Salvage - Page 2 Bo4410
* [22 BO] diddie's Salvage - Page 2 Bo4210* [22 BO] diddie's Salvage - Page 2 Bo4111
* [22 BO] diddie's Salvage - Page 2 Bo4311                        hoping to get some decent weather this week to take the frame and the JD front clip to the car wash and get them cleaned up so i can get them joined together and get it back into a roller so i can start focusing on the power plant. was planning on a 22 hp briggs but i also have a couple 23 or 24 hp kohler commands i'm thinking about.
2022 Build-Off Finalist
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 6th 2022, 10:31 pm
Nice work! Looks good AND strong!
My Tractors:
1969 MTD Seven Hundred (Running/Driving ~ Light Yard Duty)
1969 Bolens 1225 (194) "Mud Duck" (2022 Build Off Entry ~ Work In Progress)
1973 Cub Cadet 149 (Saved from Impending Doom ~ Tinkering In Progress)
1974 Bolens G10 (1055) (Running/Cutting/Snow Throwing ~ General Workhorse)
1984 Sears LT(V)11 "The Warhorse" (Offroad Trail Rig ~ Work In Progress)
1986 Roper LT110CR "Trailblazer" (Offroad Trail Mower Project  ~ Work In Progress)
diddie likes this post
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 10th 2022, 10:01 pm
Well we had some 40 degree days this week so i was able to get the frames pressure washed. At least good enough to get some work done.
* [22 BO] diddie's Salvage - Page 2 Bo4510
* [22 BO] diddie's Salvage - Page 2 Bo4610
the next pics you can see how the inside of the JD frame slides right onto the outside edge of the murray frame.
* [22 BO] diddie's Salvage - Page 2 Bo4710
* [22 BO] diddie's Salvage - Page 2 Bo4810
Next ground all my welding points down and clamped it together and flipped it over and welded it up.
* [22 BO] diddie's Salvage - Page 2 Bo4910
* [22 BO] diddie's Salvage - Page 2 Bo5010
then flipped it back over and removed the engine plate and welded it on the top side. should be pretty sturdy.
* [22 BO] diddie's Salvage - Page 2 Bo5110
at this point i decided to do a quick mock up to make sure i'm happy with how it's looking and due to the fact that i'm going to be using some 8 inch wheels with bigger tires on the front it seemed like it would put the front up to high. (don't want no Carolina squat going on here ) so i cut the front axle mounting channel out and notched out the frame to set it in a bit deeper. it was only an inch and a quarter but should be right where i need it. and a lot stronger.
* [22 BO] diddie's Salvage - Page 2 Bo5210
* [22 BO] diddie's Salvage - Page 2 Bo5310
* [22 BO] diddie's Salvage - Page 2 Bo5410
Murraymountain, Brianator and Nevadablue like this post
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 11th 2022, 7:43 pm
Today was front hub Friday ! with wanting to put 8 inch rims on the front and wanting bolt on so i don't have to fool with clips and grease. i pulled a couple of tires and wheels out of my hoard that came off of a snapper walk behind. to make them work i started with cutting the centers out of the 6 inch wheels
* [22 BO] diddie's Salvage - Page 2 Bo5510
* [22 BO] diddie's Salvage - Page 2 Bo5610
now to fit them to these three lug wheels
* [22 BO] diddie's Salvage - Page 2 Bo5710
to get them centered. i put the hub on a shaft in my vise and then i clamped a piece of metal to a brace above and spun the wheel around and adjusted it till it was centered on the hub.* [22 BO] diddie's Salvage - Page 2 Bo5810
then i marked the holes and drilled them on my drill press !* [22 BO] diddie's Salvage - Page 2 Bo5910
then installed the studs and bolted them to the wheels and welded the studs in place and got them mounted on the axle ! and i am pleased with the ride height and width of the front.* [22 BO] diddie's Salvage - Page 2 Bo6010
* [22 BO] diddie's Salvage - Page 2 Bo6110
* [22 BO] diddie's Salvage - Page 2 Bo6210
MightyRaze, Brianator, Rustbucket Garage and Nevadablue like this post
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 11th 2022, 8:04 pm
Very nice! I'm planning on doing the same thing on the rear of The Warhorse so I can run the ATV wheels I have. Nice to see you making progress!
My Tractors:
BigPip
BigPip
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 20th 2022, 8:01 am
I did this to my build, here is a link:
Lt150
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 20th 2022, 7:14 pm
@BigPip Thanks for sharing. it looks like you went belt to belt on your jack shaft. i'm going chain to belt. They say you aren't  supposed to run a chain vertical but some say it can be done, just puts more wear on the sides of the gears. i'm gonna roll with it and keep chain lube on it. even if i have to swap out the gears now and then it's no big deal !
BigPip
BigPip
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 20th 2022, 7:24 pm
I must not have updated the photos, it is chain now on the lower/transmission side. I'll take some picture tomorrow and update my thread.
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 20th 2022, 7:52 pm
got busy sorting out my steering this past week. found some steering rods with 3/8s heim joints off of a cub cadet i1050 zero tractor i had in the hoard.
* [22 BO] diddie's Salvage - Page 2 Bo6310
i used them and incorperated them with the original steering rods. you will have to unbolt them to adj. but once the toe is set, should be good to go.
* [22 BO] diddie's Salvage - Page 2 Bo6410
* [22 BO] diddie's Salvage - Page 2 Bo6510
* [22 BO] diddie's Salvage - Page 2 Bo6610
everything clears and seems to work as it should. Next i cut out the top of the dash where the gas tank used to be to make easier access to the dual batteries i'll be running.* [22 BO] diddie's Salvage - Page 2 Bo6710
Now it was time to nail down the power plant, i was up in the air between a Briggs and a Kohler. The Briggs won because it was easier to get to and less work because it was already removed LOL!.
* [22 BO] diddie's Salvage - Page 2 Bo6810
had to remove the engine mounting plate and position it back about 4 or 5 inches to get the engine back where it needed to be since i had put the JD frame further forward to get that front axle out there where i wanted it.
* [22 BO] diddie's Salvage - Page 2 Bo6910
* [22 BO] diddie's Salvage - Page 2 Bo7010
then started playing around with a front bumper to see how it looks. i've got some others to look into so no final decision on that yet.* [22 BO] diddie's Salvage - Page 2 Bo7110
* [22 BO] diddie's Salvage - Page 2 Bo7210
Till next time that's all i've got for now. Oh since i moved the rear end back a bit and the axle forward i'm at approximently 52 inches axle to axle. but i don't know what it was when it was stock. if someone that has a wide body that is still stock length could you give me a measurement ! Thanks
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 20th 2022, 7:56 pm
So sounds like you went belt from engine to jack shaft and chain from jack shaft to rear end. i'm doing it the other way around LOL.
Nevadablue
Nevadablue
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 20th 2022, 10:12 pm
Just curious why the chain? Because of the clutch? Sorry, I missed this in the thread.
I made a belt to belt jackshaft from a mower deck spindle. Hope it works, hasn’t been run yet, but the same thing would work with a chain.
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 21st 2022, 7:21 am
@Nevadablue running a chain from engine to jack shaft where it goes around the steering shaft so it will be less work to change the belt. aka you wont have to take the steering shaft loose and pull it up. no slippage with the chain either. and that makes for a shorter belt as well which in my eyes will be less chance of slipping.
Nevadablue likes this post
Nevadablue
Nevadablue
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 21st 2022, 4:23 pm
Thanks! Makes sense.
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 25th 2022, 3:42 pm
gonna be doing some fab work to get the hood sorted out this weekend. but in the mean time i got some switches i ordered in the mail today for my dual battery set up !
* [22 BO] diddie's Salvage - Page 2 Img_2013
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 27th 2022, 11:47 am
Lol, we're both doing the same thing with the battery relocation. Great minds think alike!
I'll check Ole Blue's axle to axle length in a bit when the rain quits and let you know!
EDIT: I measured the one I'm flipping to sell. Completely stock aside from a motor swap. Looks to be about 48" from the center of each axle. That's not exact but pretty close.
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 27th 2022, 6:39 pm
Thank you sir. looks like about a 4 inch streach i've got which is perfect as i didn't want to go to much. and yah i like the battery close to the engine and dash so shorter cables and wiring !
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 27th 2022, 9:19 pm
Well after a lot of staring and back and forth in my head i finally figured i'd make the hood a front lift. and just let me say i don't know anything about figuring angles or geometry. i'm strickly trial and error !
So to make the brackets i would need i started by making a dash and hood out of cardboard and made a piece to connect them with a pivot point, and then hacked away at it till it seemed to be what i was looking for.
* [22 BO] diddie's Salvage - Page 2 Bo7310
then i transferd that to some 1/4 inch plate steel i had kicking around to cut out my brackets.
* [22 BO] diddie's Salvage - Page 2 Bo7410
* [22 BO] diddie's Salvage - Page 2 Bo7510
Let me just say a plasma cutter would have been nice to have at this point ! cut off wheels die grinders and flap discs along with about two hours got it done though !
 So then i welded some nuts inside the dash for them to be bolted to with some shoulder bolts,  then welded a bracket to the inside of the hood to attach them to.
 so with the hood in place and me upside down crawled up into the engine area with a welding helmet on and holding the brackets in place i some how managed to tack them in place good enough to hold them in place then i removed the hood for final welding.
* [22 BO] diddie's Salvage - Page 2 Bo7610
after a full weld and some paint i reinstalled it and to my surprise IT WORKS !* [22 BO] diddie's Salvage - Page 2 Bo7710
* [22 BO] diddie's Salvage - Page 2 Bo7910
MightyRaze, Murraymountain, Brianator and Nevadablue like this post
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 27th 2022, 9:26 pm
That's awesome nice work! I love it!
My Tractors:
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 27th 2022, 9:32 pm
* [22 BO] diddie's Salvage - Page 2 Bo8011
* [22 BO] diddie's Salvage - Page 2 Bo8111
I also got my switches installed for my dual battery set up. you will be able to use batt 1 batt 2 or both at the same time. it seems like murray made this removable panel just for this. lol but seriously that was an awesome thing to do with this removable panel. some engineer was using his head.
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 27th 2022, 9:33 pm
Nice work! I imagine that will make engine maintenance a lot easier. I love the dual battery idea Smile
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 27th 2022, 9:38 pm
@Brianator Appriciate it sir ! i was pretty pleased with it. had my wife come out and see it (even though she don't give 2 S#!@s about it) and she gave me a pat on the back ! and then said can i go back in now !! lol.
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 27th 2022, 9:42 pm
@Rustbucket Garage sure thing ! everything is right there for easy access. working on figuering out some hood lift supports next but if that don't work out due to space, a hood prop will get the job done.
Nevadablue
Nevadablue
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 27th 2022, 10:07 pm
Nice job on the hood. I’ve never seen one done like that.
Those switches you used on the battery setup are good stuff. I used them on heavy equipment when I was a wrench turner, long ago. I bought similar ones for my builds now, but they have the ‘key’ that comes out, so you can turn off the battery and take the key away if you want.
diddie and TechnoChicken like this post
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeFebruary 27th 2022, 10:11 pm
@Nevadabluethanks it took me a while to decide if i was going to be able to make it work . but i'm glad i pushed through on it.
diddie
diddie
PostSubject: Re: * [22 BO] diddie's Salvage   * [22 BO] diddie's Salvage - Page 2 Icon_minitimeMarch 9th 2022, 9:25 pm
Not a lot of progress since last update. been working on my hood prop situation
* [22 BO] diddie's Salvage - Page 2 17110
in this first pic. i made a bracket to attach to the top of the hood to hook the hood strut to. the strut in the pic was way to short. part of the reason for very little update. as i need this done before i can break it down to do all my final welding and a bit more fab work.
* [22 BO] diddie's Salvage - Page 2 23210
* [22 BO] diddie's Salvage - Page 2 23311
After a couple trips to the junk yard and some trial and error i managed to make this thing work.  cheers
unfortunatly the winning strut is weak and just bearley holds it up ! But i know what it came off of and ordered a new one and will have it in about a week. But with that done i can move forward !
Brianator, Nevadablue and FatMike like this post
Page 2 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» Bought this at the salvage yard. Ideas anyone?
» Salvage Electric Golf Cart
» Help finding junk/salvage yards?
» Diesel Jeeps!! Southern Tractor Service and Salvage
