New Awards system! Look for your award at 500, 1000, 2500, 5000, 7500, and 10000 Posts!!!
 *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder
Budget_gokart
Rustbucket Garage
MN mudder
Nevadablue
TechnoChicken
diddie
14 posters
Go to page : Previous  1, 2, 3 ... 9, 10, 11
diddie
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Empty
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeJuly 18th 2022, 10:01 pm
Looking forward to seeing that paint job ! and nice pick on that steering wheel.
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeJuly 19th 2022, 8:52 pm
Thanks @diddie and I plan on getting back to work on it soon!
diddie likes this post
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeAugust 7th 2022, 4:16 pm
Brianator wrote:
@diddie I hear ya! I've never seen any THAT bad either!
Well, I've got a little tinkering done the last couple days!
I replaced the rod ends on the tie rod for pretty cheap ($23), cleaned it up and hit it with some bedliner...*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220597
...and replaced the control shaft seal so no more leaky hydro!
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220598
The power grid in my area is overloaded with it being the weekend in cottage country and everyone running their ACs to stay cool (been 86F the last few days) so I can't weld new rod ends on the drag link yet but I was looking over the rest of the steering and noticed the lower bushing at the steering gear is thrashed so I'll have to look into that soon.
Yesterday my neighbor @CodeRed and I were bombing it around my yard and testing it over some obstacles and stuff, the tractor itself was doing really well but the engine started acting funny and I lost throttle control but everything is hooked up the way it was. Turns out the governor (and arm) stuck in the idle position so I'm not sure what that's about but I've reset it and will hopefully test it out tomorrow!
Sorry for the weak update but it's still progress! Lol
How’d that contaminated fluid ordeal work out for the hydro?
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeAugust 7th 2022, 4:24 pm
Good, its been good ever since I replaced the fluid and the weather warmed up, I'm convinced that the fluid absorbed condensation created by the temperature differences or that maybe there was just ice that melted and got absorbed by the fluid.  I'm hoping for the latter because I'd like to use it for snowblowing duty this coming winter.
How's your situation with aerated fluid?
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeAugust 7th 2022, 4:50 pm
Still the same as of march (last time the tractor ran).
I’m almost wondering if the control seal is causing the leak, but I don’t know. I’ll be giving the hydro system a once over here once the engine and FA are done.
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeAugust 28th 2022, 8:27 pm
This isn't as much of a update as it is a heads up I'm gearing up to get back to work on this rig, still lots to do before the weather turns and I've been putting it off too long.
I did order a new fuel nozzle that should take care of the engine starting to run lean when it's hot, I believe the replacement carb was designed to run mainly on smaller displacement engines but it's all good this should solve it.*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220963
The major things on the to do list are
- Make a new front clamp plate that will double as a spot to mount the front bumper/winch plate
- Finish front bumper/winch plate
- Install and wire winch
- Trim motor plate so I can run a PTO belt behind the drive belts
- Paint, lots of time will be eaten up with bodywork and paint!
I'm looking forward to making more progress on this old girl!
MightyRaze, diddie and Rustbucket Garage like this post
diddie
diddie
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeSeptember 8th 2022, 9:35 pm
@Brianator wondering if you've been working on that paint job ? can't wait to see how she looks !
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeSeptember 8th 2022, 9:47 pm
Your timing couldn't be better man, I had just been thinking up and making a to-do list of things I want to accomplish before the Build Off closes and paint just happens to be very high on that list!
Sadly, I'm going to leave you and everyone in suspense for the most part until right near the end, I'm planning a teaser and alot of sneaky shots to avoid giving too much away until then...
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Drevil10
diddie
diddie
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeSeptember 15th 2022, 9:43 pm
@Brianator UH I'm kinda doin the same thing lol. i just have a hard time not sharing !
fbisurveilancevan
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeSeptember 15th 2022, 11:04 pm
This is exactly why I wouldn't ever do a build off.
I actually thought about converting a zero turn into an offroad 2x4 dual engine tank but now I already said too much.
diddie and Brianator like this post
TechnoChicken
TechnoChicken
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeSeptember 17th 2022, 11:22 am
I have toyed with that idea too, there was some guy selling something like that on kijji
fbisurveilancevan
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeSeptember 17th 2022, 4:21 pm
Offtopic I know but you could take 4 hydraulic motors, mount them like on a Ferris 3000 with suspension and run them off of one comically big engine and 2 or 4 pumps.
Mount a forward reverse pedal on either side and retain the steering wheel aswell or simply add another set of hydraulic motors in the front.
My expertise is in hydraulics mostly and I would love to do something like that but I didn't have the urge yet.
Tidbit tip: you could literally bolt 2 Ferris is3000's ass to ass to each other and cut the rear one off after the motor mounts. The mounting holes are there already, just need a few bolts and reverse some hoses
Since I have 2 I already thought about that  jocolor
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeSeptember 19th 2022, 9:06 pm
Apparently I do too but for once I'm going to be sneaky about it!  Lol
Well, I got myself motorvated to get back to work on it! First thing I want to do is build the bumper/winch plate so I removed everything that was going to be in the way of making a new front frame clamp that will double as the bumper mount by wrapping down the front and sides of the axle mount.
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220964
That top clamp plate was so messed up and uneven that I had a feeling the frame tubes were crushed... boy was I right sad to say! *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220965
Luckily my exhaust tubing expander is the perfect size to start working them back in shape. *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220967
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220966
Once I've welded the cracks I'll use the tubing expander and a hammer again to get them more perfect. The plan from there is to weld in some sleeves for the bolts to pass through so I can crank down on them without crushing them, I need it to be strong for this 700+ pound beast!
Now that I've gotten a start I'll be able to keep picking away at it!
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeSeptember 19th 2022, 10:02 pm
Very nice... there has been a few times a set of expanders would have been nice!
Tractors:
Dirty Rat - 77 Sears Suburban
Li'l Red Part1  Current - 89 Murray Widebody
"MTD: Made To Die, Many Troubles Daily..." - Taryl
fbisurveilancevan
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeSeptember 20th 2022, 1:08 am
Yeah I'll put those on the shopping list now for sure.
Nice work
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 Icon_minitimeOctober 2nd 2022, 7:55 pm
I made a little progress this past week, not a whole lot but it's better than none!
With the front axle mount on the bench I made a cardboard template for the new top clamp/bumper mount.*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220987*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220988
Then I transferred the template to 1/8" steel. *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220989*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220990
Cut it, scored it, bent it and welded it...*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220992*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20220991*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20221010
... ground it, shaped it and painted it! *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20221011*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20221012
Now I need some 3/8" threaded rod, weld sleeves in the frame tubes and paint that all up while it's easy to get to.
As I was cleaning the grime off the axle mount I found some of the original paint and primer! I only scraped off the loose stuff and left the rest for good luck!
Lol  *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20221013*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 11 20221014
That's all for now, hopefully I can get a little bit more done this coming week and it back on its wheels this weekend!
Page 11 of 11Go to page : Previous  1, 2, 3 ... 9, 10, 11
» finished with the snow recovery tractor
» new mudder/work tractor
» 6X6 150 speed ultimate mudder/rescue tractor
» * [22 BO] MN MUDDER Wheel Horse Pulling tractor "HORSE N AROUND"
» New Mower Riders of America Vid 4 mowers romping at duck creek
