New Awards system! Look for your award at 500, 1000, 2500, 5000, 7500, and 10000 Posts!!!
 *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder
Budget_gokart
Rustbucket Garage
MN mudder
Nevadablue
TechnoChicken
diddie
14 posters
Go to page : 1, 2, 3 ... 9, 10, 11  Next
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Empty
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeJanuary 29th 2022, 2:21 pm
The Dollar and Cents
I like to keep track of what my builds cost so this post is dedicated to how much I've got in it, keep in mind several of these items I already had "in stock" but am still adding their worth even though they weren't bought specifically for this build, also if I only used 1 or 2 of several items the price is adjusted to show only what I used. Prices are in Canadian funds, tax included and rounded to the nearest half dollar.
***PRICES OF PRODUCTS ONLINE ARE SUBJECT TO CHANGE***
$100 for the Tractor (price based on a portion of the package deal)
$50 for the 16hp Briggs and Stratton single
$50 for a new carburetor https://www.amazon.ca/dp/B08LQXC3L7
$20 for 2 brand new 8" turf tires for the front (part of the package deal)
$11 for a test belt (bought locally)
$45 for idler pulley (bought locally)
$28 for belts (bought locally)
$4.50 for a spark plug (bought locally)
$12 for the choke cable (bought locally)
$14.50 for the start and horn buttons https://www.amazon.ca/dp/B07F9R1L3B
$10 for the relays https://www.amazon.ca/dp/B0748F1JK4
$5 for the illuminated saftey flapper switch https://www.amazon.ca/dp/B01GPAXSQG
$18 for the 6 toggle switches https://www.amazon.ca/dp/B07M5GGXTV
$15 for front wheel bearings https://www.amazon.ca/dp/B07H4RSV6Z
$22.50 for the Ford starter solenoid (bought locally)
$176 for a brand new AGM battery (bought locally)
$28 for the fuse box https://www.amazon.ca/dp/B089NQQPRW
$3 for waterproof wire harness https://www.amazon.ca/dp/B07FJPMML6
$44 for the pair of mufflers https://www.amazon.ca/dp/B000LL9MGQ
$32 for the fire extinguisher (bought locally)
$37 for the fire extinguisher mount https://www.amazon.ca/dp/B08DHDMGZB
$32 for the steel for the reserve fuel tank bracket and muffler (bought locally)
$10 for the battery disconnect switch https://www.amazon.ca/dp/B07Y2Q16WW
$20 for Honda TRX front ATV rack
$30 for the airhose and fittings for the tire inflator (bought locally)
$23.50 for the 3 way fuel valve https://www.amazon.ca/dp/B09MCXQ462
$15.50 for the hood pins https://www.amazon.ca/dp/B08F9CN3H6
$23.50 for the fuel pump https://www.amazon.ca/dp/B01M7S3ZSB
$4 for 2 Honda fuel tank fittings (with built in filters) https://www.amazon.ca/dp/B083XZVJW4
$10 for the one way fuel valve https://www.amazon.ca/dp/B08H555WMH
$14.50 for the air filter https://www.amazon.ca/dp/B01M1IDMNB
$29.50 for the front and rear LED lights https://www.amazon.ca/dp/B07VV2X9VS
$45 for the used trailer hitch assembly and various metal (bought at salvage yard)
$22.50 for the wheel spacers https://www.amazon.ca/dp/B08JLJPW5N
$30 for the wheel "studs" (7/16-20 TPI Grade 8 bolts -bought locally)
$43 for the Simplicity wheel nuts (bought on eBay)
$537 for the front and rear Kenda Terra Trac tires (bought on eBay)
$60 for the new-ish rear wheels (bought from a friend)
$16 for the hood pins https://www.amazon.ca/dp/B08F9CN3H6
Total - $1691.50 as of May 21st, 2022
Free Items:
- The original seat from my Bolens G10
- Wiring
- Voltmeter
- Motor plate - 1/4" (from the Line Ward)
- New/Used Throttle Cable (found in my stash)
- GX200 fuel tank
- Pilot/Warning light
- Tire Inflator
- 3000lb Champion Winch (thanks to the Ontario government vehicle registration refund). $230 dollar value
- Front and rear toolboxes
- Various metal used to make brackets/shields/guards ect.
- Front 8" wheels from? (My friend gave them to me a couple years ago)
Weights and Measures
After learning how much the tractor weighs in stock form I thought it would be neat to keep track of the weight best I can as I build it up so here goes nothing!
675lbs - Bolens 1225 in stock form
+20lbs - B&S 16hp vs. Wisconsin TRA12D
-5lbs - Smaller than stock battery
+20lbs - Winch plus accessories
+5lbs - Toolboxes and Rack
725lbs total as of March 8th, 2022
7" of advertised rear ground clearance
Nevadablue and MN mudder like this post
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeJanuary 29th 2022, 9:11 pm
Nice...  That will add up quicker than you think!  Everything on dirty rat up to this weekend has been free or I had stored somewhere.  (minus welding rods purchased last week) That changes next week with my heims.  It's only going up from there.
Nice list of things you would like to do!  I always do lists, but for once I'm kind of winging it.  LOL
Tractors:
Dirty Rat - 77 Sears Suburban
Li'l Red Part1  Current - 89 Murray Widebody
"MTD: Made To Die, Many Troubles Daily..." - Taryl
Brianator, Budget_gokart and TechnoChicken like this post
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeJanuary 29th 2022, 10:01 pm
Ya it will! Lol. The good thing is I have 2 ATV frames plus a wack of parts, a pocket bike frame, a scrap BMX, the Line Ward, a scrap snowblower, a bunch of various shapes and sizes of metal to work with, a small bucket full of wiring and probably 50 pounds of hardware so that will all help keep the cost down!
As for "The Plan", I usually just wing it (like with The Warhorse ) but for once I wanted to come up with an actual "plan". I say "plan" because it's very fluid and subject to change! Lol
MightyRaze, Nevadablue and MN mudder like this post
diddie
diddie
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeJanuary 30th 2022, 6:48 pm
i've always been a fan of the old Bolens my Dad still has one in his shed that he has had since i was about 2 years old. and i'm 54. can't wait to see how she turns out.
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeJanuary 31st 2022, 10:30 am
I hear ya!  The first time I saw a tube frame I instantly loved it,  after some research on them I was hooked! A couple years later I finally ended up wearing my friend down and we made a deal for that tractor (G10), it's been great and hasn't given me any trouble!
I got the motor to give me a sign of life yesterday but what a fight to get to that point! Clean the gas tank, completely overhaul the sediment bowl and carburetor... I've never seen so much aluminum corrosion before it was nuts but pure white vinegar to the rescue!  Lol. The ignition points needed to be removed and cleaned up really well too.
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220173
It would basically just run for a few secs then quit and then it decided not to start at all after a few times so I obviously have more work to do and doubt a new carb will be the only answer!  I do have to say once it started and was running,  it was running pretty smoothly and feels like it has lots of compression so that's very encouraging!
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeJanuary 31st 2022, 3:25 pm
Well for once I'm glad I was wrong! Lol. I put the replacement carburetor on it, got it to fire and stay running for 5 mins before I shut it down so I guess the old carb is either too far gone or more crud found its way in. I think I'll tear into again at some point, it would be good to have a working spare.
You can find a link to the new carburetor by clicking here!
TechnoChicken
TechnoChicken
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeJanuary 31st 2022, 5:21 pm
I think this might just turn into a pretty sweet rig, i'm watching her!!!
What trails do you ride on? are they on you property or else where?
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeJanuary 31st 2022, 5:40 pm
Thanks man! I'm hoping so too! I don't have trails on my property, I only have about 1/2 acre in a cottagey area (close to the lake) but just a couple minute drive down the road from me there's part of a HUGE trail system.
So the motor is freed from it's prison, man this thing is big and HEAVY! I'd like to actually weigh it but I'll guess it's close to a hundred pounds! *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220174
I'll tinker with it and clean stuff up while it's on the bench  but the next main thing will be mocking it up in the tractor so I can build a motor mount for it, I'm not looking forward to slugging this thing around much! Lol
Nevadablue likes this post
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeJanuary 31st 2022, 8:42 pm
It's probably around 100 lbs. I weighed some various engines before and Briggs opposed twins are about 100 if I remember right. So that's probably close with that starter/generator.
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeJanuary 31st 2022, 8:52 pm
With the starter generator on there, I'm sure that adds a good amount too.
Tractors:
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeJanuary 31st 2022, 9:13 pm
It's hard to believe it could generate spark with so much corrosion on the magnet! The coil wasn't so bad though.
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220176
So I cleaned it all (plus all the contact points and wire connections)
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220177
A little something I like to do is put a thin layer of dielectric grease on everything, more of a film really so I have done that as well and expect the old beast to run even better than it did today!
MightyRaze, Rustbucket Garage and Nevadablue like this post
Nevadablue
Nevadablue
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeJanuary 31st 2022, 9:37 pm
That is a sweet engine.
MightyRaze, Brianator, Rustbucket Garage and TechnoChicken like this post
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 1st 2022, 11:51 am
I agree! I'm very fortunate to have got such a great deal on it!
Well this explains it... should help hold the front wheels down! Lol
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220210
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 1st 2022, 11:55 am
Wow, that say 143?  That's crazy.  Can't beat old iron!
Tractors:
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 1st 2022, 12:16 pm
Especially when it's all old cast iron! The only aluminum on it is the cylinder head, carburetor, coil mount, magnet mount, front plate and booster fan! Lol. I don't even have to use a compression tester to know it's got plenty, it bounces hard off it when it's shut down so she seems to have tons of life left! It even already has the double belt pulley to match the tractor AND its the exact same size as stock but I will have to source a new slighter smaller double pulley to run the PTO and there just happens to be plenty of room on the shaft to do so! I've gotten very lucky, it's almost like it was destined to be!
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220211
Well I guess it's time to remove that little test motor and start mocking this thing up!
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 1st 2022, 12:34 pm
I'll pray for your back as you start to mock it up.  Maybe a hoist could help.
affraid
Tractors:
Nevadablue
Nevadablue
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 1st 2022, 4:04 pm
There is a single cylinder engine sitting in a lot in this subdivision. I guess I better ask about it. Could be a treasure.
Fun to watch this develop. Buy a crane.
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 1st 2022, 10:21 pm
Thanks @MightyRaze and I wish @Nevadablue, even if I had one it would be completely useless to me here unless it was attached to a machine with wheels, I can only work on it outdoors as you can see in the first photo. What I've done is put a bench beside the tractor so I can more or less slide and quick lift it back and forth and then one big heave at the end of the day to get it back on the workbench. Yes it's heavy but it's also awkward! Lol.
I did make some decent progress today! I pulled the test motor out and plopped the big guy in to get an idea, looks pretty good in there!
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220212
No I won't be using that wood as the motor plate, that was just to get the test motor in there, I'm going to use the motor plate out of the Line Ward, it's 1/4" thick and the mounting holes are already there so that's a bonus
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220213
Even when it's sitting on it's proper mounting plate which is lower than that chunk of wood I'm sure I'll still need to work on the hood to make clearance for the the head/spark plug and will definitely need to relocate the fuel tank and do something about the exhaust.*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220215
This large angled support had to be cut off but I wanted to get a move on and figure out belt(s) length so I set it on a piece of 1/2" plywood (no picture), used some rope, came up with 32" and headed into town to grab some cheap belts (31" & 32") for $10 each, an idler pulley and some grade 8 hardware. I feel the cheap belts will be perfect for testing, polishing the pulley grooves and to keep as spares,  I'll buy quality ones when the time comes. I cut the angled piece off after I got home.
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220214
I still need to trim the ends off but I wanted to do some more alignment and figuring, Houston we may have a problem...  Here's my dilemma, the plate actually sits beautifully on the frame, and I can slide the pulley back for belt alignment plus it lets the motor sit as low as possible so that's all good but with the motor sitting in that location there won't be room for another set of pulleys on the engine to drive the PTO. Look at how nice the plate sits as is, let's call this this "option A"
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220217
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220216
"Option B" would be to slide the plate back, partially on top of the front clamps (which are 1/8" off height wise from one side to the other for some reason? so that adds another needed solution) and then have to add a spacer on the other end of the plate. This not only raises the center of gravity but also puts more weight forward and onto the front tires. I'm not liking "option B", seems sketchy and a pain in the arse! *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220218
"Option C" is to figure out exactly how much I need to move the front clamps forward and extend the (tube) frame that amount, that comes with yet another issue... the front PTO is attached to the front end! If I tried to space it backwards then the universal joint for the front attachments would either not reach or just barely reach... neither of which are good.
"Option D" is to "Keep It Simple Stupid!" Yknow, the KISS principle?! Lol. Go with "option A", keep options B and C in mind when altering the hood, relocating the fuel tank and reworking the exhaust. I know it sounds silly to care about the front PTO for a recovery rig/mudder but I've been secretly excited to be able to put the Snowcaster on it! My G10 runs it but struggles sometimes, it was never designed to run a 38" unit.
What would you do if you were me? Keep in mind I'm also working on stuff for The Warhorse in the background and plan on getting back into the actual build very soon, if I only had this one on the go no problem! Lol
Sorry for the novel guys! I still have a couple hours worth of motor work to post but I need a break, this post took forever! Lol.
diddie
diddie
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 1st 2022, 10:29 pm
@Brianator WOW ! i thought i had it bad here in Indiana WITH a heated work shop !! i feel for you man it can't be easy working in those conditions.
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 1st 2022, 10:37 pm
It was beauty out today, around 16F and sunny! Last week was a little tougher hovering around -5F but I'm so used to it from working outdoors most of my life, the key is to dress for it! Wear many layers and stay hydrated! I do have a small electric heater to warm my hands and a propane heater for when I close myself in the workshed, don't worry it's not well sealed so there's plenty of ventilation! Lol
diddie and Nevadablue like this post
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 2nd 2022, 12:24 am
Once it started to get too dark outside to work I turned my attention on getting more engine work done in the workshed.
I figured I should get the pulley free so I can clean up the shaft and it will make it easier for pulley relocation/add another set behind it. To my surprise it didn't put up much of a fight, not even the hub!
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220221
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220219
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220220
Then again I did start sprinkling it yesterday with my favorite penetrating oil, if you haven't seen or heard of this stuff trust me when I say you want to find it! It's the best I've ever used and it's really hard for me to come by, my first can lasted me almost 10 years I used it so sparingly and only when I knew I needed it! I didn't use very much at all and you can see in the above photos how well it penetrated. It's an American company (I'm pretty sure) and they had sponsored a Nascar team at some point so you have a better chance than me at getting some... if you do please let me know I want another can! Lol. But seriously...
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220222
Once I had the pulley and belt guard off I cleaned the front plate and noticed all these hairline fractures... I hope they won't be a problem! I think it's best for me to start poking around and see if there's any new(ish) plates to be found! Hope you can see them in the pic
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220223
I decided to have a look inside the voltage regulator, almost wish I hadn't that's nasty! Once the motor is mounted in the tractor I'll test it out but by the looks of this, it's only fit to be a spare IF it does still work!
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220224
Then I started replacing shotty wire ends, cleaning up and (dielectric) greasing all the connections.
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220226
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220225
This was about the time I realized my beer was almost empty so I shut 'er down for the night! Lol. It's been an eventful one, hopefully tomorrow is as well!
Nevadablue
Nevadablue
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 2nd 2022, 12:25 am
I can’t work (by choice, if I don’t have to) in the cold these days. Glad you can handle it, this is fun to watch.
You will need dual tires or those tracks on the front. Razz
Nevadablue
Nevadablue
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 2nd 2022, 12:29 am
Taper lock hubs are nice for removal. Expensive to buy, but positive lock.
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 2nd 2022, 12:33 am
I'm glad too or I'd get nothing done for 4 months of the year! Lol. Feel bad for you, you must be going stir crazy!?
Tracks you say... hmm.... nah not on this. That's an idea I've been tossing around for the derelict Cub Cadet, maybe next years build if I can find the parts over the summer!
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 2nd 2022, 12:36 am
No they're cheap as I learned today... look! I had to take a picture because I didn't believe it!
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220228
*c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 20220227
Now the idler pulley on the other hand....FOURTY freaking dollars for a 3" flat idler... not happy and shopping for another but I did grab it just in case I can't find another.
PostSubject: Re: *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder    *c [22 BO] Brianator's "Mud Duck"- Tractor Recovery Rig/Mudder  - Page 1 Icon_minitimeFebruary 2nd 2022, 1:06 am
GOOD LORD! That’s ridiculous! I payed under $15 for one at TSC about a year ago.
Page 1 of 11Go to page : 1, 2, 3 ... 9, 10, 11  Next
» finished with the snow recovery tractor
» new mudder/work tractor
» 6X6 150 speed ultimate mudder/rescue tractor
» * [22 BO] MN MUDDER Wheel Horse Pulling tractor "HORSE N AROUND"
» New Mower Riders of America Vid 4 mowers romping at duck creek
