Here’s my Broadmoor entry. I won’t do a huge write up for this one if you are going to merge it with my old thread. But let me know if I have to do anything else. Basically I almost have a rolling chassis. Frame is mostly done but the suspension needs to be finished. Still needs brakes, engine built, clutch, steering installed, fuel tank, battery, pretty much everything. Thanks.
Approved - Jan 15, 2023 MightyRaze
Previous Entry "HERE" and then continued in Build-Off [22] "HERE"
[adm]Welcome to the 2023 Build-Off @mr.modified[/adm]
@mr.modified is taking advantage of re-entering using this years' 75% or less reentry rule! Good luck,
@mr.modified just continue the build in this topic. When this year's build-off is over, I can merge the previous 2 threads for this build together and this topic into one continious build topic. To make sure everything stays chronological, the previous 2 topics are locked.
Well back at it for the time being. We'll see how things go.
I did get a couple minutes on it tonight. Next thing I needed to do with it was fabricate the panhard bar. I have the bolt welded on the axle and the extended piece on the frame for the other side.
Rather than buy new billets for the heim joints, I cut the old ones back out of the IFS setup that I had built a few years back.
Been quite awhile since I've been on this project. Maybe this year will finally be the year it gets done!
