 [23] Wheel Horse C-81 Build Off 2023
Mowers Gone WILD!
Mowers Gone WILD!
[23] Wheel Horse C-81 Build Off 2023  Empty
PostSubject: [23] Wheel Horse C-81 Build Off 2023    [23] Wheel Horse C-81 Build Off 2023  Icon_minitimeJanuary 30th 2023, 3:16 pm
#Buildoff2023
I am building a c81 wheel horse, putting a 670cc
with original transmission, but welded diff. Will be uploading all the build videos as well to our YouTube channel/Mowers Gone WILD. I will update here often as well, glad to be part of the form and build off.
[23] Wheel Horse C-81 Build Off 2023  20230110
Approved - Jan 30, 2023 MightyRaze
https://www.mowersgonewild.com/
PostSubject: Re: [23] Wheel Horse C-81 Build Off 2023    [23] Wheel Horse C-81 Build Off 2023  Icon_minitimeJanuary 30th 2023, 4:33 pm
[adm]Welcome to the 2023 Build-Off!![/adm]
Danceparty
[23] Wheel Horse C-81 Build Off 2023  Sig110Tractors:
[23] Wheel Horse C-81 Build Off 2023  Sig210[23] Wheel Horse C-81 Build Off 2023  Sig310
PostSubject: Re: [23] Wheel Horse C-81 Build Off 2023    [23] Wheel Horse C-81 Build Off 2023  Icon_minitimeJanuary 30th 2023, 6:04 pm
Welcome to the ATLTF and the Build Off! I look forward to following along!
My Tractors:
1969 MTD Seven Hundred (Running/Driving ~ Light Yard Duty)
1969 Bolens 1225 (194) "Mud Duck" (2022 Build Off Finalist ~ Work Still In Progress)
1973 Cub Cadet 149 (Saved from Impending Doom ~ Tinkering In Progress)
1974 Bolens G10 (1055) (Running/Cutting/Snow Throwing ~ General Workhorse)
1984 Sears (MTD) LT(V)11 "The Warhorse" (Offroad Trail Rig ~ Romping In Progress)
1984 Sears (MTD) LT(V)11 "Silver Bullet" (2023 Build Off Entry ~ Work In Progress)
1986 Roper LT110CR "Trailblazer" (Offroad Trail Mower Project  ~ Work In Progress)
Mowers Gone WILD!
Mowers Gone WILD!
PostSubject: Feb 2023 Progress Report   [23] Wheel Horse C-81 Build Off 2023  Icon_minitimeFebruary 14th 2023, 12:02 am
Ok I been making a lot of progress, I will need to learn the best practices for this forum, being I video almost everything and very little pictures.
So the 670cc is mounted on my custom mounts I welded to the rails.
[23] Wheel Horse C-81 Build Off 2023  20230210
Made a custom rod to make clutch and brake work on a single pedal, so i can use the right pedal for a throttle.
I have put Sun F 24"s in the rear, and Bear Claw 22"s in the front.
I plan to run original front end and spindles, they are 3/4", I bought 4x4 pattern hubs, with insert bearings that I ordered 3/4" bearings for. They are seeming like they will work great!
[23] Wheel Horse C-81 Build Off 2023  20230211
I had to customize my rims I had from another build to work with the 4x4 pattern as they were 4x110mm. I welded a big washer in the center, and drilled the current hole pattern. I seem to get everything very close to true.
[23] Wheel Horse C-81 Build Off 2023  20230212
Now learning I need to move the motor back farther towards the console, being the tires rub the very side corner by the flywheel, I believe moving motor back 3" will clear all my troubles. Been a real process, So much more I have done. I will do my best to create more write ups as I go. I am posting weekly or close to on our youtube, if you want full length videos as well.
https://www.youtube.com/watch?v=AIv33FDuPWc&list=PL5f899v9cpIW1t20mHLLbME-K9mAo1kW7
MightyRaze, RichieRichOverdrive and Brianator like this post
PostSubject: Re: [23] Wheel Horse C-81 Build Off 2023    [23] Wheel Horse C-81 Build Off 2023  Icon_minitimeFebruary 14th 2023, 12:07 am
I used to just screenshot my videos for easy pics. Works pretty well if you catch a clear frame. Also I completely eyeballed the hubs I made for the 4x110 wheels on the front of Mutt. Like, had a rim setting on the bolts on the hub and spun it to see it was half ass true and just welded it solid. Worked great!
Looks like you're coming along strong!
MightyRaze and Mowers Gone WILD! like this post
Mowers Gone WILD!
Mowers Gone WILD!
PostSubject: Update for The Last Month   [23] Wheel Horse C-81 Build Off 2023  Icon_minitimeMarch 15th 2023, 1:22 pm
Sorry I missed my goal of within 30 days updating, I will do a more in-depth update later this week.
I got the motor all the way back now, this was to give the clearance needed for the 22" tires in the front, and the big turning ratios the wheel horse has. The wiring is all setup with the new panel I got off amazon to make this a toggle and push button start.
The front wheels are very close to being ready to go, I need to still tack and weld the washers to the rim, as that will keep the rim true. As the last post I used Go Power Sports hubs for the front, and had to customize the rims I had.
The exhaust I knew would be tricky, but I think I got it worked out, Matt and I looked it over, and I did all the fab and welding last night. The slip on muffler will be in today, but the header and collector is welded and good to go.
[23] Wheel Horse C-81 Build Off 2023  Screen10
I also made some much needed changes to the clutch setup, Charle Horse the wheel horse, had a great video on youtube, I took some advice and points he made. Then made my own setup, hopefully it will be pretty dialed in right away. I make full length videos for anyone wanting to see the progress in video form, I will take more screen grabs and write up some of the finer details, but that is the nut shell of the last month. It will be running and driving by end of the month, mark my words haha, doesnt mean it will be 100% but much closer and can find weak points to improve on!
Last Weeks Video
https://youtu.be/NeYVM6r39SU
» Crazy_Carl's Wheel Horse Mud Rat [2018 Build-Off Entry]
» [Rules DQ] - WH-guy's Wheel Horse [2019 Build-Off Entry]
» Custom Wheel Horse build/beefy K321
» Mud Buggy 2,Biggest Wheel Horse Mud Tractor Yet [2017 Build-Off Entry]
» Redzz02 "Sears Killer" Wheel Horse Mud Mower [2017 Build-Off Entry] [Finalist]
