 Stock brake assembly
Murray modder
Murray modder
Stock brake assembly Empty
PostSubject: Stock brake assembly   Stock brake assembly Icon_minitimeNovember 25th 2012, 11:30 pm
The stock brake assembly for my murray is A gaint spring (runs down the entire length of the tractor) To the clutch and that crappy brake arm, and those crappy rubber slits to use as the stopping force. My revision. The giant spring is shortoned and attatched to a long rod running from the Arm ( cast iron now) and the little rubber peices are cast LEAD, being a softer metal, I know Ill have to replace them often, maybe upgrade to aluminum when I get my smelter fixed. sound legit so far?
» No brake assembly at all
» Trans Axle Input Shaft Brake (Pinion Brake)
» Brake idea, using existing brake.
» Loose steering arm assembly
» Make your own front 4 wheel drive axle?
All-Terrain Lawn Tractor Forum :: Technical Forum :: Drivetrain & Brake Tech :: Brake Support-
