| what size tires | |
+5Creepycrawler Speedfreek241 WellThatsSurprising crazykid1994 joshualee3d 9 posters |
joshualee3d New Member
Join date : 2013-02-15 Points : 4127 Posts : 23 Location : centerville,IN
| Subject: what size tires July 30th 2013, 4:57 pm | |
| Hey fellers, im ready to upgrade from my turf tires to atv tires but I have a few questions first. Am I able to pull a little bit different size tire on my existing rim? For example I currently have 20×10×8 turf tires and I was thinking about going to a 22x10x8 atv tire but the only ones in could find in that size are kenda scorpion. I believe I want want a little bit more agressive tread than they have. So, my 2 quuestions are 1. Are kenda scorpions good enough for basic trail and some mud running and 2. Would I be able to put say a 22x9x8 or 22x11x8 etc. On a rim that is made for a 20x10x8. | |
Age : 29 Join date : 2013-03-18 Points : 4722 Posts : 618 Location : loxahatchee, florida
| Subject: Re: what size tires July 30th 2013, 5:08 pm | |
| yea. you can. i have 10's on a rim for 8's and they work fine and go to rockymountainatv.com and look for tires | |
WellThatsSurprising Member
Age : 26 Join date : 2012-04-30 Points : 4804 Posts : 407 Location : East Bethel, MN
| Subject: Re: what size tires July 30th 2013, 5:12 pm | |
| The first number you don't have to worry about, it could be 10 or 50 and it wouldn't matter. The second nuber can be a few inches off but streching tires isn't fun and can damage the bead/sidewall. The third number needs to be the same. | |
| Subject: Re: what size tires July 30th 2013, 5:16 pm | |
| 10" wide on 8" wide rims. sorry. as long as the tire is big enough skinnier rims shouldnt matter to much | |
Speedfreek241 Member
Age : 25 Join date : 2013-07-12 Points : 4126 Posts : 137 Location : Loxahatchee
| Subject: Re: what size tires July 30th 2013, 11:24 pm | |
| you can be off on the second number no more than two-two an a half, anymore then that and the bead wont seat. the third number has o be exact. | |
Age : 36 Join date : 2013-07-02 Points : 4816 Posts : 731 Location : Logan Ohio
| Subject: Re: what size tires July 31st 2013, 8:02 am | |
| You can definitely put wider tires like 22x11 on your rims I put 26x12x12 on a rim that had 23x8x12 on it | |
Join date : 2013-06-01 Points : 4607 Posts : 578 Location : West Virginia
Age : 23 Join date : 2013-04-08 Points : 5006 Posts : 913 Location : Central Pa
| Subject: Re: what size tires July 31st 2013, 9:25 am | |
| I would use the knobby tires, they work good for off roading, they have some grip but not too much. So if you were to go up a hill and get stuck they will spin before they grab and flip you over. | |
| Subject: Re: what size tires July 31st 2013, 9:45 am | |
| - LAWN MOWER MUDDER wrote:
- So if you were to go up a hill and get stuck they will spin before they grab and flip you over.
there is 2 ways to look at that.. yes they keep you from flippin but if you had better tires would you of made it? | |
| Subject: Re: what size tires July 31st 2013, 11:10 am | |
| Hmmm I never thought of it that way. lol . | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6340 Posts : 2101 Location : Norway, Europe
Marines2621 Member
Age : 26 Join date : 2012-12-31 Points : 4380 Posts : 215 Location : Mountainburg, Arkansas
| Subject: Re: what size tires August 1st 2013, 7:02 pm | |
| Me personally, i would try out a set of ag tires. Trying to get a set and im not sure how they preform but ive heard they are great in a mud hole. | |
| Subject: Re: what size tires August 1st 2013, 8:17 pm | |
| I wanna try ag tires. Im running 18" dunlops. Might put them in the front if i get 20" ag's | |
Marines2621 Member
| Subject: Re: what size tires August 2nd 2013, 12:25 am | |
| Figure they would be beast and eat through mud | |
| Subject: Re: what size tires August 2nd 2013, 11:14 am | |
| I found some on ebay already on rims for I think 140$ but it was a while ago. I want 20's
Marines2621 Member
| Subject: Re: what size tires August 2nd 2013, 11:16 pm | |
| I got 5 lug 23 inch rims im gonna get some ags for
| Subject: Re: what size tires August 3rd 2013, 8:12 am | |
| Ah. Ok. Make sure they are deep lugs on the ags for better ground and mud penetration
| what size tires | |
