 tip mower on its side to figure out pulley setups
dwcopple
tip mower on its side to figure out pulley setups Empty
PostSubject: tip mower on its side to figure out pulley setups   tip mower on its side to figure out pulley setups Icon_minitimeMay 19th 2014, 8:36 pm
Is it okay as long as I tip it to the oil fill side and keep the carb side in the up position? I will remove the gas tank first. I need to get my idler pulleys figured out to tension the belt.
PostSubject: Re: tip mower on its side to figure out pulley setups   tip mower on its side to figure out pulley setups Icon_minitimeMay 19th 2014, 8:56 pm
yeah, just make sure the dipstick is tight. and when you set it back down, let it sit for about a half hour to let the oil drain back into the sump
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: tip mower on its side to figure out pulley setups   tip mower on its side to figure out pulley setups Icon_minitimeMay 20th 2014, 10:20 pm
I always stand mine up on the back. Run the tank below half and stand it uo in my situation. That or i hoist mine 5ft in the air. And sit under it.
» Racing mower: pulley swap
» Need help i want to pulley swap my offroad mower
» removing pto clutch pulley and running mower
» Best pulley ratio to make mower spin the tires
» Project Spare Change aka Homemade Side by Side UTV
