| Craftsman build. | |
+14Angchor Craftsman1998 camomanusa willis923 k2500life MowBandit richie thomas greener179 TheRainbowBoxer Doc Sprocket redlinemotorsportts Doug LAWN MOWER MUDDER TheBeal 18 posters |
TheBeal Veteran Member
| Subject: Re: Craftsman build. October 13th 2013, 12:50 pm | |
| Put the logo on in white today... Didnt quite turn out that great, I should have taken off the slag so it layed flat. Thats Ok though, it will work for now. | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7132 Posts : 2914 Location : Ontario Canada
| Subject: Re: Craftsman build. October 13th 2013, 1:57 pm | |
| Purple paint, horned thing... That makes this tractor The Horny Purple... what? | |
Age : 29 Join date : 2013-06-06 Points : 5527 Posts : 1398 Location : Central PA
| Subject: Re: Craftsman build. October 14th 2013, 4:29 pm | |
| Lol doc... Decided the split skull didnt fit this build... or color scheme. Painted the black in the front though. As you can see, I also experimented with gold paint... dosnt look the part I dont think. Before its all over, it may be black with purple flames... | |
| Subject: Re: Craftsman build. October 14th 2013, 5:40 pm | |
| - TheBeal wrote:
- Lol doc...
Decided the split skull didnt fit this build... or color scheme. Was it somethin' I said??? | |
| Subject: Re: Craftsman build. November 15th 2013, 7:11 pm | |
| No Doc... if it was... well... thats another story!
But any rate... no progress to speak of. Deep down I was hoping to have this thing running by the first significant snow... However, seein as how I flipped the mtd with the briggs twin... and Im too cheap to buy another shroud off the internet or one of the fine members here... Actually, I really dont have an extra $20 or so for it. But thats ok. I will survive.... I mean, this thing will survive? | |
| Subject: Re: Craftsman build. December 19th 2013, 4:17 pm | |
| Made up a few parts yesterday and today... What you see are 2 hooks that will be put on the bumper, the plate with the hole will bolt to the leaf spring. If Im thinking right, the U bolt will be on either side of it so it should keep the spring from moving around. The other 2 are going to be for the spindle bracket. So slow progress better than none. | |
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5575 Posts : 1408 Location : Galway NY
| Subject: Re: Craftsman build. December 19th 2013, 5:44 pm | |
| those are big hooks. if they let go, there is a serious problem | |
| Subject: Re: Craftsman build. December 20th 2013, 5:57 pm | |
| - willis923 wrote:
- those are big hooks. if they let go, there is a serious problem
They are 5/8ths roundstock heated and bent around a pipe. Ought to work good... if they do let go at some point, it could only be a weld somewhere. And if thet happens... I should rethink my career choice to be a welder lol But anyways, more progress today. A NEW SHROUD a the scrap yard. Almost missed it. Got it for free. Not sure if they do that all the time for something that comes out less that a $1 or if it was the lovely receptionist/cashier/whateversheis lol. You can also see part of the spindle bracket there on the leaf spring. Its not quite right where it is welded, so i think Im going to leave it as is and find a use for it later and make some new ones. But maybe you can kinda get an idea of what is floating through my head... Also discovered an adult student in the diesel shop has an opposed twin that threw a rod, might see about getting it if it doesnt have internal damage... | |
| Subject: Re: Craftsman build. December 20th 2013, 6:18 pm | |
| Very interesting. What's the leaf spring from?
Regarding the U-bolt plate- I very much doubt that alone will be enough to locate the axle securely, if you're attempting to do what I think you are.
What I think you are doing, is a transverse leaf spring- This is one single lateral spring running parallel to the axle. Generally, the center of the spring pack would get bolted to a frame bracket, and both spring eyes get bracketed to the axle.
Now- with a really stiff (too stiff to be useful) spring, you MIGHT get away without radius arms or another means of locating the axle, and on a low speed tractor at that. If the spring is soft enough to do something beyond look like a spring, it's gonna be all over the place. Lethal on anything over a few MPH. | |
| Subject: Re: Craftsman build. December 20th 2013, 7:31 pm | |
| The spring is from a trailer. Before I actually messed with it I thought about using the whole set! I could NOT flex them at all lol. That was about a joke! Even this single piece is pretty stiff.
What would you suggest doing Doc? I had though about welding a bracket on the spring but I dont think I want to weld on it or drill on it. | |
| Subject: Re: Craftsman build. December 20th 2013, 7:39 pm | |
| No- do NOT ever weld to a spring, the heat will kill the temper of the spring. Proceed with the U-bolt bracket, and use the spring's centering pin (or a bolt) to locate it in the bracket. Keep a close eye on measurements- I occasionally come across a leaf spring where the centering pin is NOT in the exact center from eye to eye. And I do believe you'll have to fab up some radius rods or similar. | |
| Subject: Re: Craftsman build. December 20th 2013, 8:01 pm | |
| I figured it would do something like that. Im pretty sure it is centered, I too have seen some off center. So Ill just get a longer bolt... thats easy. I was planning on making some sort of trailing arm/radius rods/whatever they are called. I think it will look cool. Planing on talking to the shop instructor to see if I can maybe bring the whole thing in sometime to work on. Or atleast build a subframe to build the front suspension on and then bolt to the mower body. And now, after thinking about ti some more... I have ideas for a hotrod gokart... Gona be low and wide... powered by a "bog block" briggs flatty... muwahahah... hahaha... {EDIT} Doc, or anyone for that matter... If you have an idea of something that might work better than what Im doing, or even something you think would be cool to see on this build feel free to PM me or post it here. | |
| Subject: Re: Craftsman build. February 9th 2014, 6:24 pm | |
| Dinky little update... Sterrin wheel!Hahaha... | |
| Subject: Re: Craftsman build. March 31st 2014, 7:56 pm | |
| And so it begins......................... Engine swap this week... | |
Age : 27 Join date : 2013-03-18 Points : 7297 Posts : 3131 Location : raleigh nc
| Subject: Re: Craftsman build. March 31st 2014, 8:20 pm | |
| I thought........ The day would never come!
An update! *sniffle* | |
| Subject: Re: Craftsman build. April 1st 2014, 8:25 am | |
| WOOOO tread revived!! glad to see this project up and going again | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6214 Posts : 1434 Location : east dublin georgia
| Subject: Re: Craftsman build. April 1st 2014, 5:17 pm | |
| bout time man, now hurry up and dont make us wait that long again | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4393 Posts : 467 Location : Greensburg, PA
| Subject: Re: Craftsman build. April 6th 2014, 10:01 pm | |
| Yeah so soon as I get the stupid pulley off the oppy I can set in on the craftsman... and start figuring out the exhaust and controls and whatnot... woot. | |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 4966 Posts : 1068 Location : New jersey
| Subject: Re: Craftsman build. April 7th 2014, 8:18 pm | |
| I do... but its not working for me. lol But anywho... some pics. Thats how the exhaust will be routed. I will need to extend them so they go below the footboards or whatever they are called. | |
| Subject: Re: Craftsman build. April 11th 2014, 8:35 pm | |
| I like the idea of mounting it backwards, and could you tell me what purple (like company you used) because thats a awesome color. | |
| Subject: Re: Craftsman build. April 11th 2014, 9:10 pm | |
| I figure it would be a bit easier to run the exhaust back, and not have a U in there anywhere. The paint, my dad brought home. I just slapped some one there to see what It looked like lol. Valspar Satin Purple. Lable on the can says something about being "product of the year" in 2012.. could be a couple years old... been frozen several times Im sure. And some more pics... You can see the bolt holes do not line up... ugg. Solution? Cut out and replace with some 3/8 plate! (cause that what I have lol) ...and here, you can see we have some fitment issues. Clearly I will have to break out the angle grinder... And hopefully, I can cut out the exact same on each side. Gotta be perfect! ...and here you can see about how far back the engine will be sitting, it will be further yet 2-3in. The stock air filter will not fit there. Also, the vents on the top of the hood are thereabouts... Im thinking hood scoop. ...and here... as you can see, it was pretty darn close to that steering rod. Couldnt even set the engine on the frame with the stock pulley on there. Hoodscoop anyone? | |
| Subject: Re: Craftsman build. April 13th 2014, 8:56 pm | |
| Cut this area out. Still need to cut a bit more, but this will be replaced with something around 1/4. Then i can position the engine further back aswell. Thinking Im gona refigure the exhaust.. Gona make some new flanges and have about 6-8in if strait pipe then hopefully find some flexible tubing and run some of that, then exit out the sides in front of the rear tires with some 1 1/2 or so conduit... Any suggestions for modding the steering any? And my transaxles... a 3 and 4 speed. Both have a 900 020 tag. | |
| Subject: Re: Craftsman build. April 13th 2014, 9:28 pm | |
| Looks good, and what about steering? Like was it missing before this? Need something to go around the engine? | |
