Gotta say I have learned a LOT in the past few months.
Biggest thing I have learned though, is how I should build the ultimate, (for me), super utility tractor.
Without compromise, it should include, but not be limited to, the following things.
1. Lower the center of gravity without compromising ground clearance.
2. WIDE
3. Stretched. (Rear axle WELL behind the driver.)
4. Separate brakes. (And hopefully better than the brakes that are standard on a tractor.)
5. Secure drive train that will not slip at a dangerous moment.
6. Put a winch on the front.
I am finished with the trail. I will probably never go down or back up that trail again.
Biggest reason being, I can't bloody well WALK the trail.
And then there's the time it would take me to make a really good build that I would trust on that trail again... Is longer than it will be before the bridge is finished, and the trail will be closed. IOW: I can't build fast enough to be able to use the trail again, anyway.
But I got bit by the tractor bug. I do still need to build that good build, so I can use it on my own property. But even if I didn't have to, I'd still get out there and build it just because I'm infected with the tractor fever now. LOL
Ok, to whit:
I have three tractors to choose from, to begin the new build. Lets have a look at them , and consider the options.
We are going to look at the frame. The drive train. etc...
I will come back to this thread and add things for the good or the bad, as they occur to me.
First we have my first tractor, the BEAST.
![0ptions for next build Beatbe11](https://i.servimg.com/u/f39/18/82/53/07/beatbe11.jpg)
This is the beast after the crash, and after I started taking parts off of it.
The hood is pretty well beat, but that isn't going to matter for a tractor that I will not be leaving somewhere out in the public and so I don't have to worry about locking it all up.
The steering needs improvement. I would probably want to stiffen/beef up the front axle, then possibly change it to direct steer. Although with a utility tractor that may require some tricky steering in some spots on my hillside... it may be best to leave the steering type as is, but beef everything up. I think that could probably be done.
Frame. This frame is pretty beef! I don't like the tunnel being as tall as it is. I'd like to cut that down. And I'd have to cut the fender, etc, to lower the center of gravity by lowering the seat. And it may actually be the best of the three to extend.
The transaxle seems to be one that a lot of people like. I'll agree with that. My one gripe about it is that the axle itself is pretty wimpy. If I go with this one, I will be looking for the axle bearings from an 820. (And seals.) And I will be extending the axles, and adding pillow blocks to support them. Again, maybe all this is ok, because I'd have to do all that to the ariens as well, if I stretched and widened it.
The engine seems to be the best of the engines I have. Works really well. Is very strong. (RUNS up that hill, compared to the WHAMS only creeping up.) And doesn't seem to any the worse for wear from my putting a foot throttle on it.
Next we have the WHAMS. Man, I really liked that tractor!
![0ptions for next build Racks10](https://i.servimg.com/u/f39/18/82/53/07/racks10.jpg)
I really should have taken the time to separate out the brake on that thing, and put in a separate pedal for it. It might have saved me from the crash. Not too sure about that, though. Because I don't know that a brake that is inside a grease packed case, and is completely packed with grease, itself... Would have held on that steep slope anyway.
The hood is all plastic. And did take a bit of a beating. Again, no big deal, because I am not going to be leaving it in a place where I need to lock it up like you do your car when you leave it in a parking lot.
Steering. Even though I did the repairs to the front axle and components, it never steered any better than the craftsman. Still all over the place.
It was/is all wheel steering. That may seem like a good thing. And in some scenarios, I am sure it would be so. But that has been damaged now. If I stretch it as well, then I would be eliminating the rear steering anyway. Just because it would be stronger and easier to build it without working rear steering.
Bottom line, I'd have to rebuild the steering, just like I'd have to rebuild it on the beast.
The frame for this is kaput. If I had to pick the frame that is the least desireable of the three, this one would be it.
That rear transaxle, and axle is the strongest that I have. Real beef! Unfortunately it is FNR only. And to be honest, I don't like the vari-drive. If I decide to stretch and build this one, I'll have to do a LOT of experimenting with the vari-drive system. Not sure I want to mess with that. Especially since every time I drive it, I smell the belts burning. And that is with 'normal' driving.
If I could find some other way to reliably vary the speed, I might consider it.
The engine. Well, it runs. But either the engine itself is gutless or the vari-drive system makes it so. I never tried to bypass the governor on this one, either. So maybe it is unfair to compare it to the engine of the same size on the beast. (Which HAS been bypassed.)
Now we come to the final contestant.
Untried and unsure. The ariens.
![0ptions for next build Ariens10](https://i.servimg.com/u/f39/18/82/53/07/ariens10.jpg)
The plow is homemade. The PO made that, and then never tried it. Ever.
It was running when he parked it there. It hasn't been started or run, since. Been several years sitting there.
It has no hood. Nothing of any kind. The "dash" is all beat up, and would have to be pretty much rebuilt. Again, no biggie because this will not have to be locked up. But it WILL have to be kep covered...
Steering... Completely unknown. I have to say that i really like the looks of the front axle, and the really beefy way it is mounted. But the wheels wobble like mad on it, so at the least the wheels are going to have to be replaced. At this point in time I am going to assume that to get good solid steering on this, I'll have to go through and do a rebuild, repair, and adjust, just like I would have to to the other two tractors.
Frame. This one is a bit strange. It is strangely shaped. It does seem sturdy. And again, I really like the sturdy appearance of the front end. But to stretch the back end may require a bit more framing and bracing than the beast frame. And I have to say, when I sit on this one, I like the stance and the feel the best, out of the three of them.
The trans is a hydro. I've never driven one. But from what I have gathered here and elsewhere, it may well be the best trans of the three, for my purpose. Which is strictly utility. Not speed. I have no idea if it even works. I will assume that it does, or that it will be fairly easy to MAKE it work, since the PO was driving it before he parked it.
And last.. the engine. The other two are 15.5hp. They are almost identical. This one is 15hp. It is a tekumseh. And it was running when he parked it. But it is full of gray sludge. When you turn the top by hand, you hear metal grating sounds inside. Again, I have no idea if this is going to run, and/or if it does, is it going to be any good. It does have one of those vacum powered fuel pumps. The others do not. (The beast has an electric that I put on there, but would probably work on gravity feed. And the whams is a gravity feed.)
My thoughts...
It almost looks like a frankenstein is going to be my best bet.
The beast frame seems the beefiest. But it could be that once I strip down the ariens I will like the frame just as much. And I already like the stance and feel of the ariens the best.
The ariens definitely has the best seat out of the three. Whatever I build will likely end up with that seat.
So far the engine from the beast seems the best.
The trans from the whams is the best as far as being beefy. Anything that I build, will have to have strength in mind as the first priority. But it's only an FNR.
I need to get the ariens ambulating on it's own, to be able to truly judge that trans. I also need it running, so I can judge the engine.
Today, I have been recovering from the crash.
Tomorrow, I will get out there and get the ariens down here into my working area, and see what it is going to take to get it going so that I can judge what parts of it are good or better than the others. If any at all ARE...
There is supposed to be a 'dump valve' on those hydros. Does anyone have any idea where it is on this rig?
