Welcome to the All-Terrain Lawn Tractor Forum! New Awards system! Look for your award at 500, 1000, 2500, 5000, 7500, and 10000 Posts!!! |
| | The Jtrack | |
SlipperyJim New Member
Age : 37 Join date : 2019-12-21 Posts : 5 Location : Grass Lake, Michigan
 | Subject: The Jtrack February 9th 2020, 4:30 am | |
| Hello Everyone, Time for a little write-up on the down n' dirty details of my hydrostatic half tracked heavy hauler, aka; The Jtrack. I'm writing this on my mobile and the text size looks a bit odd to me so I hope it formats ok. I consider myself a pretty decent mechanic but this is the first time I've ever built anything track based or off of a lawn tractor style platform. Basically all of the inspiration came from all of you fine folks.
Background. We recently bought a house and I needed a small-ish UTV to haul rocks, blocks, dirt, firewood etc. I picked up a non running, no mower deck Craftsman lawn tractor for 50 bucks. Hydrostatic drive, 19hp Briggs oppy twin. It needed a starter rebuild and all of the snot cleaned out the carb. There was also a problem with one of the safety switches, dunno which one because I just went ahead and chopped 'em all out. Problem solved.
It came with a hood but I immediately got rid of that and built the flat bed for it.
I knew already that I was going to build a half track for it but I couldn't resist a little woodland baseline test romp, instant disappointment, open diff=no good. I wanted to overhaul the transaxle because I didn't really know what the tractor had been through and hydraulic systems like to be kept clean. I took that opportunity to Lincoln lock the diff, reassembled and went for another test romp with much better results. I could see those 15/6/6 front tires were not gonna work but I had a plan.
I had watched a few videos on the googleTube where simple half track configurations had been built and I had a few ideas of my own so I got started building my swing arm out of some old ladder rack and swingset frame. The threaded track length adjustment is an oem style, spare tire kit scissor jack, it offers just over 4 inches of adjustment in it's current configuration but could easily be modified to get more if needed. The wheels are just mocked up in the pics but I think you can see things taking shape.
More to come, stay tuned. | |
 | Subject: Re: The Jtrack February 9th 2020, 6:19 am | |
|  | | AllisKidD21 Moderator
 | Subject: Re: The Jtrack February 9th 2020, 8:40 am | |
| Sweet half track build! Looks like a lot of fun, and pretty hand with the flatbed up front. I like the tension adjustment setup too.
Did the half track with locked differential affect the steering much? _______________________________________________ "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* - Allis B-110 x2, 710 & 716 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic & 1668 - Cub 106 & 124 - Ford LGT 125 & 145 - White 1650 Yard Boss | |
 | Subject: Re: The Jtrack February 9th 2020, 10:29 am | |
| The steering was affected but not as much as I thought it would be. When cornering the inside track hops and chews up the grass a little but that's the price we pay for traction I guess | |
|  | | Creepycrawler Established Member
Age : 34 Join date : 2013-07-02 Posts : 655 Location : Logan Ohio
 | Subject: Re: The Jtrack February 9th 2020, 3:37 pm | |
| very cool man, talk about out of the box
|  | | Sponsored content
 | Subject: Re: The Jtrack  | |
|  | | | The Jtrack | |
