| Very fast lawnmower question | |
CraftsMAN Member
Age : 37 Join date : 2010-06-01 Points : 5578 Posts : 364 Location : NY
| Subject: Very fast lawnmower question November 3rd 2012, 11:03 pm | |
| So I am building a tractor with a motorcycle engine and a go kart style rearend. like the one in this video below. I was wondering for the rear axle I got a 32x1 inch go kart axle. Should I use a pillow block bearing that will attach to the stock tranny mounts on a lawnmower. Or should I drill a hole through the frame and mount 2 bearings on the frame of the tractor? I am sure I will be asking more questions as times go on. https://www.youtube.com/watch?v=yAW1wg_WJwA | |
CraftsMAN Member
Age : 53 Join date : 2010-02-10 Points : 6867 Posts : 1726 Location : Florida, USA
| Subject: Re: Very fast lawnmower question November 5th 2012, 8:44 am | |
| I suggest pillow blocks, mainly for the high RPMs , strength and servicability ( can grease em) - they work for building ventilation systems so should work great on a tractor - all my mods are using pillow block berings. | |
CraftsMAN Member
| Subject: Re: Very fast lawnmower question November 9th 2012, 3:45 pm | |
| I picked up a 32x1 inch axle for it with 2 of these bearings (http://www.ebay.com/itm/2-DODGE-F4BSC204-2-1-4-4-BOLT-FLANGE-BALL-BEARINGS-/271098320214?pt=LH_DefaultDomain_0&hash=item3f1eb81556) What I also wanted to know is what do I do to keep the sprocket from moving from side to side when I put it on the axle shaft?? I imagine it goes on with a keyway but do I use a spacer to hold it center? Thanks | |
AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4727 Posts : 208 Location : Tennessee
CraftsMAN Member
CraftsMAN Member
| Subject: Re: Very fast lawnmower question November 9th 2012, 11:58 pm | |
| How do I make sure the lock collars do not move around? The threads might not hold up on the bolt to tighten them.... | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5490 Posts : 1089 Location : Galion, OH
| Subject: Re: Very fast lawnmower question November 10th 2012, 12:34 am | |
| Lock collars do a great job of staying where they are supposed to... we use the crap out of them. | |
Chopperhed Moderator
Age : 57 Join date : 2012-10-14 Points : 5045 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Very fast lawnmower question November 10th 2012, 1:14 am | |
| - CraftsMAN wrote:
- How do I make sure the lock collars do not move around? The threads might not hold up on the bolt to tighten them....
Couple of ways to lock set screws down so they don't move Before you install the setscrew take a drill and bit smaller than the ID of the threads, and drill a dimple in the shaft. It doesn't take much of a dimple. Then use some thread locker on the set screw to keep it from backing out. Red if its permanent, Blue if you want to take it apart later. Or if you are really cheap and don't care if it comes out, Superglue makes a good thread lock, It may or may not come apart afterward though Or you can skip the dimple and just use the threadlocker, pretty weak though I personally would drill and tap for a second set screwm opposite the first, dimple both, and Loctite them in | |
CraftsMAN Member
AcreFarm Member
| Subject: Re: Very fast lawnmower question November 21st 2012, 1:29 am | |
| Looks like direct steer versus rack & pinion... They would both work, it just depends on your preference. Some people would say not to use direct steer on an off-road machine... some would say go for it. I built a direct-steer setup on my mower, mainly because I prefer a hand throttle over a foot throttle. Honestly you will get a whole lot more feedback from a direct steer... as you hit & run over things the steering wheel will want to jerk left or right. The rack & pinion steering will feel closer to a stock mower setup; it will take multiple turns of the wheel to go full-lock to the left or right. Like a kart vs. a mower... it will steer slower, but with less feedback thru the steering wheel. | |
CraftsMAN Member
CraftsMAN Member
CraftsMAN Member
| Subject: Re: Very fast lawnmower question November 22nd 2012, 9:43 am | |
| I Need to know a few things
First off which engine are you using? Make and model of the bike its coming from is all I need to know
Output sprocket size on the engine, are you using the shifter, or will it be in locked in gear?
Tire size
expected top speed
I should be able to find the gear ratios for the engine on line, if not, the engine sprocket size is all i need | |
CraftsMAN Member
| Subject: Re: Very fast lawnmower question November 29th 2012, 3:24 am | |
| The rear tires are 18x8.5x8 and the engine will be a 400cc yamaha engine most likely. I will be using the shifter. Expected top speed not really worried. About 50 lets say ? | |
| Subject: Re: Very fast lawnmower question November 29th 2012, 7:48 am | |
| - CraftsMAN wrote:
- The rear tires are 18x8.5x8 and the engine will be a 400cc yamaha engine most likely. I will be using the shifter. Expected top speed not really worried. About 50 lets say ?
\ Is it a dirt bike ir street bike engine, 2 stroke or 4 stroke Do you know the model of the bike its coming from? | |
| Subject: Re: Very fast lawnmower question November 29th 2012, 11:31 am | |
| I just ran the numbers using the stock Yamaha XS 400 twin with a stock 16 tooth sprocket, assuming a 4th gear ratio of 1 to 1 ( 5th and sixth gear are usually overdrives) Its the only old yamaha 400 with electric start. Using a kick start engine in a tractor would be a pain.
with a 60 tooth rear sprocket you would expect a top speed of 100 mph @ 7000 rpm a 70 tooth sprocket would get you down to 85 mph, however a 70 tooth sprocket is huge, nearly the size of the tire
if you add a jackshaft with a 20 tooth input sprocket and a 10 tooth output sprocket and use a 50 tooth rear sprocket you can cut you're top speed to 60 mph @ 7000 rpm.
if you add a jackshaft with a 32 tooth input sprocket and a 10 tooth output sprocket and use a 40 tooth rear sprocket you can cut you're top speed to 45 mph @ 7000 rpm.
How much pulling power do you want?
CraftsMAN Member
| Subject: Re: Very fast lawnmower question November 29th 2012, 5:35 pm | |
| - CraftsMAN wrote:
- It would be off of a street bike 4 stroke. I would like some good low end..
All the old yamaha 4 stroke 400s were about the same horsepower. I wouldn't bother trying to use a kickstart motor, unless you can figure out some fancy rigging to actuate the kicker. A 400 single is damn hard to kick over even for me, and I weight 240 lbs. Doing it on a tractor would be extremely difficult. "if you add a jackshaft with a 32 tooth input sprocket and a 10 tooth output sprocket and use a 40 tooth rear sprocket you can cut you're top speed to 45 mph @ 7000 rpm."This forumula should work quite well, You pretty much have to run a jackshaft or you won't get nearly the ratio you need to get the speed down to 50 or so. The formula is based on the Yamaha 400 twin with a 16 tooth engine sprocket. A 70 tooth sprocket is 14-1/2" around and it will get you down to 85 mph with out a jackshaft, but you won't have much bottom end. | |
CraftsMAN Member
CraftsMAN Member
CraftsMAN Member
| Subject: Re: Very fast lawnmower question November 30th 2012, 9:52 am | |
| I need to know the model of the bike for any better info. an 80 tooth #50 sprocket is 16.5 inches in diameter. you'ld only have an inch or so clearance under the sprocket.
A jackshaft only takes as much space as the largest sprocket plus a little for chain and guard clearance.
Mine only uses a roughly 5"x 5" area 12" wide, and it could be narrower, I could have used a shorter shaft. | |
