Ours do look alike lol. There's no serious body damage on it that i can tell. It just needs to be cleaned up a little. And i'm pretty sure the transmission is still good too. I guess i'll find out when i pull it to my garage haha. And thanks for that link, that tractor is awesome!!
^ lol i was looking at that one too on craigslist
TennesseeCowboy Member
Age : 28 Join date : 2012-08-05 Points : 4429 Posts : 124 Location : TEN-A-SAYY
Ya, I was just thinking if you where local.(I'm up and over in NH) I would really like to keep it whole too, like doing a restoration job. The original color is orange, but someone had painted green over it. Seems kinda like what you've got. But the dash is really similar. That's something I haven't seen. Does yours have a lighter on it?
I could really use that grill right now lol the corner hing part on mine is broke and its gunna be a pain to make it work lol
BlackMountian88 Member
Age : 24 Join date : 2012-09-08 Points : 4696 Posts : 399 Location : NH
Wow $20? Not bad my friend lol. Its pretty tough to find good deals on mowers, most people want a forture for them and most times they need work. I like when you find one someone just wants off their property and its free haha
dagr8tim Member
Age : 47 Join date : 2012-01-01 Points : 4744 Posts : 194 Location : Columbus, Oh
All my dynamarks have fuel fillers thru the hood, BUT the '82 has the tank bolted to the hood - so i have to make sure theres not alot of gas in the tank when i pop the hood. Its sort of a pain to refuel them- i need a funnel to keep gas from going everywhere.
The hood pins on mine are thru the hood sides mounted to the dash sides - basically just a bolt sticking out - i dont use any sort of nut , the tension holds the hood on.
My '82 has a 3 speed that uses gear oil - same as in my agway - the other two have grease filled transmissions. I cleaned the grease out of my 88 kleen kut and stuff looked like nasty baby poo. Thats the biggest tractor of the 3- had a 18HP twin and 45" deck , its sitting right now till i can get back to redoing it.
dagr8tim Member
That's really neat! That's different clips than mine. Mine is like on a toolbox . I'd like to see the moor I that's not too much to ask!
Motor or more? I'm sure that there will be pictures and videos when I work on it.
It feels like there is a wire clip that the pin connects with on the inside. The pins have a diagnal slot on the shaft that I'm assuming is supposed to turn 1/4 of a turn to lock.
Aw that would be awesome. I'm confined to the garage cause its like 20 dagrees and windy out here. I've been having problems with battery's acting up in the cold.
Age : 53 Join date : 2010-02-10 Points : 6879 Posts : 1726 Location : Florida, USA
