One of a kind! I like it! Since it's a Chrysler axle, maybe you could put a select-able locker in it so you could unlock it when u needed to turn. Being from the 50's might be tough.. that would be sick though. The only thing the surprises me is the fact that it only has a 38" deck.. I have a 11 hp briggs that runs a 36" deck. Is it diesel or gas?
Its a gasser. Would be cool if it were a diesel. I could be rollin coal on a lawn mower!
AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4727 Posts : 208 Location : Tennessee
I emailed a magneto repair company a few days ago and asked how much it would cost to rebuild my magneto. I got an email yesterday from them and they said to rebuild that magneto would cost about $250 so I thanked them for replying with a quote and went outside to see if I could fix it myself. Took apart the magneto last night and looked at a damaged gear inside the magneto. The gear is missing a tooth but seems to work just fine so I put the magneto back together and put a good battery on it.
Now before I go any further with the description I must mention that the first time I attempted to start it I used the orignal battery which was no good so I had to jump start it. When I started it the first time the motor turned over very slow but at the time I just thought it was supposed to be that slow so I thought the magneto was faulty because I wasent getting spark.
Ok back to the description. I hooked up a nearly new 420 amp lawn and garden tractor battery on the tractor and attempted to start it. I noticed the motor spun over much faster so I got a little carb cleaner and sprayed in the carb and the motor busted off. When I get some gas I will try and get it running. __________________
Tractor Man Jeff Moderator
Age : 29 Join date : 2012-06-26 Points : 4804 Posts : 492 Location : Back in the sticks of VA
