| Husqvarna 90's rally mower. | |
| Subject: Husqvarna 90's rally mower. September 18th 2013, 5:57 pm | |
| my friend has multiple mowers, and a craftsman that he liked to romp. He got a MTD with a hydro and a opposed that ive got running, sounds great. He also got this new Husqvarna with a non running (needs coil) kohler 13HP. We swapped the oppsed to this new Husqvarna. It has a hydro and he says hell get a 6 speed. just need to make shifter linkage and axle mounts and should bolt right up, its basically a lt1000. Old mower: No wireing, going to cut out the safty's. Roller now. Old engine with the engine pully (mower deck is electric clutch selling that) Siderails bumpers and maybe exhust from trampoline tubing lol. Again its not mine so I might show up and it might change. I have no control just suggest things. | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6191 Posts : 1434 Location : east dublin georgia
| Subject: Re: Husqvarna 90's rally mower. September 19th 2013, 6:16 am | |
| - richie thomas wrote:
- whats he plannin for the old motor?
Put it on the mower that the oppy came off of. | |
| Subject: Re: Husqvarna 90's rally mower. September 19th 2013, 12:34 pm | |
Put it on the mower that the oppy came off of. oh, just wondering lol thats the motor i have on dixe, it has a good bit of power | |
| Subject: Re: Husqvarna 90's rally mower. September 19th 2013, 2:55 pm | |
Put it on the mower that the oppy came off of. oh, just wondering lol thats the motor i have on dixe, it has a good bit of power Yea, the oil filter is cool feature | |
k2500life Veteran Member
Age : 26 Join date : 2013-06-19 Points : 5162 Posts : 1135 Location : Southern Florida
| Subject: Re: Husqvarna 90's rally mower. September 19th 2013, 9:35 pm | |
| - k2500life wrote:
- Them kohlers are awesome
Definatally, the single cyl can take abuse. he has a 15.5hp on his other craftsman with a string to the governer arm and just yanks on it all the time. you can gear the lifters chatter and never skip a beat. | |
cumminsbayou Member
Age : 26 Join date : 2011-11-04 Points : 4812 Posts : 232 Location : fairhope Al.
| Subject: Re: Husqvarna 90's rally mower. September 20th 2013, 8:59 am | |
Definatally, the single cyl can take abuse. he has a 15.5hp on his other craftsman with a string to the governer arm and just yanks on it all the time. you can gear the lifters chatter and never skip a beat. I had a 13hp kohler and something made the governor sticked wide open and to get it back to my house I drove it like that for over 10 minutes, I took the arm off the governor from then on, and i put a good return spring on the carb. | |
| Subject: Re: Husqvarna 90's rally mower. October 21st 2013, 8:35 am | |
| Well this will sound goofy. I'd like to see this mower romping but the 13 Kohler that will go on this engine needs a coil. Is it possible to take a Briggs coil (witch we have) and measure and drill new holes in it? Would it work? | |
cumminsbayou Member
| Subject: Re: Husqvarna 90's rally mower. October 21st 2013, 8:52 am | |
- Well this will sound goofy. I'd like to see this mower romping but the 13 Kohler that will go on this engine needs a coil. Is it possible to take a Briggs coil (witch we have) and measure and drill new holes in it? Would it work?
I don't see why it wouldn't if the fly wheel had the same magnet and bolting it up was possible. | |
Guest Guest
| Subject: Re: Husqvarna 90's rally mower. October 21st 2013, 9:22 am | |
| your axle mounts from the hydro to the 6 speed will be the same. front braces, if so equipped will be different, but not majorly so...
and that 13hp that needs a coil? (did I read that right?) have one if you need it. |
| Subject: Re: Husqvarna 90's rally mower. October 21st 2013, 11:05 am | |
| - prometheusedi wrote:
- your axle mounts from the hydro to the 6 speed will be the same. front braces, if so equipped will be different, but not majorly so...
and that 13hp that needs a coil? (did I read that right?) have one if you need it. Yea I remember you saying that.ill take it if I didn't have to pay for it | |
