| 1997 Murray widebody trail mower | |
+17CornShuck4CE countryboy1995 Moose the54 TheRainbowBoxer Lawren Wimberly LAWN MOWER MUDDER TheBeal T-Dub13 willis923 richie thomas redlinemotorsportts Thunderdivine Ariens YT11 crafsmankiller mr.modified 1997 Murray 21 posters |
Moose Established Member
1997 Murray Veteran Member
| Subject: 1997 Murray widebody trail mower March 3rd 2014, 2:06 pm | |
| got to work on this a little before school, was spinning it over by hand to distribute the oil before i started it, and it started! I guess my key was hooked up wrong.. does anyone have a diagram to use when you want to keep the key switch? | |
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5552 Posts : 1408 Location : Galway NY
Age : 27 Join date : 2012-10-31 Points : 4955 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: 1997 Murray widebody trail mower March 4th 2014, 9:26 am | |
| yeah, this was the engine that I was going to give to you, and the 700 woold be nice to have right now, but maybe I can find one localy. | |
| Subject: 1997 Murray widebody trail mower March 7th 2014, 11:46 am | |
| well, bought a 6" cast iron pulley for $44 yesterday, along with a starter silinoid and some other stuff for my mowers. started up the montgomery wards and drove it for about 10 min before the engine sized. good news is, the 17 hp teccy fits with 1/2" to spare! also got the pulley on the murray and took it for a spin. it goes about 22 mph, which is not quite fast enough... good thing that I have a 3" to go in place of the 4" that is on the tranny now. Oh yes, I got 2 quarts of 80w-90 for the trannys, so hopefully that will help the tranny stay together... | |
countryboy1995 Member
Age : 29 Join date : 2013-09-25 Points : 3913 Posts : 45 Location : Marion,NC
| Subject: Re: 1997 Murray widebody trail mower March 16th 2014, 4:11 pm | |
| this is a nice build I think murrays are the best for off road builds ive got a murray im gonna start building on when I have the time | |
CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4027 Posts : 337 Location : Woodville Al
| Subject: Re: 1997 Murray widebody trail mower April 8th 2014, 9:10 pm | |
| 44 bucks is a lil steep check tracter supply out look in tracter section where the chain is and there are collers and pulleys you weld together for about 22 bucks from 3 inch up to anout 14 inches | |
T-Dub13 Established Member
Age : 54 Join date : 2013-12-06 Points : 4363 Posts : 540 Location : Central MA
| Subject: Re: 1997 Murray widebody trail mower April 9th 2014, 9:34 am | |
| - CornShuck4CE wrote:
- 44 bucks is a lil steep check tracter supply out look in tracter section where the chain is and there are collers and pulleys you weld together for about 22 bucks from 3 inch up to anout 14 inches
yeah, I don't have a tsc around here, just applied industrial | |
| Subject: Re: 1997 Murray widebody trail mower April 11th 2014, 12:54 pm | |
| take it apart and justify that is the problem, and since you are in there replace any other parts that need replacing like bottom seal. ect, | |
| Subject: Re: 1997 Murray widebody trail mower April 11th 2014, 4:48 pm | |
| speaking of oil, who knows where I can get a gasket kit for my twin? And 1997 I would sugest getting that twin. | |
| Subject: Re: 1997 Murray widebody trail mower April 14th 2014, 10:32 am | |
| he accepted! it is a 40 min drive to his place, and I need gas for the truck and I have $8 left after the parts... so I need a job good thing spring break is here! maybe on my way to get the parts I can stop by the scrap yard and sell some aluninum shaveings... | |
| Subject: Re: 1997 Murray widebody trail mower April 17th 2014, 9:52 am | |
| Got the twin, costom exhaust, 16" engine pulley, 3" trans pulley, peerless 930 locked and rebuilt, wiring, and some idiler pulleys. Got $120 for the scrap, truck ran great until the egr gasket gave out I will get pics tomarrow. | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6334 Posts : 2101 Location : Norway, Europe
| Subject: Re: 1997 Murray widebody trail mower April 21st 2014, 10:34 am | |
| locked the front axle for stability, drove it.might change the pulley on the tranny to one that grips the belt better. sounds great, can't weight to ride with the quads! | |
| Subject: Re: 1997 Murray widebody trail mower April 21st 2014, 12:00 pm | |
| what happens when retainer falls off of valve on ohv engine: a better pic of the pipes: and the numbers on the engine. it has the heads with 42 on them, but t is a 40 ci engine, witch i think means bigger valves. | |
