| Updated Pic's of DG350 | |
+11TheRainbowBoxer WilliesBuilds TroyBilt Pony T-Dub13 redlinemotorsportts TheBeal Thunderdivine Doug Craftsman1998 Doc Sprocket DG350 15 posters |
T-Dub13 Established Member
| Subject: Re: Updated Pic's of DG350 December 26th 2013, 1:02 pm | |
| This is the only one they make that is under 2" inlet / outlet. Glasspack 87021. Yeah, those dual shorty's look cool! Should sound great... | |
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5492 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: Updated Pic's of DG350 December 26th 2013, 7:42 pm | |
| Mean looking machine, can't wait to see it run. Does it have have reverse?
DG350 New Member
| Subject: Re: Updated Pic's of DG350 December 27th 2013, 9:17 am | |
| No reverse. The 71 Honda 350 engine/trans assembly was just 4 forward gears. I just used a jack shaft between the engine and the rear sprocket to power it. Nothing fancy. | |
| Subject: Re: Updated Pic's of DG350 December 27th 2013, 12:54 pm | |
| im not sure if you know, but do you think you could put cb350 carbs on a cb400 and re-jet them? I have a cb400 with no carbs and all the junkyard has is 350's. | |
DG350 New Member
| Subject: Re: Updated Pic's of DG350 December 30th 2013, 9:17 am | |
| I'm probably not the person to ask, but my guess is the carb from a 350 (which is actually only 325cc's) will not flow as much air as the carb from a 400. You can rejet all day long to get the fuel/air ratio correct, but that will not increase air flow through the body of the carburetor. It would be like putting a two barrel carburetor on a car that came with a four barrel carburetor. It will work, but will choke performance. Just my .02 cents. | |
1997 Murray Veteran Member
| Subject: Updated Pic's of DG350 December 30th 2013, 11:35 am | |
| It should work, I put a carb from a 230cc on a 15 hp briggs, I think they are 500cc. runs great! | |
Age : 54 Join date : 2013-12-06 Points : 4363 Posts : 540 Location : Central MA
| Subject: Re: Updated Pic's of DG350 December 30th 2013, 12:02 pm | |
- im not sure if you know, but do you think you could put cb350 carbs on a cb400 and re-jet them? I have a cb400 with no carbs and all the junkyard has is 350's.
Yep, (edit) That's the 4 cylinder, right? They should plug right in. Don't bother rejetting until you get it running. You may not have to change a thing. | |
| Subject: Re: Updated Pic's of DG350 December 30th 2013, 1:31 pm | |
| - T-Dub13 wrote:
Yep, (edit) That's the 4 cylinder, right? They should plug right in. Don't bother rejetting until you get it running. You may not have to change a thing. Nope mines not the super 4, just a twin. | |
Age : 57 Join date : 2013-12-21 Points : 4596 Posts : 744 Location : Salem Illinois
| Subject: Re: Updated Pic's of DG350 December 30th 2013, 1:49 pm | |
| A smaller carb (airflow smaller, not physical size) tends to increase low end torque and decrease high end HP at wide open throttle. 99 percent of the time you are not running a carb at it's max air flow. This is why the quadrajet has thos tiny primaries and huge secondaries. The tiny front 2 barrels increase low end torque and fuel economy during normal driving. If the carbs from the 350 will physically fit, I'd say go with 'em. I wouldn't mess with the jets. Unless you intend to build an all out racer, it shouldn't matter to you.... they may even be the same carb. Yamaha used the same mikuni carb for everthing from 200 to 1000 cc's. | |
DG350 New Member
| Subject: Re: Updated Pic's of DG350 January 5th 2014, 9:37 pm | |
| Oh, gett'n stoked!
It's funny, I stripped, chopped and cut up the tractor from it's original state and disassembled the donor motorcycle into a zillion pieces over a year ago. After a while, you start to wonder if it will every breath again. Well, this weekend it came one step closer to coming to life. I finished up the wiring, tested a few circuits, and turned the key. To my amazement, the starter spun and the spark plug I had laying on the cylinder head had spark. It's far from being drivable, but it looks like I can actually start this machine up and hear it run very, very soon. Hopefully I will have time next weekend to plum the fuel system and give it a whirl. Wish me luck.
Randyh | |
DG350 New Member
| Subject: Re: Updated Pic's of DG350 January 21st 2014, 12:40 pm | |
| All right, The DG(dirty girl)350 is alive!!!!
I plumbed the fuel system, hit the starter button, and I swear the engine did not get a chance to spin a second revolution before it fired right up. Sounds amazing! It's not too loud at idle, just a nice muffled rumble. But boy when you crack the throttle it really wakes up. Sounds bad to the bone.
Had my neigbor over and he was just giggling.
Not sure when I will have a chance to finish up the various systems to get it driveable, but at least I can start it up now. This gave me the motivation I needed to keep pressing on. And honestly, your comments/support help also. It's cool when other people "get it". Some folks just don't understand..................
Later, Randy | |
DG350 New Member
| Subject: Re: Updated Pic's of DG350 January 23rd 2014, 7:24 am | |
| I'm going to try and post a vid, but I'm not sure my work email will allow me to send such a large file. | |
| Subject: Re: Updated Pic's of DG350 January 23rd 2014, 7:52 am | |
| oh yea i have one more question about these, does the coil just plug right into the connectors that come out the side case? and a shutoff should be one wire off the coil? | |
| Subject: Re: Updated Pic's of DG350 January 23rd 2014, 8:44 am | |
| Typically, a Street bike motor will have more than one wire coming from the magneto (area). Manufacturers have done things in different ways over the years, so I'd suggest looking for a wiring schematic online if you can find one.
Find the correct ignition coil for the bike / motor and see what it needs to hook up. Usually a twin cylinder will use only one wire to a twin output coil. That wire gets grounded by the kill switch or button to stop the signal from the magneto / points from getting to the coil. Same as a mower setup. | |
DG350 New Member
| Subject: Re: Updated Pic's of DG350 January 23rd 2014, 12:08 pm | |
| On my particular set up, the hot wire from the battery goes first to the keyed ignition switch, then to a cut off switch that allows 12V to go through a single wire to the coils. That single wire splits into two once it gets to the dual coils. So with the cut off switch in the off position, neither coil can get 12v. | |
DG350 New Member
| Subject: Re: Updated Pic's of DG350 January 24th 2014, 7:28 am | |
| Yes. On mine, there as a single connector that recieves the 12vdc from the cut off switch. That connector also has wires in it that leads to the coils and the points.
If you look on the "Honda Twins" website, they have schematics that show this wiring. This happens to be for a CL or CB350, but I believe all the old twin cylinders are pretty much wired the same. | |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2644 Posts : 582 Location : Reeses Mill, WV
| Subject: Re: Updated Pic's of DG350 February 3rd 2019, 8:59 pm | |
| That is one heck of a machine. I got a 1972 Montgomery Ward 4 I will speed 15 and it's got the exact body as that one. Yours must have been made by Gilson like mine. | |
