| Janiece: The Montgomery Mudder | |
+5redzz02 Lawren Wimberly Doc Sprocket 1997 Murray camomanusa 9 posters |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4380 Posts : 467 Location : Greensburg, PA
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5247 Posts : 1311 Location : NW USA
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7119 Posts : 2914 Location : Ontario Canada
camomanusa Member
Age : 57 Join date : 2013-12-21 Points : 4606 Posts : 744 Location : Salem Illinois
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 29 Join date : 2010-05-12 Points : 6177 Posts : 899 Location : PA pittsburgh and pymatuning
| Subject: Janiece: The Montgomery Mudder January 1st 2014, 10:27 pm | |
| great! I know that some of the older MTD's had them, but I wasn't shure when that was. | |
Age : 23 Join date : 2013-04-08 Points : 5010 Posts : 913 Location : Central Pa
Join date : 2013-06-01 Points : 4611 Posts : 578 Location : West Virginia
camomanusa Member
| Subject: Re: Janiece: The Montgomery Mudder January 4th 2014, 2:19 pm | |
| nope, not tht i know of, its a mst 205 but if it did, it dont now, ill see the manual dosnt say anything bout it | |
camomanusa Member
| Subject: Re: Janiece: The Montgomery Mudder January 11th 2014, 4:27 pm | |
| UPDATE 1: This thing is so rigged lol, the guy or whoever had it (im pretty sure) welded the rims on the transaxle. It might be ok though, ill just clean up the rims good and get some bigger tires. My friends family owns are car shop and junk yard, with mowers, so i can get rims for the front, Ill see if i can get same size rims on front and back but bigger tires in back. I post update vids on my channel so ill put a link. Im doin a side build on a little 2hp briggs for when i cant work on my mower. Mower Updates: Wednesday Mower or briggs update or random update: Sunday | |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 4953 Posts : 1068 Location : New jersey
camomanusa Member
| Subject: Re: Janiece: The Montgomery Mudder January 11th 2014, 5:21 pm | |
| There welded right so ill just replace the tires, i thought about it i though "hey they aint coming off now" lol. Ill go to my friends junkyard if i decide to change it | |
camomanusa Member
| Subject: Re: Janiece: The Montgomery Mudder January 17th 2014, 12:27 pm | |
| They arent welded on, it looked like it but it wasnt. i got the back cover off so i started cleaning it up for paint. its supposed to get cold again so there might be a wait on any major progress. | |
camomanusa Member
camomanusa Member
| Subject: Re: Janiece: The Montgomery Mudder February 11th 2014, 5:29 pm | |
| FFS the weather! its driving me nuts. Gotta cold (which wont stop the work) but its still cold outside. I needed to update but i havent done anything. When its warmer, im talking at least 40's out, ill get the engine off and keep tearing it to just frame. ive been working on my side build lately. Its a 2hp briggs horizontal shaft. All i need to do is get the paint off it now, should i just use paint thinner or do you guys do it another way? let me know, Thanks | |
| Subject: Re: Janiece: The Montgomery Mudder February 11th 2014, 5:34 pm | |
| - camomanusa wrote:
- FFS the weather! its driving me nuts. Gotta cold (which wont stop the work) but its still cold outside. I needed to update but i havent done anything. When its warmer, im talking at least 40's out, ill get the engine off and keep tearing it to just frame.
ive been working on my side build lately. Its a 2hp briggs horizontal shaft. All i need to do is get the paint off it now, should i just use paint thinner or do you guys do it another way? let me know, Thanks Lol Its 16 degrees outside and i'm still working on my build Surprised i haven't got frostbite yet. And to get the paint off do you have a air compressor and a wire wheel or sanding wheel. If you don't try using paint thinner. And sometimes Kerosene works. | |
camomanusa Member
| Subject: Re: Janiece: The Montgomery Mudder February 11th 2014, 5:48 pm | |
| - camomanusa wrote:
- no compressor, my ole mans getting one after we move, i got lantern feul will tht work?
hhmm I don't know if it will work. Only one way to find out is to try it. And if it doesn't work you can always wipe it of and try something else. | |
camomanusa Member
camomanusa Member
| Subject: Re: Janiece: The Montgomery Mudder February 18th 2014, 6:47 pm | |
| WORKS ON HALT! I messed my back up lifting stuff all weekend (lifting that snowmobile didnt help either.) My barn also has 3 inches of ice and 1 inch of water covering the floor. I was making a shop cleanup vid but its gotta wait too. If the weather keeps up, it should be melted by Sunday, so ill do it then. No progress on the tractor also. | |
camomanusa Member
| Subject: Re: Janiece: The Montgomery Mudder April 27th 2014, 2:05 pm | |
| Vid soon, got it pretty much torn down and started to do a little bit of painting, i got a few ideas for it so hopefully it works out. | |
camomanusa Member
| Subject: Re: Janiece: The Montgomery Mudder May 11th 2014, 9:14 pm | |
| imma try for a vid tomorrow, I planned on one before but i never got around to it, plus with a possible soon move so ive been cautious of what to get done. | |
camomanusa Member
| Subject: Re: Janiece: The Montgomery Mudder June 25th 2014, 10:05 pm | |
| not finishing, not even close too, i start moving tomorrow and i got camp starting sunday for a week so good luck everybody else that is done/ almost done. cant wait to see waht everybodies looks like that finishes when i get back. I will finish my mower after were done moving, it makes it easier on me to just wait til we move instead of getting really far in it and moving everything. Thanks for the opportunity to enter and to try to win!ill certainly enter the next one if we plan on another one!(And finish hopefully ) | |
