 My 2000 Craftsman build.
2 posters
theoffroader
theoffroader
My 2000 Craftsman build.  Empty
PostSubject: My 2000 Craftsman build.    My 2000 Craftsman build.  Icon_minitimeDecember 30th 2015, 1:55 am
Hello.
Well been watching the forums for a while now so i just started posting.
Been slowly building this thing up for a few years now.
It came with a hydro in it but i changed that out to a 5 speed peerless last summer.
It was our grass cutter for 5 years around the yard. It ran amazing until all the bearings went in the mower deck.
We have since purchased a cheap john deere and have had not very good luck with it.
Anyways.
I drove it around a ton in its stock form with the deck removed for some time. Until i burned out the tranny.
When i got it for tinkering with it had around 500 hours on it. I will guess and say that it has at least 1000 on it currently.
It has a Kohler 20HP V-Twin and it is a awesome engine. Runs great and never complains. We have just done the standard regular maintenance and it has never put up a fight to this date.
A little after i put in the new tranny i stripped out the whole electrical system and started from scratch. I am using a  toggle switch for the kill switch and a keyed ignition for the fuel solenoid and starter. This sadly does have the fuel solenoid. Once it gives me trouble i will just take it out. But it is handy to have because you never have to worry about your carb being gummed up as it uses all the gas before it shuts off.
SO here are some pics. This was before i have painted it. It is currently mostly painted with a rubberized asphalt. The hood is done but i ran out of time and the body id not quite done.
My 2000 Craftsman build.  IMG_20151006_151216_zpsp04opawj
And was how it sat all winter. The tractor on the left is my future project. Also a craftsman, Around the 80's
My 2000 Craftsman build.  20151109_133822_zps1it5hlxx
Compression test for the foot pedal side?
My 2000 Craftsman build.  20151229_1424460_zpssdpmgzjo
Compression test for the clutch pedal side
My 2000 Craftsman build.  20151229_142624_zpsbwvcapjq
I am currently building a new clutch for it as i have completely messed up the stock clutch in doing clutch dumps and such. Big shout out to Fearless Front for giving me the idea. I have learned a lot from your channel and glad i have found it. I have watched literally every video twice and while i am trying not to copy you, This clutch idea was just perfect. So i will give credit were credit is due. SO head over to his channel and give him some support if you haven't already
My 2000 Craftsman build.  20151229_212620_zpscboh9h5y
My 2000 Craftsman build.  20151229_212625_zpsdkn6erey
My 2000 Craftsman build.  20151229_213313_zpspaxa9obq
My 2000 Craftsman build.  20151229_213322_zps3jza5uov
And last but not least. Here is a video of the old beast starting up. I can also post videos of me doing the compression tests if anyone would like
https://www.youtube.com/watch?v=pzVBV4tHxXQ
Also, If you would like to take a peek at my YouTube channel i would greatly appreciate it
https://www.youtube.com/channel/UCxJNF5HTTRJevtvjflMzu9Q
I will do my very best to answer any and all questions that you may have.
Thanks
theoffroader
theoffroader
PostSubject: Clutch Progress   My 2000 Craftsman build.  Icon_minitimeDecember 31st 2015, 12:51 am
Got more done on the clutch today. Got both pulleys were i wanted them and started making the pivot bracket.
Coming along good
Welding is improving as well
My 2000 Craftsman build.  20151230_193640_zpsn0sup3c4
My 2000 Craftsman build.  20151230_201243_zpstqcges3u
My 2000 Craftsman build.  20151230_201251_zpsvciygjne
My 2000 Craftsman build.  20151230_201303_zps8cif6716
My 2000 Craftsman build.  20151230_201322_zpsguzyqy6y
PostSubject: Re: My 2000 Craftsman build.    My 2000 Craftsman build.  Icon_minitimeDecember 31st 2015, 10:44 am
the compression looks great. most my engines only have 60-80 psi. and the two cylinders are supposed to be within 20% of each other, and yours are really close so I wouldn't worry about rebuilding the engine any time in the near future. Nice build!
theoffroader
theoffroader
PostSubject: Re: My 2000 Craftsman build.    My 2000 Craftsman build.  Icon_minitimeDecember 31st 2015, 12:41 pm
Thanks. And i agree.
I won't be rebuilding it becouse it is running so great already. If i rebuild it ill screw something up i am sure haha.
I was pleasantly surprised at how good the compression is.One is just 2 psi more then the other. Just 1.8% more
» Fordification's LGT-2000 build.
» Craftsman 2 build A.K.A No.9
» Another craftsman II build
» Craftsman build.
» craftsman build
