| Willis's 74' Bolens (rolling thunder) | |
+22kawasaki220 crafsmankiller Angchor Speedfreek241 craftsmancole Moose untrusty huskee richie thomas Jedi mr.modified TroyBilt Pony camomanusa Craftsman1998 cjs1029 Thunderdivine 1997 Murray Lawren Wimberly T-Dub13 Creepycrawler redlinemotorsportts MowBandit willis923 26 posters |
willis923 Veteran Member
Guest Guest
Age : 27 Join date : 2013-04-10 Points : 5552 Posts : 1408 Location : Galway NY
| Subject: Re: Willis's 74' Bolens (rolling thunder) January 1st 2014, 8:08 pm | |
| I still dont understand why bolens categorized this as a "GT mower" because the axles are probably stronger then some car cv shafts and it weighs like x2 more then my rig. Probably x4 heaver the mini! | |
1997 Murray Veteran Member
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6334 Posts : 2101 Location : Norway, Europe
| Subject: Re: Willis's 74' Bolens (rolling thunder) January 2nd 2014, 3:19 am | |
| - Lawren Wimberly wrote:
- Pretty sick lookin rig man... betcha can make it bulletproof!
allready looks bulletproof! Good Luck Willis! | |
cjs1029 Member
Age : 25 Join date : 2013-08-26 Points : 3952 Posts : 41 Location : galway
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 4943 Posts : 1068 Location : New jersey
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4370 Posts : 467 Location : Greensburg, PA
Join date : 2013-06-01 Points : 4601 Posts : 578 Location : West Virginia
| Subject: Re: Willis's 74' Bolens (rolling thunder) January 4th 2014, 4:22 pm | |
| theres nothing mini about it... and craftsman98' i would strap it but i dont have anything to anchor it to. idealily i would have a decent shop with a chain-fall or something | |
| Subject: Re: Willis's 74' Bolens (rolling thunder) January 7th 2014, 8:24 am | |
| well boys, update. got my pully off the driveshaft on sunday. had to use the fire wrench to cut the race off the shaft, so now i have to use my flap disk on the angle grinder, so i can make the shaft smooth again. i will be ordering a 3/4 inch 2 bolt flange bearing with a locking collar from surplus centers. i think thats a better option rather than paying 40 bucks for the OEM bearings. i will update again once i get the bearings. might do a re-assembly video too. | |
| Subject: Willis's 74' Bolens (rolling thunder) January 7th 2014, 10:36 am | |
| fire wrench? is that a torch? good to see you making progress. I had to use a 60 ton press to get my pulley off. | |
| Subject: Re: Willis's 74' Bolens (rolling thunder) January 7th 2014, 5:06 pm | |
| - 1997 Murray wrote:
- fire wrench? is that a torch? good to see you making progress. I had to use a 60 ton press to get my pulley off.
yeah, AKA blue tipped wrench. oxy/acetlene torches | |
| Subject: Re: Willis's 74' Bolens (rolling thunder) January 8th 2014, 8:22 am | |
| well boys, update. i want to keep this thread as well as the build off thread. got my pully off the driveshaft on sunday. had to use the fire wrench to cut the race off the shaft, so now i have to use my flap disk on the angle grinder, so i can make the shaft smooth again. i will be ordering a 3/4 inch 2 bolt flange bearing with a locking collar from surplus centers. i think thats a better option rather than paying 40 bucks for the OEM bearings. i will update again once i get the bearings. might do a re-assembly video too. Possibly tires here in the next few weeks too. Im getting Kenda Bearclaws on the rear (24x8x12) and ags on the front (4.80x4x8) | |
Guest Guest
| Subject: Re: Willis's 74' Bolens (rolling thunder) January 8th 2014, 3:47 pm | |
| heck yea!!! im thinking of running kendra bear claws aswell on my build but not 100% sure yet tho see 3-4 others running them aswell but they are some great tires tho so ud almost be dumb not to run them on ours u know for the price!! |
| Subject: Re: Willis's 74' Bolens (rolling thunder) January 8th 2014, 5:51 pm | |
| yeah! i couldnt believe how cheap they were, even at rockmountainatv. i'll let you know how they do once i get them. i am aiming for the old ag look, without the ags.. something with more bite, and the bearclaws look similar, and have some serious treads | |
Jedi Member
Join date : 2013-11-27 Points : 3854 Posts : 44 Location : Georgia
| Subject: Re: Willis's 74' Bolens (rolling thunder) January 15th 2014, 9:36 pm | |
| STILL waiting on parts... ffs.. sometime this week would be nice. its been warm so the snow is down, mud is up and there is soooo much water | |
| Subject: Re: Willis's 74' Bolens (rolling thunder) January 23rd 2014, 7:18 pm | |
| WOOHOO!!! bolens is back in the running! got my bearings on, now i just have to get them mounted to the plate, and slam everything back together! hopefully tomorrow we have a shop day in school, i'll drill everything. maybe scrounge up some bolts. then get home, fire up the salamander out in the shelterlogic (0degrees out) and get it back together yall dont understand how bad i want to put it back on its wheels and go for a hardcore snow romp | |
