| | Scotts S1742 Trail & Trailer Pulling | |
+13the craftsman mudder Stretch44875 Lawren Wimberly T-Dub13 camomanusa Doc Sprocket richie thomas willis923 LAWN MOWER MUDDER redlinemotorsportts 1997 Murray Moose B440 17 posters | |
| Subject: Re: Scotts S1742 Trail & Trailer Pulling August 7th 2014, 11:11 pm | |
| Trailer is looking great! Are you going to weld the front axle so the chassis doesnt tip all around? Or did i miss something? - CornShuck4CE wrote:
- Finaly someone found a good use for a craftsman.
Looks good like the build Woooooah! | |
| | | B440 Member
Join date : 2014-01-22 Points : 3995 Posts : 226 Location : Thompson, CT
| | | | B440 Member
| Subject: Re: Scotts S1742 Trail & Trailer Pulling August 24th 2014, 1:49 pm | |
| Did a little work to the Scotts last night. Forgot to take pics I removed the transaxle, replaced the 4" steel pulley with a 6" aluminum pulley. 6" is actually the stock size for the spicer tranny. I wanted to go a little slower as it's more useful that way. Didn't have to change the belt because the belt-tensioning system gave me enough slack for the larger pulley. Filled the trans with gear oil (didn't remove the grease) to try and tone down the whining noise. Drilled a hole though the neutral switch and put a rubber hose on to vent it. Just little fixes here and there. This is still my favorite, and most reliable machine. At some point, I want to treat it to some better front tires. | |
| | | B440 Member
| Subject: Re: Scotts S1742 Trail & Trailer Pulling September 2nd 2014, 7:39 pm | |
| Weight! for the front. Two brake rotors and two flywheels to be exact. It really needed it because of the ATV tires. They are very grippy and I was always having to shift my weight forward to turn. Now I can just turn the wheel and she goes! Less unintended wheelies when taking off too. I'll add a bracket to the top for support later, but it stays in place pretty good right now. | |
| | | B440 Member
| Subject: Re: Scotts S1742 Trail & Trailer Pulling October 29th 2014, 4:15 pm | |
| Changed my muffler today. The "down-in-front" muffler style isn't all that great for off-roading, or in my case, pushing brush back. My buddy's Murray with B&S OHV has a much simpler design that has the muffler right on the exhaust side. I've been patiently waiting for a cheap one and found it on a friend's MTD that had a hole in the block. Just making sure it fits. You can see the old muffler still attached. Took it off, painted and refit. It stops just before the tire. I did have to modify the hood. The sound is the same. Actually, it's a little quieter because after I hit something with the old muffler, it separated it from the header pipe and was louder | |
| | | B440 Member
| Subject: Re: Scotts S1742 Trail & Trailer Pulling November 29th 2014, 7:38 pm | |
| - B440 wrote:
- Yes I'm going to weld it. Need to strip paint off and maybe even add metal before welding.
Ha, I've changed my mind. I found an easier way to stop the front axle from pivoting. A couple bolts: Carefully placed into these holes, and Bam! No more pivoting. Not sure why it took me that long to do this? I haven't used the trailer in awhile. It got some use today when I had to grab a parts machine and take all four wheels off. Still thinking about the crane hoist attachment, but that's at least $100 away That's all I got for now. I've been busy with a JD 212 that I've been setting up for plow duty. | |
| Subject: Re: Scotts S1742 Trail & Trailer Pulling November 29th 2014, 9:21 pm | |
| Crane attachment? Yea know HF has there 2500lb winch on sale for $50 this weekend or something.
Also, what about your 4x4x4x4 thing? | |
| | | B440 Member
| Subject: Re: Scotts S1742 Trail & Trailer Pulling January 12th 2015, 4:12 pm | |
| It's been cold, and rainy, and did I mention cold? I lose a lot of interest in building when it gets real cold out. But, I found someone giving away gym equipment on CL, which leads me back to working on the trailer. This is where the tower will go: Mocking up the metal. These are pieces from a bed rail and a large box store sign. Two pieces of angle iron should be strong enough for the base. I thought about bolting the large angle piece, but just welded it. I didn't want to remove any structural integrity. Here is the part from the gym equipment. Already has a pulley up top. It's bolted in three places and I reused the plates that came with it. You can sort-of see the plates. They are acting as washers on both sides. I still need to purchase the hand-powered winch from HF. It'll mount where my hand is. A mock-up of the cable location; This is how it will sit until I get the winch. I don't think I want to get an electric one. Trying to keep it simple. I may add a ramp to the back to make it easier to load. | |
| | | B440 Member
| Subject: Re: Scotts S1742 Trail & Trailer Pulling June 6th 2015, 10:16 pm | |
| I think a little too much time has past since my last post. But I have been doing a little bit here and playing a bit there. The tractor popped the welded diff while I was doing donuts in the woods. No damage, I'm back to an open diff I bought the hand winch a long time ago and it collected dust in the garage. Today, it is mounted and ready to use. I did as much welding as possible today. I even beefed up the towing plate on the tractor. Hard to see, but the ball hitch sits a little higher now. I made up a better mounting point so the winch handle didn't hit anything when spun. So here's a Scotts 20/48 garden tractor. Nice and heavy. I really need to add a ramp. The tractor still required lifting, but I didn't have to completely dead-lift it. More like; Turn the winch a little, shove tractor, turn, shove, turn, etc. Didn't even break a sweat. | |
| Who is online? | In total there are 46 users online :: 0 Registered, 0 Hidden and 46 Guests
