| Backfiring out the carb | |
+3redlinemotorsportts willis923 Dipshaw87 7 posters |
Dipshaw87 Member
Age : 57 Join date : 2013-12-21 Points : 4596 Posts : 744 Location : Salem Illinois
| Subject: Re: Backfiring out the carb February 24th 2014, 3:12 am | |
| I'd check the valve lash.... I'm thinking it is an overhead valve engine. I think the valves are gapped too small and your intake is staying open once the engine warms up
Forget the carb and governer for now, and check the basics... valve lash first, then timing
Just my two cents | |
Dipshaw87 Member
Age : 29 Join date : 2014-01-02 Points : 3948 Posts : 135 Location : Vanderbilt, Pa
Dipshaw87 Member
Dipshaw87 Member
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5552 Posts : 1408 Location : Galway NY
Dipshaw87 Member
| Subject: Re: Backfiring out the carb February 25th 2014, 10:27 pm | |
| Well I'm trying to get a set of valve spacers so I can measure the gap between the rocker arm and valve. I have some I just can't find them lol | |
Dipshaw87 Member
Dipshaw87 Member
| Subject: Re: Backfiring out the carb February 26th 2014, 1:17 am | |
| Ok so I've been doing research online about the lmh 32 walbro carbs. Apparently there are 2 oem replacement for those that fits the tecumseh oh160. It's the walbro whg 17-1 and 16-1. The first one (17-1) has an adjustable high speed jet and the 16-1 doesn't. But everything else like the Venturi size are the same on those as the lmh 32. | |
| Subject: Re: Backfiring out the carb February 26th 2014, 8:49 am | |
| - Dipshaw87 wrote:
- Well I'm trying to get a set of valve spacers so I can measure the gap between the rocker arm and valve. I have some I just can't find them lol
you can just get a set of feeler gauges from a local auto parts store, probably for less than 10 bucks | |
Dipshaw87 Member
Dipshaw87 Member
| Subject: Re: Backfiring out the carb March 1st 2014, 7:31 pm | |
| I'll get to adjusting the valves tomorrow afternoon and I'll try and post pictures up | |
fast adam Member
| Subject: Re: Backfiring out the carb December 22nd 2014, 9:49 pm | |
| Is there an air filter on it? Is it bolted to the block good and tight? | |
