Welcome to the All-Terrain Lawn Tractor Forum! 2024 is the 10th and LAST ATLTF.COM BUILD-OFF . . . for now! |
| | Welding problem please help! | |
83ratrodmurray Member
Age : 28 Join date : 2013-07-05 Points : 4090 Posts : 94 Location : Kentucky
| Subject: Welding problem please help! March 15th 2014, 10:27 pm | |
| Today while I was welding I ran out of wire. I had been using flux core wire, so I didn't need gas. I decided to switch to solid wire and gas, so I hooked up the gas, switched the polarity for the gun, and did everything according to the book that came with the welder.
When I went to weld, I didn't hear any gas flowing from the mig gun and my weld had pinholes in I. So obviously no gas is flowing. when I hit the trigger the flow meter on the regulator goes down so gas is able to make it to the welder but not out the tip of the gun. I did not see any obvious signs of blockage anywhere so I have no idea what to do at this point. Any ideas? | |
| | | Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4749 Posts : 919 Location : Defiance, Ohio
| Subject: Re: Welding problem please help! March 15th 2014, 10:51 pm | |
| check your lines running through the welder check connections around the solinoid etc etc your more than likely losing it before the gun if it isnt coming out at all | |
Age : 27 Join date : 2013-04-10 Points : 5559 Posts : 1408 Location : Galway NY
| Subject: Re: Welding problem please help! March 17th 2014, 8:35 am | |
| if your flowmeter is reading gas going through it, its flowing, just not making it to the gun. check around where the gun lead connects to the welder. if you pull the trigger and you hear a hiss, then thats where the leak is. its best to take the tension off the drive rollers so its not spitting wire while youre messing with it, also, make sure you have the right nose cone on the gun too | |
| | | Craftsman Dude Member
Age : 29 Join date : 2012-09-08 Points : 4410 Posts : 145 Location : MS
| Subject: Re: Welding problem please help! March 17th 2014, 4:54 pm | |
| Where the mig gun connects to the machine there should be some o rings if these are broken or missing you could be loosing gas there .Did you change from a flux core nozzle to a mig nozzle ? Also what machine is it? How many cfh are you running. | |
| Who is online? | In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests
